Old 10-28-2009, 09:57 AM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Seven New Porsches Revealed
http://www.autocar.co.uk/News/NewsAr...llCars/244386/
Porsche's product plan for the next four years is outlined below.
You can see hi-res spy pictures and artist's renderings of all the cars by following the link below.
Panamera V6 and diesel 2010
Porsche will launch V6 petrol and V6 diesel versions of the Panamera towards the end of next year. It’s unlikely that either model will get four-wheel drive since these versions are designed to be cheaper, entry-level models and, in the case of the diesel, pretty frugal.
With the next-generation Cayenne also not far from the showroom, there’s a good chance that these engines will be updated, if not significantly re-engineered, versions of the units seen in today’s Cayenne.
The Panamera petrol and diesel V6s will make the car far more affordable than the V8s, but this doesn’t mean they will be all that cheap. In the Cayenne, swapping from eight to six cylinders saves about £10,000. If the Panamera follows that pattern, it would mean a starting price of just over £60,000.
New Cayenne - 2010
Next year’s Cayenne will have a much more curvaceous and fluid exterior, to bring it further into line with the design language used on the 911. The bonnet is 911-shaped, tapering to a narrow opening between the redesigned headlights. Wrap-around lozenge-shaped tail lights also give the Cayenne a hint of 911
at the rear. Under the skin, the biggest changes will be the reworked direct-injection V8 engines first seen in the Panamera.
Cayenne Hybrid - 2011
Porsche is in desperate need of a hybrid for the Cayenne range, and although this model was signed off last year, it is not expected to go on sale until 2011. The company says the car will use a “full parallel hybrid system”, and there will be the option of running the vehicle for a short distance in ‘zero emissions’ mode. Porsche is claiming economy improvements of up to 30 per cent, and impressive performance when both the engine and electric motor are propelling the Cayenne.
Panamera Hybrid - 2011
The Panamera hybrid will be one of the most important versions of the super-saloon, but it won’t be cheap. Porsche can use the same sophisticated transmission in the Panamera as it does in the Cayenne hybrid (which combines an automatic ’box and electric motors), but the installation will be quite different.
The Panamera hybrid is unlikely to have four-wheel drive. This is partly for reasons of economy, but also because it has a very different four-wheel drive system from the big SUV. The 4WD Panamera not only uses a Haldex clutch mounted on the rear of the transmission housing, but also directs power forward to a driveshaft system that runs through the engine’s sump.
Although a V8 hybrid might be more appealing to the US, a more efficient V6 hybrid would suit Europe better.
New 911 - 2012
The next Porsche 911, due in summer 2012, will be an all-new model. Porsche is not prepared to take any revolutionary steps with the styling, so while it might look similar to the current 911 don’t be fooled; nearly every panel on this 911 coupé and cabrio will be new. The car will be slightly longer (almost 4500mm across the range) and wider (around 1860mm on the base Carrera and 25mm extra on the Turbo). These alterations are down to a modified steel floorpan, which has a wheelbase extended by 50mm to 2400mm, and new suspension.
Rockster/ Small SUV - 2013
A few years ago, Porsche was seriously investigating building a small SUV to slot in below the Cayenne. One of the full-sized concept models was a three-door “off-road coupe” that had strong 911 styling cues.
Autocar had the design study confirmed by one of highest-ranking Porsche bosses, although he would not comment on the position of the engine, mainly because the styling had strong mid-engine overtones.
However, it has subsequently come to light that Porsche’s engineering arm was working on the body engineering of the new Audi Q5 SUV. It’s likely that this was the donor car, but co-operation is said to have been pulled by the then-Audi boss, Martin Winterkorn.
Latest reports say that now Porsche is part of VW, and VW is headed by Winterkorn, the Q5 could be used as the basis for a baby Cayenne.
Just as the new 356 could allow the Boxster to move upmarket, so the arrival of a Porsche Rockster small SUV could allow the Cayenne to do the same and make the big SUV more profitable.
928 cabrio and coupe - 2013
Having put a substantial amount
of money into the almost entirely
all-new Panamera model, Porsche will be keen to recoup some of its costs. The best way to do this would be a coupé and a cabrio to take on cars like the Bentley Continental GT and Maserati GranTurismo/GranCabrio. One senior company source has already told Autocar that a large three-door, in the spirit of the 928, would be a “very nice” addition to the line-up, although nothing has been signed off. In any case, it is understood that a cabrio version would be first to arrive, in 2013.
Hi-res pics of Porsche's planned cars from 2010 to 2013
New entry-level Porsche revealed
Old 10-28-2009, 10:01 AM   #2
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
+1 on the Panamera coupe.
Spenk is offline   Reply With Quote
Old 10-28-2009, 10:08 AM   #3
Beowulf
Member#: 24465
2012 Regal GS
1990 300ZX TT
Looks like a Ferrari
Beowulf is offline   Reply With Quote
Old 10-28-2009, 10:15 AM   #4
REX8
Member#: 24038
Isn't that supposed to be the 928?
Old 10-28-2009, 10:56 AM   #5
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
This looks cool but what exactly is the market for this supposed to be?
Mike Wevrick is offline   Reply With Quote
Old 10-28-2009, 11:00 AM   #6
lunatictokyo
Member#: 48344
the same market that would consider buying a X6 ...
lunatictokyo is offline   Reply With Quote
Old 10-28-2009, 11:04 AM   #7
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
^^^That thing needs to be taken out back and shot. Repeatedly.
Crazy_pilot is offline   Reply With Quote
Old 10-28-2009, 11:20 AM   #8
nhat
Member#: 140163
03 STi
hellaflunctional
panamera coupe looks great (better than the sedan) from the angle we see...but then again, the sedan doesn't look half bad from that angle. need to see a profile and rear shot before i make a decision.
Old 10-28-2009, 11:35 AM   #9
im2lazy789
Member#: 166857
2009 Ford Mustang GT
I'm not sure, but I know I really want to RallyX that b****
im2lazy789 is offline   Reply With Quote
Old 10-28-2009, 11:36 AM   #10
Hites
Member#: 138997
0000 Nothing
Rockster REALLY looks like a frog.
Hites is offline   Reply With Quote
Old 10-28-2009, 12:38 PM   #11
design1stcode2nd
Member#: 112178
Boxster, Roxster, so any chance they rename the Cayman the Coxster. Still love that from Top Gear.
design1stcode2nd is offline   Reply With Quote
Old 10-28-2009, 12:49 PM   #12
SilverSubaab
Member#: 88288
.... At this point,
even I have lost track.
Indeed.........
SilverSubaab is offline   Reply With Quote
Old 10-28-2009, 12:59 PM   #13
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Upcoming Porsche 356 will be based on the Audi R4
Porsche is preparing to roll out a new entry-level sports car that will help underpin the maker’s long-term future as part of the giant VW Group.
Dubbed by some insiders as the “new 356”, the mid-engined machine will not, however, be a bargain basement model, despite initial rumours to the contrary. Given the final green light, it would cost from about £33,000 in today’s money.
Instead, the 356 is expected to be based on a new steel and aluminium platform that’s being developed by Audi for its own R4 mid-engined sports car.
Work on the R4 is already well advanced, and it’s due to launch in June 2011. However Porsche’s version of the car, which won’t arrive before late 2012, is expected to be significantly different.
Aside from its unique styling inside and out, the 356 is also expected to be one of the first Porsches to be fitted with a forced-induction flat-four engine that is currently under development.
This unit will also help ensure the Porsche and Audi have sharply different characters, even though the two cars have the same basic architecture.
As well as their common structure, the two cars will share many other costly sub-systems. These include the electrical architecture, climate control system, basic suspension layout, electronic chassis systems and innumerable hidden parts, such as seat frames and door locking mechanisms.
It’s also likely that the Porsche will share its transmission with the Audi because the longitudinal unit used in the 911 and Boxster is thought to be too costly.
Not much is known about the flat-four engine at this stage, but Porsche sales and marketing boss Klaus Bening told Autocar earlier this year “That there is a clear trend towards downsizing, using smaller powerplants and supercharging. We will find our own conclusion to downsizing”.
Using today’s flat six as a starting point, a new flat-four engine would come in at just over 1900cc and could use either a light-pressure turbo or a supercharger. The light-pressure turbo set-up is already said to be under development for 2012’s 911.
It’s highly likely that such a unit would be good for about 250bhp. That’s virtually the same as today’s entry-level Boxster, although fuel economy would surely be better.
However, there’s little chance that the 356 and Boxster will clash because, according to one rumoured product plan, the next-generation Boxster and Cayman could be moved sharply upmarket.
Porsche has a financial problem with today’s Boxster/Cayman/911 line-up. According to an analyst’s report seen by Autocar, the cost of the components that make up one of the flat-six models is perilously close to the base price of a Boxster.
Indeed, the entry-level Boxster is only just over half the price of an entry-level 911, despite the two cars costing a similar sum to make.
Porsche can haul in significant profits from this model range in the good times — mostly thanks to the huge margins delivered by the high-end 911s. However, when combined sales fall below 50,000, the profitability of the flat-six model line is badly dented.
In the wake of the 356 launch, Porsche would be able to make the 3.2 Boxster S that model’s entry-level car, priced at £40,000. This would help improve the profitability of Porsche’s sports car line, especially since sales are not expected to be dented significantly.
However, in the long run, all Porsche’s sports cars will probably be based on the 356’s steel and aluminium platform. Selling four flat-engined sports cars on the same basic platform at volumes of over 75,000 per year — plus 25,000 or so units from Audi’s R4 — would help secure the long-term future of Porsche’s most iconic models.
autocar
Old 10-28-2009, 01:16 PM   #14
BlaineWasHere
Member#: 165271
2013 FR-S
IF they build a small SUV it will have 4 doors and by based on the Tiguan/Q5 platform.
It won't be that nasty 3 door thing.
BlaineWasHere is offline   Reply With Quote
Old 10-28-2009, 01:45 PM   #15
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
That's a lot of new models. How many are being driven by VW?
mhoward1 is offline   Reply With Quote
Old 10-28-2009, 01:51 PM   #16
BeatLA
Member#: 182396
2005 WRX Wagon
2004 FXT for Mrs. BeatLA
Anyone else think Porsche is suffering from bi-polar disorder? Not that long ago you had what, 2 choices (911 and Boxster)? Now all these odd SUV's, sedans...etc.
BeatLA is offline   Reply With Quote
Old 10-28-2009, 02:12 PM   #17
justincredible
Member#: 83633
2012 bright green
box
I would gladly rock a Rockster. I just couldn't afford it.
Everything looks great except that 4 door monstrosity.
justincredible is offline   Reply With Quote
Old 10-28-2009, 02:15 PM   #18
G Langa
Member#: 181396
99 Razor Scooter
G Langa is offline   Reply With Quote
Old 10-28-2009, 04:14 PM   #19
aren040
Member#: 74215
Silver-ish
I just don't see it. What does moving the Boxster and Cayman "significantly" upmarket mean? How far can they really move it while justifying the price without interfering on 911 sales.
The Cayman S is already viewed as a better car than the Base 911, yet the 911 costs more. Porsche justifies this by limiting the Cayman S in power and so on. Also, how low is this supposed 356 going to be priced? The Boxster already starts out in the 45K range. So This would be what, the 35K Porsche? Last time they tried this with the 914 it did not fair too well for them. Not to mention that at the 30 to 35K price point it would blow the "exclusivity" of the Porsche brand.
Now granted BMW and MBZ have both gone lower market and not suffered much, I don't know if Porsche can pull that off. Or are they going to bring in this new car in the 40 to 60 range and then move the 987 to the 55 to 70 range and have the 911 be the 70 to 120 range depending on trim levels?
Like I said, I just don't see it.
aren040 is offline   Reply With Quote
Old 10-28-2009, 05:29 PM   #20
s203.22b
Member#: 113970
2005 STi WRB
2001 2.5RS AW
Tiguan and Q5 don't share the same platform. Tiguan is Golf based and Q5 is A4 based.
But back on topic. The 356 sounds very intriguing although properly slotting it, the Boxster/Cayman, and 911 looks to be difficult unless the next 911 will move upmarket to the $100k+ range. I just can't imagine that the 356 could be priced near $35k either. Sounds like the plan is to move current vehicles upmarket to make more money on those and to release new vehicles to slot into the position that were previously occupied to not lose sales.
s203.22b is offline   Reply With Quote
Old 10-28-2009, 05:47 PM   #21
nhat
Member#: 140163
03 STi
hellaflunctional
i blame vdub.
Old 10-28-2009, 06:12 PM   #22
impreza_punk
Member#: 102900
2005 Impreza STi
Rockster reminds me of a Toyota concept (can't remember nor find it atm) but I really liked the Toyota variant, this will probably far out of my price range. Maybe the VW variant will be cheaper.
impreza_punk is offline   Reply With Quote
Old 10-28-2009, 06:32 PM   #23
under5
Member#: 188980
2005 WRX
PSM For Sale:(
Originally Posted by AVANTI R5 View Post
under5 is offline   Reply With Quote
Old 10-28-2009, 06:58 PM   #24
TougeRenner
Member#: 138762
08 STi
Plebeian Silver Metallic
I wonder who they hired at Porsche??? Because Ive seen this look before somewhere......
TougeRenner is offline   Reply With Quote
Old 10-28-2009, 07:09 PM   #25
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Good grief. Are they trying to make sure they have a product in every niche BMW does?
Chromer is offline   Reply With Quote
Ford's new coupe revealed AVANTI R5 Non-Subaru News & Rumors 21 06-14-2009 05:40 PM
New Holdens Revealed mhoward1 Non-Subaru News & Rumors 6 04-10-2006 09:19 AM
new Porsche Carrera GT Wintrode General Forum Archive 3 10-06-2000 12:34 AM
NEW Porsche GT "supercar" matt7184 General Forum Archive 34 10-01-2000 11:37 AM
OT: Saw the new Porsche turbo...and a JERK driver. Reciprocity General Forum Archive 3 09-05-2000 11:59 AM
