Old 10-26-2009, 01:02 AM   #1
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Default The SHOP + JR TUNE 2006 STI + HTA86 goes 10.43 @ 135.86
Event: Test and Tune
Ambient Temp: 55-60
Elevation: 0
Weather: Sunny
Track and Conditions: Ice Skating Rink
Tires: Mickey Thompson Death Ride 17 X 26 X 7
Car: year, model = 2006 STI
Tuner: [email protected] SHOP CT!!!
Peak HP at RPM: Around 580-600whp
Peak Torque at RPM: 500?
Target Boost: 25-28psi (Waste gate + Creep )
Fuel: VP Q16
Engine/Power Modifications: built 2.5ltr, The Shop 4.5" FMIC, HTA86 Single Scroll rotated mount, fuel system w/2200s... All built and tuned in house @ THE SHOP CT
Driveline Modifications: Jodi-Spec PPG 6spd, BC Coil overs, DSS Axles, DSS Drive shaft, Exedy triple disk, Wilwood front brakes.
Other Modifications: HEAVY!!! Full Interior 06 STI, AC,HEAT,STEREO,POWER EVERYTHING + 10pt Cage and Chute
Finally got the 06 STI out for some test runs.
1st pass was to check LC and alignment. Someone spilled something on the track so I found myself riding the center line so I let off.
2nd pass I got the LC working and cut a low 1.6 or 1.59.. but I quickly let off when I hit 2nd and the car was pointed at the guard rail... Rolled it out again and saw a 40mph gain from the 1/8th to the 1/4 but the car was very unstable up top.
3rd pass just stayed in it. Car was not going straight but felt pretty good so I just let it rip. Lift shifting and using the clutch with the exception of the 3-4... The AEM saw 8500rpm for some reason around the 1000-1100ft mark and turned on the soft ignition cut... You can hear the car lay down on the top side. Pretty sure it would have been a 10.0-2 @139-140mph had it not seen the limiter.
Oh well.. We are done with the 17s.. We have 15" ET Drags mounted and ready to install for this week. The car is to heavy to run on the MT MotorCycle slicks.. The car swings side to side all the way down the track, not a good feeling.
Jimmy, Berto, and Hector as usual put together a monster.
Cant say it enough The SHOP CT is 100% the best shop I have ever worked with. They make my job so easy. Jimmy knows these cars inside and out.. Jim is the real deal. 95% of the time he is in the shop working on cars instead of just being a business owner sitting around "talking" about getting **** done.. From assembling a motor to installing it.. He gets it done.
I'm glad to be part of the TEAM @ The Shop
Rob58 has himself one bad ass street car!! All the patience he has shown while the car was built. It was nice to see him happy watching the monster he had built go down the track. This is just the beginning too.. Car has another 15psi to go before its on kill.
Junior2JZ is offline   Reply With Quote
Old 10-26-2009, 01:22 AM   #2
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
Wish I had known you where running it, I woulda shot on up there to see it
2002WRXSTi is offline   Reply With Quote
Old 10-26-2009, 02:55 AM   #3
TheStig22B
Member#: 171328
01 GT35R'd RS
Good job Junior, that thing is going to be a monster on the ET Drags.
TheStig22B is offline   Reply With Quote
Old 10-26-2009, 09:16 AM   #4
STi_chet
Member#: 187528
91 Supra Turbo
Yeah saw that car in person its f**king fast. I was the guy in the white sti i ran a 12.9.
STi_chet is offline   Reply With Quote
Old 10-26-2009, 09:16 AM   #5
SharpByCoop
Member#: 199906
2008 Infiniti G37S
World's quickest: 11.13"
Nicely done, Junior. I sense your frustrations on the failed attempts. Island Dragway IS an often-disappointing venue. Smart to know your limits.
135 with a burble is serious.
Congrats to Rob58 for his patience.
Coop
SharpByCoop is offline   Reply With Quote
Old 10-26-2009, 10:15 AM   #6
jays05
Member#: 78165
05 STI 35r + e85
Nice! What happened to running it with the hoosier 245/17s ? Or were they for another car
jays05 is offline   Reply With Quote
Old 10-26-2009, 10:17 AM   #7
WRXPowa112
Member#: 158527
2006 STi BABY!!!!
10.72 @ 131mph
sorry to rain on the parade. some stuff does not make sense. the run is fine but the reasons and stats you are giving are not.
questions:
- the car was tuned for 40psi but you ran it on 28psi?
- you have slicks for the car all the time but you ran street tires?
facts:
- it could not be a skating rink if you trapped 106 in the 1/8th and picked up 29mph upstairs. you could blame the cold weather but 60 degrees is not freezing point and you could also blame the someone spilling something but again the mph on the slip does not show sliding. i think you are making this vehicle out to be more than it is.
- you claim it is heavy but the pictures show otherwise:
you can see from the GAP from the top of the tire to the bottom of the quarter panel. looks like an off road vehicle. the car is no were close to being heavy.
GP
WRXPowa112 is offline   Reply With Quote
Old 10-26-2009, 10:25 AM   #8
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I dont know you or them so Im not going to make up to many excuses however there are many reasons that would explain all of the above other than saying than saying the car is heavy. Yes the car was tuned at 40 psi but this may have been a shakedown which would make sense since he mentioned playing with the lc and ffs. Also, you can spin and have traction problems and still turn good sixty foots and even pick up quite a bit of mph on thie big end. As far as having slicks and not using them I agree this car is a monster and should have used the slicks but since i like being able to say streetable i would have used street tires as well, maybe they were worried about breaking things??
stretchedk7 is offline   Reply With Quote
Old 10-26-2009, 10:30 AM   #9
dansabzz
Member#: 202111
2006 Wrx WrB
b00sTiN!
Junior is the BEST ! To bad i couldn't go with mike to the track yesterday
dansabzz is offline   Reply With Quote
Old 10-26-2009, 10:31 AM   #10
jays05
Member#: 78165
05 STI 35r + e85
The tires were MT motorcycle slicks, it was mentioned twice. There's a video of one of the PR cars going sideways in 4th gear with those tires...
Old 10-26-2009, 10:32 AM   #11
WRXPowa112
Member#: 158527
2006 STi BABY!!!!
10.72 @ 131mph
very good points but still leaves alot of WHY in those answers.
- slicks were used for tuning, launching the car outside to get the lc correct, etc... but when it came to track day....they took them off?
i read all of there posts thoroughly and follow all of there threads. this is why i ask what i ask. there are still alot more questions to ask but i will wait until these are answered before moving on to others.
- i would like to see a video of this run.
GP
Old 10-26-2009, 10:38 AM   #12
jays05
Member#: 78165
05 STI 35r + e85
Not street tires! lol
Old 10-26-2009, 10:45 AM   #13
dansabzz
Member#: 202111
2006 Wrx WrB
b00sTiN!
Car is HEAVY weighs a good 3500 plus chute, 10pt roll cage, driver etc. especially when it was going on mt motorcycle slicks
Old 10-26-2009, 10:47 AM   #14
WRXPowa112
Member#: 158527
2006 STi BABY!!!!
10.72 @ 131mph
the pictures above show different
the car is not as heavy as you think to be jacked up that high in those pictures
Old 10-26-2009, 10:48 AM   #15
dansabzz
Member#: 202111
2006 Wrx WrB
b00sTiN!
they have bc coilovers which i believe you can adjust ride height
Old 10-26-2009, 10:50 AM   #16
dansabzz
Member#: 202111
2006 Wrx WrB
b00sTiN!
Old 10-26-2009, 10:57 AM   #17
WRXPowa112
Member#: 158527
2006 STi BABY!!!!
10.72 @ 131mph
i doubt anyone puts coilovers on to jack up a car. not to mention, after installation, they are already lower than stock.
so again, brings me back to my point on weight.
Old 10-26-2009, 10:58 AM   #18
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Honestly, just get the F out of this thread. I didnt post in the AMR threads much, only lurked, and it is obvious that you were very frustrated there. Now your trying to lash back by bringing chit in here.
FYI, even though the term "full weight" is used loosely, the carbon trunk and lightweight seats of this car are countered by the cage and chute. It is literally heavier than stock if anything.
STi Mikey is offline   Reply With Quote
Old 10-26-2009, 11:06 AM   #19
dansabzz
Member#: 202111
2006 Wrx WrB
b00sTiN!
Thank you STI MIKEY if you want to BASH get out of this forum, you dont appreciate good work and just are a HATER
Old 10-26-2009, 11:07 AM   #20
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
way to ruin a perfectly good thread
Thats why when I run I try to provide pictures and video of my car on the scales and showing its full interior.
Sick car Junior, congrats
I can't wait to see you all at the shootout
Old 10-26-2009, 11:08 AM   #21
the real suby dude
Member#: 125497
02 Alpine White M3
Rouge Engineering !!!
ahahahha GET EM MIKEY
the real suby dude is offline   Reply With Quote
Old 10-26-2009, 11:17 AM   #22
WRXPowa112
Member#: 158527
2006 STi BABY!!!!
10.72 @ 131mph
It does not matter what thread I speak in. Facts are facts. JR and these guys are quick to question everyone but when they go out its excuses excuses on what coulda-shoulda happened and what they did to the car before went to the track to "down tune it" which never make sense and then claim the car "will go this fast if we had bla bla bla what they took off originally" (ex: no slicks, no 40psi, etc... not to mention no video).
I follow there threads and comment when there is a good job. You are arguing with me for posting facts that people aready know from there threads. I can also say what everyone says on this forum, how do we know thats even the car? Is that slip even for that car? Weres the video?
I am not here to argue just asking alot of WHY questions. Please do not take this wrong but I am part of the Subaru community as well and I would like to know the answers to my WHY questions.
Old 10-26-2009, 11:17 AM   #23
CatfaceType-R
Member#: 81102
are you seriously saying you can measure weight with your eye's
that STi is heavy because it's jacked up high...
that STi is like that for weight transfer if anything
you realize you sound foolish, don't you? just run for the hills on this one...
CatfaceType-R is offline   Reply With Quote
Old 10-26-2009, 11:28 AM   #24
dansabzz
Member#: 202111
2006 Wrx WrB
b00sTiN!
Old 10-26-2009, 11:28 AM   #25
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Either way, 28 psi and tens is stupid! I would pull over on my bike (gsxr 1000 on the spray) and cry if i did a roll with ANY car and it ran with me. Very nice build, very very nice tune.
