Old 10-28-2009, 07:07 PM   #1
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
Default sohc intake/wrx injectors
which O rings do I need. I have heard rs tops for the fuel line rail and then wrx bottoms for the block.
Is there 2 o rings on the bottom?
2000 rst
cheers.
freeride is offline   Reply With Quote
Old 10-28-2009, 07:15 PM   #2
VIsubi
Member#: 187834
06 2.5i impreza
Red
um why not just order the 550cc top feed from rallitek for a good price that will work PnP your trying to make a hybrid injector which I see issues down the line...
VIsubi is offline   Reply With Quote
Old 10-28-2009, 10:33 PM   #3
legacydreamz
Member#: 92423
still locked in freezer
cuz the wrx injectors can be modded to put out a lot more than 550cc and can be had cheaper?
ummm, i dont know...
legacydreamz is offline   Reply With Quote
Old 10-28-2009, 10:54 PM   #4
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Actually, plugging WRX topfeeds into an RS works perfectly well. If you only need fuel that can be provided by practically free injectors, why buy anything else?
OP, I can't recall the exact O-ring combo you need, but if you ping Rallitek they'll be able to tell you.
BAN SUVS is offline   Reply With Quote
Old 10-29-2009, 12:29 PM   #5
ShlowShtuph
Member#: 188240
95.5 Impreza
MAaarooooon
Call Rallitek and tell them you need the o-ring kit for wrx injectors in an RS manifold. I'm using aftermarket rails so I can't say anything about the top but I had to use that kit for my bottom rings. good luck.
ShlowShtuph is offline   Reply With Quote
Old 10-29-2009, 12:44 PM   #6
Odyknuck
Member#: 192866
2006 Impreza
The 2000 uses the air assist Injectors so the ports are longer. I ended up using 2 of the Raliteck "O" rings on the bottom and the stock "O" rings on the top of my aftermarket fuel rails. Something to think about is because the WRX Injectors are shorter and are farther up into the Manifild the fuel hits the side of the hole and tends to puddle. I notice popping when I let off the throttle from unburnet fuel. I am assumming this is the cause. The Injectors shut off however the Ignition does not.
Odyknuck is offline   Reply With Quote
Old 10-31-2009, 06:17 PM   #7
freeride
Member#: 49783
SRP/white
I had some o rings from subaru but wasn't sure which ones I should use...all rs or all wrx..
Old 11-01-2009, 07:14 AM   #8
Safir
Member#: 3873
. Paradise is
like Disney with hookers
WRX bottom and RS top makes the most sense to me. if you have all of them on hand, why not just try a few combinations and see waht works?
Safir is offline   Reply With Quote
Old 11-01-2009, 07:42 PM   #9
VIsubi
Member#: 187834
06 2.5i impreza
Red
Cause being cheap with your car usually results in an expensive job afterwards.Unless your sending them off to flow more not a wise thing to do it yourself. Also why would you use old used injectors instead of rebuilt or brand new ones..the idea still hasn't sunk in yet maybe its me but I'll stick with brand new never used and warranty...
Old 11-01-2009, 10:01 PM   #10
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Um, you've got used injectors every time you run your engine after the first time they open and close. And if X injectors have the flow you need for your power levels, it's not being cheap. Why spend $400 for injectors when a set you can get practically for free does the job perfectly well?
RS SOHC and WRX Intake manifold differences Odyknuck Normally Aspirated with bolt-on Forced Induction Powertrain 11 02-03-2009 05:25 AM
Early SOHC intake manifold bolt to phase 2 SOHC heads?? Will ECU work with cam sensor ciper Normally Aspirated Powertrain 7 08-26-2008 05:35 PM
FS: SOHC 2.5 intake manifold, injectors, fuel rails, throttle body t3hWIT Tri-State Area Forum 1 12-12-2005 09:40 PM
SCAM - WRX Block & Heads, COBB GC8 Intake, RC & WRX Injectors & more!! Free too!! blaznc Private 'For Sale' Classifieds 59 02-19-2005 01:58 AM
intake manifold/injectors from SOHC EJ25 couldnthinkaone Private 'For Sale' Classifieds 0 08-11-2004 02:13 PM
Message Board Statistics All times are GMT -4. The time now is 07:20 PM.
