Old 10-27-2009, 05:28 PM   #1
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
Default Anyone with a GC8 OEM camber bolt laying around, can you measure it?
The diameter, please. I had to replace one and the one I purchased from Subaru, referencing multiple places for the part number, is too large to fit in the knuckle by a good amount. The part number seems to be right but the bolt just doesn't fit.
DeusExMachina is offline   Reply With Quote
Old 10-27-2009, 05:45 PM   #2
sachilles
Member#: 115107
02 wrx wagon
61 Morris Mini
silly question, you know you may have to move the knuckle around a bit to get everything to line up in order for the whole bolt to go through? That'll mean loosening up the other bolt.
Just asking, as it could be easy to over look if you haven't done this before.
sachilles is offline   Reply With Quote
Old 10-27-2009, 06:34 PM   #3
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
The knuckle was removed from the strut, and sitting in open air. The threads went into the hole but the eccentric portion would not, by more than a few mms.
Old 10-27-2009, 06:47 PM   #4
jamal
Member#: 71875
98 Legacy GT
my wheels fit
diameter of the cam is 16.5mm. I got about 16.34 actually with a set of calipers.
You do know that the bolt only fits through the upper front hole in one direction, right?
jamal is offline   Reply With Quote
Old 10-27-2009, 07:35 PM   #5
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
Yeah...this is a shop it was at, so hopefully they know. Head of the bolt facing the middle of the car.
Thanks for the measurement, I need to find the caliper and measure mine.
Old 10-27-2009, 07:43 PM   #6
jamal
Member#: 71875
98 Legacy GT
my wheels fit
everything from a 90 legacy to a 2010 sti uses the same bolt.
Old 10-27-2009, 08:16 PM   #7
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
Actually the 2004 and under has one part number, and 2004 and up has another. Different bolts.
Old 10-27-2009, 08:21 PM   #8
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
Mine is 16.38mm...what the hell. Obviously not enough for a big difference the way it wouldn't go in...
Old 10-27-2009, 10:32 PM   #9
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
This thread has just become my failblog.
I went out to the garage, took it apart and compared the eccentric bolt to the hole. There was a lot of corrosion in the hole, probably due to a New York winter. The smaller aftermarket bolt would allow more junk to get in there and allow for more build up.
So an hour later with a file, some elbow grease, and some actual grease, the bolt is in and camber is set.
Old 10-27-2009, 10:37 PM   #10
jamal
Member#: 71875
98 Legacy GT
my wheels fit
they're still all the same. The difference is the coating on them.
Anyone w/ a GD engine apart can you measure something for me? (Pitchmount bolt size) Mike 01Hawk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 05-07-2010 11:06 PM
Does anyone have a busted RS fog light laying around that..... munkis Tri-State Area Forum 13 04-19-2005 08:11 PM
I need help! those that have oem wrx header laying around GregBolby South East Region Forum 0 01-13-2005 09:56 AM
Front camber bolts- how negative can you go? Shankster Brakes, Steering & Suspension 10 09-17-2003 10:39 PM
Anyone in LI with stock 2.5 crank pulley laying around? HRE | giulio Tri-State Area Forum 3 08-23-2001 09:21 AM
