Old 10-26-2009, 09:16 PM   #1
mlangejan
Member#: 205567
2000 Impreza rs
blue ridge pearl
Lightbulb 2.5 sohc na heads
just wondering if anybody has actually flow benched a set of these heads and has numbers to go with them. i've heard claims of them out flowing dohc STI heads and flowing as much as the chevy LS1. i ported mine and i noticed a little difference but i also did a bunch of other things to the engine as well. i never had them flow benched so i do not know if it actually did anything.
this is all i figure that the claims are based on is that a na motor relies on volume metric efficiency of the engine as a boosted motor relies on the force of the incoming air to enter the engine so the ports in a na motor would be bigger to get the most out of the engines ability to suck and blow
mlangejan is offline   Reply With Quote
Old 10-26-2009, 09:18 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Nope. Never been done. Not once.
I've never posted my numbers either.
Old 10-26-2009, 09:23 PM   #3
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
Burnout is offline   Reply With Quote
Old 10-26-2009, 11:34 PM   #4
VIsubi
Member#: 187834
06 2.5i impreza
Red
more than a LS1 motor..hmm doubt that but yeahthey flow more than the DOHC's personally built SOHC heads are wicked with boost..port and polish with angle job good be a beast of heads.
VIsubi is offline   Reply With Quote
Old 10-27-2009, 12:13 AM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Mine are out for flowbenching now. When they come back, the porter and I are going to work out a plan for making the heads work with the cams I've finally settled on. Hopefully, within Q1 2010, I'll have PnP'd heads with cams, valves, the works.
Old 10-27-2009, 10:07 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
It was Cobb who published that information. They used to work with Chapman and used to have a graph on their website that showed LS1, Ej22t, Ej25D and Ej251 all side by side. So you can doubt it, but I'll take Trey Cobb's word over yours on this subject.
Old 10-27-2009, 11:07 PM   #7
VIsubi
Member#: 187834
06 2.5i impreza
Red
so ur saying two n/a motors and our heads flow better and more air that makes no sense then why dont more wrx's install sohc heads with boosted applications then anways whatever.
Old 10-27-2009, 11:13 PM   #8
Back Road Runner
Member#: 60082
2004 Forester STI
Cobb like a billion years ago posted flow numbers.
It can be found through the Way Back Machine ala www.archive.org
I made it easier by actually copying both the SOHC and DOHC articles into a Word doc and uploading it.
http://www.gigafiles.co.uk/files/185....5L%20SOHC.doc
Old 10-28-2009, 12:09 AM   #9
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Because it's a pain in the ass to get the SOHC heads to work with an ECU that's expecting a DOHC setup. Then, with the advent of AVCS, it became and even bigger PITA. Frankenmotors are rarely simple.
Old 10-28-2009, 10:28 AM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
Do a search for Wedge's build. Also look for Xephyr's build. Both cars in the 400whp realm running SOHC Ej25 heads. But they were both done on the GC chassis.
I suspect that over time you will see more and more new age 2.5i's slapping their stock SOHC heads onto Ej257 bottom ends and boosting them. With the option to OS tune them now, boosting is a viable option on the modern cars in a way that it wasn't before. You just won't see it on many WRX's or STi's. They'll stay DOHC.
93 2.2 sohc heads on a 02 2.5 sohc, will they fit? Oldbluelegacy Normally Aspirated Powertrain 17 05-05-2010 01:22 AM
Fs: 2.5 Sohc Rebuilt Heads 02darkRS Engine/Power/Exhaust 4 09-05-2008 06:07 PM
ej20 DOHC heads onto 2.5 SOHC NA block tmeh Subaru Conversions 7 05-30-2005 05:18 PM
Questions about the NA 2.5 sohc vizwiz Normally Aspirated Powertrain 2 01-21-2004 02:44 PM
EJ22T with 2.5 SOHc heads. which head gasket? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-03-2001 11:40 AM
