Old 10-27-2009, 06:06 PM   #1
P.I.C
Member#: 119365
04 WRX
Default STI HID's in a wrx???
I was looking to get OEM STI HID's for my 04 wrx but after looking around the bulbs look way different and even the back of the STI headlights look different. Is there a way to make them work using my wrx headlight housing??
P.I.C is offline   Reply With Quote
Old 10-27-2009, 06:17 PM   #2
THEVERGE
Member#: 127421
2002 Subaru WRX
Best bet is to just use the OEM STi housing. You'll blind people using the WRX's. The reflectors weren't designed for HIDs.
THEVERGE is offline   Reply With Quote
Old 10-27-2009, 06:19 PM   #3
Derek E
Member#: 202183
2008 WRX Sedan
Stage II
I asked about a retrofit and my service guy told me the wiring would be a snap, but the 08s HIDs were $700+ per side :-(
Derek E is offline   Reply With Quote
Old 10-27-2009, 09:18 PM   #4
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
A pair of HID projectors(low beam only) on ebay=$80-$120 dollars.
A pair of ballasts $110.
A pair of D2S HID "bulbs" $45-$90 dollars.
Wiring harness-about $30 dollars.
Thats $350 dollars for all the parts needed. You may have a heatgun or oven needed to bake the lights apart and get at the insides to replace the halogen projector with the HID projector and put them back together. If all you want is more light then simply modify a pair of H9 bulbs to fit into your H11 low beam projectors. The H9s are only 10 watts more than the H11s but put out a lot more light and won't melt anything and cheaper than even a cheap PNP HID kit.
Old 10-29-2009, 07:21 PM   #5
P.I.C
Member#: 119365
04 WRX
ok so I purchased the real deal 04 STI housings, just waiting for them to arrive. Is there any extra wiring I will ned to do to make them work in the standard WRX?
Old 10-29-2009, 08:00 PM   #6
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
I believe Caesar at lightwerkz sells a plug n play harness for this. Worth a look.
Old 10-29-2009, 08:14 PM   #7
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
I get sick of this thread always showing up, but thank you for doing it the right way.
XanRules is offline   Reply With Quote
Old 10-29-2009, 10:07 PM   #8
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Lightwerkz does sell a harness. I just got it in the mail. It's mostly plug and play and very straight forward.
Noah is offline   Reply With Quote
how to install MY04 USDM STi HID's on a WRX? skivvie Electrical & Lighting 73 07-03-2009 11:53 PM
sti HID's in a wrx? Giganticprune Newbies & FAQs 12 01-11-2008 04:14 PM
06 sti hid's in 06 wrx blah0r Interior & Exterior Modification 3 01-08-2007 10:04 PM
installed HID's in 06 WRX. are drl's okay??? toekneeyo Electrical & Lighting 22 03-08-2006 09:53 PM
what bulb size for HID's in stock wrx headlights? turn off day lights.. M32WRXin3seconds Newbies & FAQs 8 08-08-2003 05:29 PM
