Old 10-29-2009, 01:36 PM   #1
dans04wrx
Member#: 149689
Default Tightening Power steering belt & AC Belt
Hey Guys, i know it probably easy to do. I need to tighten these to belts. Anybody have any detailed info on how to do it with hopefully pictures? Is it in the manual?
Thanks
dans04wrx is offline   Reply With Quote
Old 10-29-2009, 02:19 PM   #2
Badler
Member#: 133597
Take off alternator cover. Locate PS pump on passenger side front. There is a long bolt going vertically. That adjusts the tension. There is a horizontal bolt below this. That is the lockout or whatever you want to call the one that keeps it tight once adjusted. Loosen that one first. Then go to the vertical one and tighten or loosen until you get desired belt tightness. Re-tighten the lockout bolt. Replace alternator cover. Have a beer?
Badler is offline   Reply With Quote
Old 10-29-2009, 02:30 PM   #3
dans04wrx
Member#: 149689
wicked, thanks bro. Same for Ac but other side?
Old 10-29-2009, 04:56 PM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
A/C has an idler pulley below it, loosen the idler pulley first, then loosen the belt with the long bolt going through its bracket.
rougeben83 is offline   Reply With Quote
Old 10-30-2009, 09:53 AM   #5
Badler
Member#: 133597
Whoops. Meant a/c, not PS pump but I'm sure you figured it out.
Old 12-31-2014, 01:19 PM   #6
andrewjt19
Member#: 336760
Guys, thanks this helped me tighten my power steering pump. But how can I tighten the Air Conditioning belt. I see the Idler screw below it but that didn't seem to do anything to the tension of the belt. Maybe I'm looking at the wrong thing
andrewjt19 is offline   Reply With Quote
Old 12-31-2014, 09:05 PM   #7
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
For the AC you loosen the nut in red (ac idler pulley), then you loosen/tighten the bolt in yellow
to adjust the tension. When the tension is good, re-tighten the bolt in red.
fastnoypi is offline   Reply With Quote
Old 01-01-2015, 02:33 AM   #8
andrewjt19
Member#: 336760
Thanks for the reply... This explains it all. Hopefully it can help someone else too.
Old 01-21-2015, 04:01 PM   #9
Vsestalopowe
Member#: 411474
Itís really great posts.
Vsestalopowe is offline   Reply With Quote
WTB: 2004 subaru TS AC Condensor, Power Steering Pump & Fog Lights. themadeguy Private 'Wanted' Classifieds 2 10-20-2009 08:33 PM
WRX STi Gates Racing Power Steerring and Alternator Drive Belt New tolishel Engine/Power/Exhaust 0 07-22-2009 06:28 PM
Power Steering Pump / Alternator / AC compressor Chandy69 Engine/Power/Exhaust 33 06-02-2008 07:18 AM
Subaru WRX Alternator & AC Belts (May fit other Subaru models also) mav1c Engine/Power/Exhaust 9 12-02-2007 03:21 AM
