Old 10-28-2009, 02:43 PM   #1
IAG Performance
Member#: 158123
Default Dyno Tune: IAG makes 409whp on 2.5L + Prototype Blouch DOM 3.0 XT-R
This has been in the works for some time now and we are happy to bring you the results of our recent testing.
Event: Dyno Testing
Ambient Temp:69F
Elevation: 700 ft
Weather: Overcast
Car: 2005 STI
Tuner: Jorge from P&L (RiftsWRX)
Dyno Info: Dynojet 424x
Peak HP at RPM: 409@6400 (uncorrected)
Peak Torque at RPM: 408@4400@4400 (uncorrected)
Baseline hp/tq for a stock on same dyno: Stock STI's dyno 225-230whp
Target Boost: 22.5psi
Target AFR: 11.7 on pump/12.4 on @16
Fuel: 93 octane/Q16
Engine/Power Modifications:
DOM 3.0 XT-R (10cm2)
APS DR725 FMIC
Catless TBE
PE 850cc
Perrin Big MAF Intake
Perrin 2.4" Inlet
Driveline Modifications:
OEM Clutch (Slipped on Race Gas, but we will talk about that later)
RF010 is on 93 Octane
Above Runs are comparing the Standard DOM 3.0R to the New DOM 3.0 XT-R with Billet Compressor Wheel and 10cm2 Turbine Housing. Both runs are on 93 octane and both cars have similar mods. Note that the with the new lightweight Compressor Wheel the XT-R spools faster!
Above Run is on VP Q16. You will note that we shut to car down early because the clutch let loose. The peak HP numbers are not quite accurate. The car however, was on point to make about 465whp.
The above runs are to compare the DOM 3.0R to the New DOM 3.0 XT-R both on Race Gas. Again, you will note the slipping clutch.
IAG Performance is offline   Reply With Quote
Old 10-28-2009, 03:01 PM   #2
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Stock fuel pump? TGV's intact?
Any comment on how this turbo would do on a stock or larger aftermarket top mount intercooler?
SonicWRX is offline   Reply With Quote
Old 10-28-2009, 03:37 PM   #3
GregsblueRex
Member#: 31997
08 QSM Spec Bizzle
96 XJ Beater
I'm 99% sure it has a walbro. And TGV's have been deleted.
GregsblueRex is offline   Reply With Quote
Old 10-28-2009, 03:41 PM   #4
IAG Performance
Member#: 158123
Right about the Walbro. TGV's are stock though. Stock motor, stock clutch, stock TGV's.
Old 10-28-2009, 03:44 PM   #5
GregsblueRex
Member#: 31997
08 QSM Spec Bizzle
96 XJ Beater
Really..Ok. Still awesome numbers...Pulls like a freight train. I've felt it!
Old 10-28-2009, 04:07 PM   #6
FettLord19
Member#: 132044
2004 STi WRB SOLD!!!
2006 OBP STi
Finally!!! Good to see some more results. I've been very curious about this turbo, and the other "teaser" thread has lost my interest. Wow it appears to really add a good bit of area under the curve vs. the standard dom 3. Were the boost settings the same on both cars as well?
Looks like a ton of fun
FettLord19 is offline   Reply With Quote
Old 10-28-2009, 04:07 PM   #7
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Not as well
Old 10-28-2009, 04:13 PM   #8
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Thanks for taking the time to post up the results!!!!!!!
Was the Dom3 your comparing to using the old 8cm, or the new 10cm turbine housing?
rexworx is offline   Reply With Quote
Old 10-28-2009, 04:17 PM   #9
IAG Performance
Member#: 158123
We will be testing in the next few days actually. We will test with a Spearco TMIC.
DOM3.0R was at 22.5 psi and DOM3.0 XT-R actually starts out at 24 psi and settles in at 22.5. Probably the most significant thing is that the XT-R actually spools much earlier because of the Billet Wheel.
Old 10-28-2009, 04:22 PM   #10
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Originally Posted by kellygnsd View Post
Not as well
Interested in how much it suffers in overall power/torque versus how much it gains in responsiveness on the low end.
Also would be interested in the driving impressions in the lift-off then reapplication of power that FMIC's seem to struggle with.
Old 10-28-2009, 04:32 PM   #11
9vapors
Member#: 92582
So little parts, 409hp! Nice comparison, That turbo is great!
9vapors is offline   Reply With Quote
Old 10-28-2009, 04:37 PM   #12
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
wow glad i did wait when the rumor started about the new turbos im just waiting to see what the xtr + meth will do!
DarkKnightBaku is offline   Reply With Quote
Old 10-28-2009, 05:00 PM   #13
FettLord19
Member#: 132044
2006 OBP STi
^this!
Old 10-28-2009, 05:48 PM   #14
IAG Performance
Member#: 158123
Cool picture of the dyno tuning:
Old 10-28-2009, 07:09 PM   #15
nhat
Member#: 140163
03 STi
hellaflunctional
great numbers
any chance you can compare this turbo to the atp equivalent?
i'm sure many of us are on the fence between these 2 companies as both have taken stock location turbos to a new level.
Old 10-28-2009, 07:58 PM   #16
fourmicah
Member#: 128760
2015 STI
Finally some actual results on these turbos, good to see. I'm interested to see what the Dom 4 XT-R puts out.
fourmicah is offline   Reply With Quote
Old 10-28-2009, 08:42 PM   #17
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Very nice. If I knew you guys were doing this car Saturday night and not Sunday afternoon I would have stopped by.
Thanks again. The car feels amazing and that 321whp is crazy fun. I'll see you guys soon for some new wheels.
You gonna give it another try with a stronger clutch? I'd like to stop by and see it.
-EJ-
Brother EddieJ. is offline   Reply With Quote
Old 10-28-2009, 09:00 PM   #18
JamesBernard
Member#: 180038
IB You dont even
own a subaru!
so stock TGV's + Internal Wastegate + (stock headers?) and still 409hp!?
i think there is some serious potential here.
JamesBernard is offline   Reply With Quote
Old 10-28-2009, 09:37 PM   #19
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
Damn I want this turbo bad. Solid numbers JJ.
jordanretro1223 is offline   Reply With Quote
Old 10-28-2009, 10:04 PM   #20
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
yeah definatly tgv's and maybe some ported intake pieces and your in business
Old 10-28-2009, 10:15 PM   #21
[D.I.]WRX
Member#: 116314
wow....good looking turbo
[D.I.]WRX is offline   Reply With Quote
Old 10-28-2009, 10:45 PM   #22
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
man i think i found my next turbo!, i just wonder how it will run on a ej207 stroker
Thran is offline   Reply With Quote
Old 10-28-2009, 11:35 PM   #23
dankster
Member#: 54592
Originally Posted by nhat View Post
great numbers
I think the blouch would outperform because of the billet wheel. I think I read that the XT-R is 55lb/min rather than 52 like the normal dom3. Is this true?
dankster is offline   Reply With Quote
Old 10-28-2009, 11:42 PM   #24
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
blouch's website doesnt say but it is rated at 550hp instead of 520
Old 10-29-2009, 01:43 AM   #25
JNA Performance
Member#: 184966
---- Visit Us @ ----
www.jnaperformance.com
Nice!
Alan
-JNA Performance-
JNA Performance is offline   Reply With Quote
FS Blouch Dom 3.0 XT-R 2.4" mywifesSTi NESIC Private Classifieds 25 07-13-2011 08:08 PM
Dyno Tune: Junior makes 400whp on a 2.5L + APS SR55 @ 24psi WMP Proven Power Bragging 42 09-28-2010 01:53 PM
2.5L 05 STi + Blouch Dom 3.0 XT-R makes 380whp and 355wtq krambte79 Proven Power Bragging 27 11-20-2009 12:17 PM
IAG + Jorge make 464whp on 2.5L + TSR70 on Pump + Cobb AP IAG Performance Proven Power Bragging 9 11-02-2009 08:12 PM
tips on intalling a blouch dom 3.0 ( HELP ASAP) fastlanerex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-06-2008 06:23 PM
