Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Vendor Classifieds
Closed Thread
Old 10-28-2009, 05:36 PM   #1
P&L Motorsports Inc.
Vendor Sales Rating: (26)
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Default P&L Winter Special!!!
I'm running this special in the reason of the season ending and the new falls of the winter season starting. Lets have another sale....
30k Services
- 250 + parts
  • Replace: Engine oil-AMSOIL-35.50/Valvoline-24.99 $
  • Replace: Engine oil filter-10.00 $
  • Perform: Rotate Tires
  • Replace: Spark Plugs-STI-30.99/WRX-13.00 $
  • Replace: Brake Fluid-AT-15.99/Conventional-10.99 $
  • Replace: Engine coolant-Peak 50/50-11.89x2 (23.18) $
  • Replace: Fuel filter-WRX-39.99 $
  • Replace: Air Filter-K&N Cleaning-Free/OE Replacement 38.47 $
  • Inspect: Drive Belts
  • Inspect: Brake pads/rotors
  • Inspect: Front/rear axle boots, CV joints, axle shafts
  • Inspect: Parking brake operation
  • Inspect: Clutch system operation
  • Inspect: Steering and suspension
STI 340.00
WRX 380.00
60/90K Services
- 450 + parts (timing replaced)
  • Replace: Engine oil/filter-AMSOIL-35.50/Valvoline-24.99 $
  • Replace: Brake Fluid-ATE-15.99/Conventional-10.99 $
  • Replace: Transmission & Rear End fluids-AMSOIL-40.99/Valvoline-35.00 $
  • Replace: Drive Belts-A/C-21.00/ALT-21.00 $
  • Replace: Timing Belt-Gates-125.00/OEM-110.99 $
  • Replace: Water Pump-OEM-110.99 $
    **Timing components that are possible replacements
  • Large Idlers-59.99 $
  • Small Idler-34.50 $-T.B.T.-129.99 $
STI 60/90K 1000.00 (savings of over 25%)
WR 60/90K 1000.00 (savings of over 25%)
P&L Motorsports 50.00 dollar AMSOIL Oil Change Special
P&L Motorsports 10.00 dollar oil change!
• Customer Provided oil
Suspension Special
-Suspension specialty pricing
  • If suspension is swapped for stock from aftermarket 175.00 dollars
  • If suspension is modified to accommodate winter tires and wheels
    *See alignment rate for pricing
-Coilovers and Suspension Components
  • Apexi STI coilovers as low as 1100.00
  • Bilstein STI coilover systems as low as 1800.00
  • DC Sports Strut tower bars in stock
  • Eibach STI coilovers as low as 1450.00
  • Energy Bushing kits in stock
  • HKS Suspension components and coilovers in stock
  • Kartboy Bushings and Endlinks in stock
  • Koni replacement struts and cartridges in stock
  • KW STI coilovers as low as 1550.00
  • SPC Camber bolts in stock
  • Stance as low as 1150.00
  • Swift Springs for all makes and models available
  • Turn In Concepts Components, from coilovers to bushings in stock
  • Whiteline Sway bars, endlinks, bushing kits, strut bars and more in stock
  • Some parts are to low to list!!!
EX: Full Suspension Setup Installed, P&L Recommended
  • Whiteline F/R Sways
  • Kartboy Endlink F/R
  • Stance Coil Overs
  • Whiteline ALK, Center Roll Adjustment, Steering Rack Bushings
  • Installed Price….2900.00!!!
  • PM ME FOR STAGED PACKAGES SHIPPED TO YOUR DOOR!!!
There are obviously plenty of options on what to run and the options of products. Shoot me a PM and I’ll give the best pricing available.
Alignment Specials
-Specialty Winter Pricing
  • 100.00 stock setup alignment or to accommodate wheels and tires
  • 75.00 dollars for the first hour and 50.00 dollars every hour after that for custom spec alignments
  • Specialty pricing if products are purchased through me!
Many more suspension components available as well as custom alignments, fender rolling, custom brace fabrication (roll cages to chassis bracing) and discounts on wheel and tire combos (or by themselves…whatever works)
Brake Specials
-Save up to 30% on these select products
  • DBA Street, 4000, and 5000 series rotors on sale
  • Hawk ceramic, street, and all race pads on sale for all years!
  • Specialty Combos on sale, DBA/HAWK Combos
  • Big Brake Kits on sale
  • Brembo
  • Stop Tech
  • PMU
  • ALCON
  • Many more available!
  • OE Replacement on sale!
-Specialty Pricing on P&L Brake Lines, Quality Racing Brake Fluids, and all your brake needs on HUGE DISCOUNTS!
-GUARUNTEED BEST PRICING!
Pm me, give me a call or even shoot me an Email, as long as you can reach me somehow I’ll be able to help you out!!!
Drive train Specialty pricing
I’ve got all sorts of specials here, everything from OE replacements to 3 carbon plate clutch kits. Check out some of these prices and check out some of the installs with it!!!
-Clutch Kits
-ACT Clutch kits in stock and ready to go!!!
  • ACT HD Streets from 619.99 plus shipping
  • ACT HD 6 Pucks from 599.99 plus shipping
  • ACT HD 4 Pucks from 549.99 plus shipping
  • ACT XT Streets from 699.99 plus shipping
  • ACT XT 6 or 4 Pucks from 619.99 plus shipping
-Exedy Clutch kits pricing available while supplies last!!!
  • Exedy OEM clutches from 339.99 plus shipping
  • Exedy Stage 1 Clutches from 399.99 plus shipping
  • Exedy Stage 2 Clutches from 599.99 plus shipping
  • Exedy Hyper Single from 1250.99 plus shippingExedy Twin Plate Metallic clutch kits from 1799.99 plus shipping
  • Exedy Carbon Clutch kits from 2799.99 plus shipping
-These are just examples, I’ve got everything from Carbonetic, Competition Clutches, HKS clutches, Clutch Masters, Quarter Master, and many more options!!!
-Clutch Kits Installed
  • OE Replacement Exedy 850.00 installed
  • Street Disc (SB4-HDSS) 950.00 Installed (XT 1000.00)
  • Any 6 puck or 4 puck is 950.00 installed
PM Me for more options!!!
-Kartboy Shifter Specials!!!
  • 185.00 for the 04+ 6 speed
  • 145.00 for the 02-07 WRX 5 speed
  • 165.00 for the Legacy or 08+ WRX model 5 speed
  • *All kits include front and rear bushings
*Replace the yoke bushings for another 15.00
-Kartboy Shifter Install Special….100.00 with purchase of products From the P&L Sales Dept.!!!!
-Drive Shaft Shop Specials!!!
  • 1 Piece Aluminum D/S’s as low 439.99 plus shipping
  • Front Axle Upgrades as low 479.99 plus shipping
  • Rear Axle upgrades as low as 479.99 plus shipping
Many more options available just get a hold of me!!!
-Differentials
  • Quaife as low as 1099.99 plus shipping
  • Carbonetic as low as 1299.99 plus shipping
  • Cusco as low as 1089.99 plus shipping
PM me for specialty orders or even rebuild kits!!!
-Group N Engine, Trans and Pitch mounts also available with severely discounted pricing!!!
  • Engine mount kits are only 124.99 plus shipping
  • Transmission mounts are only 69.99 plus shipping
  • Pitch Mounts are only 49.99 plus shipping
-Everything from fluids to OEM parts are on massive discounts!!!
  • Rebuild Kits to in house Rebuilds of your 5 Speed on sale!!!
  • 6 Speed install pricing on discounts!!!
-OEM Parts from drive shafts to seals on sale. PM me or shoot me an Email with your needs and I’ll take care of it.
-Engine Management Pricing Reduced!!!
-I have a list of sale prices from all sorts of tuning programs, everything from COBB A/P’s to AEM EMS’s
  • COBB A/P for all years 595 with FREE OVERNIGHT to any lower 48 states
  • Apexi AFC Neo
  • Apexi Power FC
  • Ignition Controllers
  • Boost Controllers
  • Plus many more available!!!
-Staged Kits Available which included the following...
-AEM kits which include IAT sensors, MAP sensors Adapters, UEGOs and EMS Boxes, Prices as low as 2100.00 for a whole kit!!!
  • Programmers (from Cobb A/P’s to AEM’s)
  • Necessary wiring, adapters, or sensors (map sensors, map adapters, wiring patches)
  • EBCS’s
  • Gauges, pods, all necessary hardware
  • Injectors
  • And more, depending on the overall power output and goals with the car!!! Contact our sales dept. for more details!!!
Specialty pricing for tuning of products if purchased through our sales dept!!!
-Specialty install pricing with recommended kits!!!
-Specialty tuning pricing with recommended kits!!!
-PM me for amazing pricing on your engine management needs
- MANY MORE INSTALL SPECIALS GOING ON! JUST ASK!
  • Injectors
  • Fuel Pumps
  • Turbo Backs
  • Intakes
  • Full Stage Packages
  • Group N Mounts
  • Suspension Components
  • Turbo kits
  • and MANY MANY MORE!
Dyno Tuning with Jorge w/ EMS - $225 per hour (AP tunes estimated at 1 to 1.5 hours)
Dyno Tuning with Jorge w/ Open Source - $225 per hour (estimated at 1.5 - 2 hours)
Dyno Baseline - 2 wheel drive, 3 pulls with wideband o2 AFR printout - $80
Dyno Baseline - 4 wheel drive, 3 pulls with wideband o2 AFR printout - $110
Dyno Rental - 2 or 4 wheel, unlimited pulls with wideband o2, priced per hour - $140
P&L Motorsports has the best pricing on all products from Kelford cams to Deatchwerks Injectors!
Here’s a list of just some of the products that are on HUGE discounts from anyone else!
GET UP 25% OFF ON THESE SELECT PRODUCTS!!!
• ACT
• AEM ELECTRONICS
• AEM INTAKES
• AEROMOTIVE
• APEXI
• APS
• ARP
• AUTOMETER
• BREMBO GT
• BLOUCH
• CARBONETIC
• CARRILLO
• COMETIC
• COMP CLUTCH
• DBA
• DEATCHWERKS
• DEFI
• DEI
• EIBACH
• EXEDY
• GATES
• GT SPEC
• HKS
• INGALLS
• INJEN
• JE-SRP
• K&N
• KELFORD
• KONI
• KOYO
• KW
• MAHLE
• MISHIMOTO
• MOROSO
• NGK
• PAUTER
• PRECISION
• PROGRESS
• QUAIFE
• RAYS
• SAMCO
• SPARCO
• SPT
• SUPERTECH
• TIAL
• TURBO XS
• TURBONETICS
• VIBRANT
• WALBRO
• PLUS TIRES, WHEELS, BODY PARTS AND INTERIOR!
And many more!
Give me a ring, shoot me a pm or even send an email and I’ll get back to you with the best pricing!
Mark@pandlmotorsports.com
- Mark
P&L Motorsports Inc. is offline
Old 10-28-2009, 06:01 PM   #2
MF-DIF
Member Sales Rating: (32)
Member#: 62197
2002 WRX, 2004 GTO
2000 SV650N
These are good prices. Will be seeing you to winterize my car!
MF-DIF is offline
Old 10-28-2009, 06:10 PM   #3
dsolis
Member Sales Rating: (36)
Member#: 121775
how much for a Walbro fuel pump?
dsolis is offline
Old 10-28-2009, 07:06 PM   #4
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Your looking at 175.00 installed.
-Mark
__________________
[B]P&L Motorsports[/B]
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 10-28-2009, 07:08 PM   #5
dsolis
Member#: 121775
how about just the FP alone shipped?
dsolis is offline
Old 10-28-2009, 07:51 PM   #6
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Zip?
-Mark
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 10-28-2009, 07:58 PM   #7
PSI_XTC
Member Sales Rating: (7)
Member#: 123386
'12 IS-F
'08 Saab 9-3 TurboX
Does Jorge do E85 tunes?
PSI_XTC is offline
Old 10-28-2009, 07:58 PM   #8
dsolis
Member#: 121775
dsolis is offline
Old 10-28-2009, 08:53 PM   #9
eurospek
Member Sales Rating: (20)
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
How much for just balancing wheels? My winter tires are already on a second set of stockers, except some tape-on weights went missing at the end of last winter.
eurospek is offline
Old 10-28-2009, 11:51 PM   #10
Dave_zok
Member Sales Rating: (19)
Member#: 225034
2006 STI
does the timing belt need to be changed on an 06 STI for the 60K service, or is it only at the 90k.
Dave_zok is offline
Old 10-29-2009, 01:35 AM   #11
Jasoncor
Member Sales Rating: (13)
Member#: 195934
WTB 2007 black sti
when does this sale end?
Jasoncor is offline
Old 10-29-2009, 02:20 AM   #12
STiProsDoc
Member Sales Rating: (6)
Member#: 158495
2007 STi OBP
Phatbotti tuned on E85
-Mark
Do I need to get retuned with the addition of the FP?
STiProsDoc is offline
Old 10-29-2009, 04:01 PM   #13
stoke
Member Sales Rating: (12)
Member#: 164513
2001 2.5RS+EJ20+VF34
'13 WRX Special Ed
PM'd you last night about tuning services.
stoke is offline
Old 10-29-2009, 04:01 PM   #14
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Of course, you would need to sit through his speech about it and then you're set.
-Mark
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 10-29-2009, 04:05 PM   #15
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
It'll depend on mods and how the car reacts to the mod. To tell you from a safe and reliable perspective, yes, you should tune it. Subaru's need to be tuned after every mod performed to them. You can't throw on a MBC, FMIC, Cams, Intake, TBBE and call it a day as you can with that other tuner car out there...coughevocough. You still need to tune them but subies are much more touchy.
-Mark
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 10-29-2009, 04:05 PM   #16
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Whenever I want, probably until the last snow fall, or spring solstice.
-Mark
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 10-29-2009, 04:09 PM   #17
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
It's not necessary to change it bu that also depends on you're driving style. If a normal driving style is at 90K then what would a rowdy one be at? I'd say you can think about it especially if you have the opportunity to do it (even at such a low price you might as well).
If you ask Subaru then they'll say 90K, if you ask a drag racer they'll tell you every 10 to 15 passes. Every car is different and some people just do it at 60K for piece of mind.
-Mark
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 10-29-2009, 04:10 PM   #18
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Normally the cost is 10.00 dollars a wheel bu the discounts brings it down to 8.00 dollars a wheel.
-Mark
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 10-29-2009, 04:23 PM   #19
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
91320
92.50 bucks with the install kit.
-Mark
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 10-29-2009, 06:01 PM   #20
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
18.00 bucks for all four.
-Mark
Do you guys use the tape on weights or the ones that clip on the lip of the wheel?
eurospek is offline
Old 10-29-2009, 06:08 PM   #21
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Both, depends on what the wheel will take or what you'd want to put on there. The only reason the stickies don;t stick is because the person didn't heat it up (I am also a tech of multiple backgrounds, crew chief or lead bay tech at Discount tire) so I make sure it get's done right here.
-Mark
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 10-29-2009, 07:16 PM   #22
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
Great, when does this special pricing end and free wheel swap? Realistically I would love to get them re-balanced and swapped out with my current wheels in one visit, as I'm too lazy to swap the wheels myself.
eurospek is offline
Old 10-29-2009, 07:18 PM   #23
cjx17
Member Sales Rating: (40)
Member#: 108550
2008 WRX 5-Door 4EAT
Lightning Red
any chance you guys got any decent all season tires in stock 225/45/17?
cjx17 is offline
Old 10-29-2009, 08:58 PM   #24
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
I have some RE0960AS for 610.00.
-Mark
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 10-30-2009, 03:46 PM   #25
plmrass
Member Sales Rating: (9)
Member#: 94109
2006 WRX Wagon
VF 43 307 hp 360 tq
How much to swap turbo, tmic, turbo back with gaskets back to stock?? Thanks Jeff
plmrass is offline
Closed Thread
P&L Winter Special!!!! ECU and Tuning!!! P&L Motorsports Inc. Engine Management 0 11-16-2009 07:07 PM
P&L Winter Special!!! Drivetrain P&L Motorsports Inc. Drivetrain 0 11-12-2009 07:33 PM
P&L Suspension Winter Special!!! P&L Motorsports Inc. Suspension/Brakes/Handling 0 11-11-2009 06:44 PM
P&L Suspension Winter Special!!! P&L Motorsports Inc. Suspension/Brakes/Handling 0 11-11-2009 06:42 PM
P&L Winter Special!!! P&L Motorsports Inc. Engine/Power/Exhaust 0 10-29-2009 06:29 PM
