Old 10-28-2009, 12:18 AM   #1
VIsubi
Member#: 187834
06 2.5i impreza
Red
Default WRX bolt up exhaust on 2.5i bolt pattern
So since both bolt patterns for both cars are the same I'm looking into an HKS Highpower catback exhaust in the 3'' size(yes I know no bigger than 2.5'') but I'm stocking up now on my parts for turbo kit from AVO and the kit comes with a high flow turbo cat. Is it possible or has anyone done this, to bolt up the catback of that size to the stock 2.5i catverter till I get the kit. I've already ordered my stage 3 SPEC clutch and its on its way..with aluminum flywheel. Other than high flow of exhaust gases this should work out pretty well or should I just go with a stock turbo size of 2.5'' which makes no sense since once the built block comes I'll need that 3'' outlet for flow. let me know what you think or links I've looked found nothing nor anyone that really plans on sticking with a built RS block to do this.
VIsubi is offline   Reply With Quote
Old 10-28-2009, 01:04 AM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Uhh.. maybe a shop could make you an .. expander..? I guess. Or put a flange on the stock cat pipe that would let a 3" fit. An exhaust shop should be able to get this to work is what I'm saying.
chazly413 is offline   Reply With Quote
Old 10-28-2009, 01:59 AM   #3
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
I'm pretty sure Vizzions on here, bolted up a 3" wrx catback onto his 2.5i
J-Chow is offline   Reply With Quote
Old 10-28-2009, 08:11 PM   #4
VIsubi
Member#: 187834
06 2.5i impreza
Red
he did any one see any problems running N/A for a short time seems no one can answer this question...hmmm
Old 10-28-2009, 08:34 PM   #5
chazly413
Member#: 151079
2005 2.5RS RBP
It'll run fine, it's just not optimal. I doubt you'll notice that much of a difference.
Old 10-28-2009, 10:27 PM   #6
VIsubi
Member#: 187834
06 2.5i impreza
Red
hmmm cool now to see if a 3'' will bolt up to stock cat since turbo kit comes with high flow cat pointless to buy one also
Old 10-28-2009, 10:49 PM   #7
chazly413
Member#: 151079
2005 2.5RS RBP
I mean.. you could save some time and money and wait for everything else to come, at least that's what I would do.
Old 10-29-2009, 02:30 PM   #8
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Why don't you just not put the new catback on until you put the turbo kit on? Unless you have to trade away what you already have on there, I don't see why you should bother.
BAN SUVS is offline   Reply With Quote
Old 10-29-2009, 10:59 PM   #9
VIsubi
Member#: 187834
06 2.5i impreza
Red
your right was talkin to a friend while we where in the shop building up a S14 about this and I came to the conclussion to just wait...till the kit is bolted and just do it then..
WRX exhaust on 2.5i lionsault Newbies & FAQs 9 08-05-2011 09:20 PM
wrx exhaust on 2.5i subiehatch09 Newbies & FAQs 3 03-10-2010 07:52 PM
power from exhaust on 2.5i? tcoffin014 Normally Aspirated Powertrain 9 05-21-2008 07:28 PM
wrx exhaust on 2.5i tcoffin014 Normally Aspirated Powertrain 8 05-21-2008 04:43 PM
SPT Cat-Back Exhaust on 2.5i or not p2adan Newbies & FAQs 7 04-18-2008 10:36 AM
