Old 10-26-2009, 09:38 AM   #1
Mechie3
Member#: 120152
Default Oil Cooler O-ring
The FSM for the 06 WRX shows the cast iron piece put onto the block with a large o-ring using the smaller 21mm bolt with an o-ring before and after this bolt. I don't recall these being there when I took the engine apart, nor are they in my gasket kit. There doesn't seem to be a space for them either.
The aluminum piece has an o-ring put onto the next and this is held on with 6 or 7 smaller bolts. This looks a little different than the FSM, but what the engine I took apart has. Has anyone else assembled an 06 oil cooler assy to verify that the FSM doesn't quite match the real product in this case?
Mechie3 is offline   Reply With Quote
Old 10-26-2009, 01:20 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Can you post some pictures of what you're trying to ask? I'm not following you.
Old 10-26-2009, 03:03 PM   #3
Mechie3
Member#: 120152
Will do. I forgot to post last night and don't have the FSM on hand at work.
Old 11-16-2009, 12:26 PM   #4
Mechie3
Member#: 120152
Took a while...here's the pic. It's part "H". Based on the picture, it looks like an O-ring goes on both sides of that small(er) hollow bolt, part "B". My cooler has an O-ring groove on part "C" that the lower "H" can fit onto. This seals against the inside bore of part "A". If I put on the upper "H" o-ring, it will be squished between the bolt head and the counterbore of "A". There is no groove to hold it.
I don't recall this part being on it when I took it apart, but want to double check. If the intent is to seal the inner chambers of C and A, then I have done that with the single O-ring as the two parts nest inside each other. I've found a few other places were the FSM for the 06 is a little bit different than what I've seen in reality.
Old 11-16-2009, 02:13 PM   #5
JRach
Member#: 78075
98' SF5 STI
93' GF8 (rally)
For 06' the wrx changed the design of the oil cooler. (the picture you posted above is the 06/07 wrx design)
C is connected to A with a bunch of (i think 6) little bolts.
However, when removing the main oil cooler (D) from C/A, it's held into place via (E) which threads into (C). C is simply a sandwich plate that angles the oil cooler a little bit.
The 06' WRX oil cooler IS different than the 06' STI oil cooler (the STI is similar to the 02-05' wrx oil cooler, as it's one piece design and comes straight down from the block, (rather than angled via the angles sandwich plate).
I didn't use the FSM, but if I had to guess it may be showing the sti version of the oil cooler.
If you don't remember it being like that when you removed it, maybe a previous owner of the car changed it to the other style. As that's what I had to do on a 06' wrx when installing equal length headers, because the angle it sits originally blocks the headers.
JRach is offline   Reply With Quote
Old 11-16-2009, 02:58 PM   #6
Mechie3
Member#: 120152
The pic is from the FSM.
I'm the only owner of the car.
I'll post up pics tonight or tomorrow of the spare assembly I have. I have all the parts shown in the pic, and it all makes sense, except for there being two "H" o-rings.
Old 11-16-2009, 04:47 PM   #7
Mechie3
Member#: 120152
Here's what I have (from older pics I have):
Part "A" engine side, O-ring "G", Part "D" O-ring "G"
Part "A" bottom side and a mystery o-ring. I know for a fact the blue o-ring goes there. In the FSM diagram it would be upper o-ring H, but it doesn't match the other o-ring H. There's no other place for it. All I can think, is that they changed the design, or have a mismatched diagram. There are still 2 o-rings that seal the inner chamber from outer, and the outer chamber from outside.
Part "C", lower o-ring "H". This slips over the neck in the middle of "C" and squeezes into the bore on the bottom side of part "A"
I think everything is good, just want final confirmation. (I'm paranoid after losing more than a couple engines).
Old 11-16-2009, 04:50 PM   #8
Agile Auto
Member#: 91335
Looks good to me
Artie
Agile Auto is offline   Reply With Quote
Old 01-22-2013, 08:02 PM   #9
eagle98ak
Member#: 49526
2006 20GXTR 6spd Wgn
SGM
Anybody know the part number for the non angled STI version of part C? I can't seem to be able to find it. :-(
eagle98ak is offline   Reply With Quote
Old 10-13-2013, 02:54 PM   #10
Volatle
Member#: 194515
Where is the diagram on subarugenuineparts.com for the oil-cooler assembly? I've looked under engine and cooling and have searched for it.
Volatle is offline   Reply With Quote
Old 01-15-2014, 01:51 AM   #11
Konathebarbarian
Member#: 370557
'94 Legacy Touring
'98 M3/4/5
Default quick tip
So this is a bit of a thread bump but not as bad as the ones you occasionally see that are > 8 years old
There are a couple other threads on NASIOC about this oil cooler gasket, but this one had a nice diagram and some other pertinent info so I figured I would share a tip for those looking to replace the gasket. And the tip is...you may not even have to replace it!
Instead of replacing it, what I think you should do first is simply tighten the large bolt that holds the assembly to the block a little bit and see if that solves the issue. You will need a 24mm deep well socket in order to do this job. Clean the area well with some engine cleaner and monitor the area for a couple days after you tighten the bolt a bit and see if you are still getting oil to appear.
If you do see oil, well go ahead and replace the gasket and get angry at me for even suggesting this incredibly stupid idea.
My theory is that it loosens over time because during each oil change when you remove the oil filter, you also ever so slightly loosen the bolt as well, giving oil a chance to work its way out.
My 06 wrx had a the signs that the oil cooler gasket needed to be replaced so I went ahead and replaced it. When I inspected the orange gasket I suspected to find a small tear or something where oil was getting through but I did not. In fact it looked brand new! I wish I would have just tightened the bolt first and see where that got me and go from there.
Anyway, hope this helps someone in the future.
Konathebarbarian is offline   Reply With Quote
Old 06-24-2014, 01:37 AM   #12
Miatamaniac92
Member#: 62392
05 Subaru
STI - Stock
I have this issue and I'm going to try what Konathebarbarian suggests at the next oil change.
However, finally tracked down the part number for the oil cooler filter o-ring gasket:
21370ka00
http://www.subarupartsforyou.com/p/21370KA001-10566
http://www.subarupartsdepartment.com...?siteid=215189
Miatamaniac92 is offline   Reply With Quote
Old 06-24-2014, 08:08 AM   #13
Justin V
Member#: 98747
07 WRX
the 06-07 WRX had a different heat exchanger setup than the STI's
no iron plate if I recall.
Justin V is offline   Reply With Quote
Sti pistons, ring set, rods, oil cooler gabosub Private 'Wanted' Classifieds 6 10-06-2009 09:35 AM
STI parts: pistons, rods, oil cooler, oil pump, ring set, ... gabosub Private 'Wanted' Classifieds 3 10-03-2009 05:53 PM
Oil Cooler "O" ring gasket install question? aveera Service & Maintenance 0 07-02-2008 09:24 PM
Where are my oil cooler and trans cooler located at? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-28-2002 10:40 AM
spark plugs, oil coolers, transmission coolers, upgraded radiator, who has them? ChristophWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-04-2002 01:48 AM
