Old 10-27-2009, 02:24 PM   #1
csugden
Member#: 154959
04 JDM STI
Default What do you need to do to have constant voltage to fuel pump?
What do you need to do to have constant voltage to fuel pump? What are the ups and down of doing that ?
csugden is offline   Reply With Quote
Old 10-29-2009, 08:44 AM   #2
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Why would you want that? what are you trying to do?
skingfreak is offline   Reply With Quote
Old 10-31-2009, 10:39 AM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The fuel pump is controlled by the ECU and if the ECU doesn't see ignition pulses it will turn off the pump. It is a safety issue. You don't want the pump running if there was an accident, the fuel line gets severed, and fuel keeps coming out of the tank.
What do you need to do to use E85 fuel? wantsti Rocky Mountains Impreza Club Forum -- RMIC 37 02-20-2014 01:27 AM
`do You Need Retune After Installing Catch Can Set To Atmosfere casper64 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 42 08-21-2009 01:39 AM
WARNING. If you have installed an aftermarket fuel pump PLEASE READ. AZScoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 48 11-12-2005 12:59 PM
why with ecutek do you need a fuel pump? mpower22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 06-03-2005 04:16 PM
ATTN: 99 RS Turbo Projects - I have injectors and a fuel pump for you! K2Skier Private 'For Sale' Classifieds 0 10-07-2003 10:15 PM
