Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 10-26-2009, 11:01 PM   #1
Member#: 18129
1999 2.5RS-T Impreza
Silverthorn metalic
Question Idle issue...
This issue has been going on for years, i've yet to find an answer. So I figured I will try here.
My problem is when my car is sitting idle at like a light or stop sign, my rpm's bounce around from 800-1200 i'd say, and about 95% of the time it will just stall out and make it look like i'm still learning to drive a manual transmission
Is it possible that this issue is due to the flywheel?
My specs:
New EJ25 Block with JE 8.5:1 pistons
Pauter Rods
Total Seal rings
T4 Turbo
Greddy (trust) GC8 FMIC
Exedy Street Clutch
Fidenza Flywheel - could this be the problem?
Vishnu WRX fuel rails
RC 440cc Injectors - getting 750's soon
Supra fuel pump
If you need anymore info just let me know, thanks for your help in advance.
decepticon is offline   Reply With Quote
Old 10-26-2009, 11:44 PM   #2
Member#: 159853
2005 Impreza
I believe your tuner should know whats up. i had the same problem, and i raised my idle so it doesnt stall, cleaned my IACV too.
ADAS1223 is offline   Reply With Quote
Old 10-27-2009, 02:43 AM   #3
Member#: 123295
2001 RSTI Version 6
First things first, try cleaning your IACV.
impreza_GC8 is online now   Reply With Quote
Jumping idle issues, any ideas? Also fueling issues. roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-20-2009 11:32 AM
weird idle issue...not average idle stuff slingshot Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-25-2006 04:24 PM
idle issues and boost issues jdgrimm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-05-2006 09:45 PM
Idling Issues KTB Warranty Issues & SOA Problems 7 04-17-2002 08:00 PM
Long overdue update on idle issue plus website info :) Warp3 South East Region Forum 4 01-17-2001 07:38 PM
