Old 10-30-2009, 01:06 PM   #1
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Default Mick's Antilag setup - Video included
Repost from Built Motor Forum as I thought PPB would like it as well.
Antilag information with video of it in operation.
Build Details (It's my backup block actually). Darton sleeved open deck 2.5L with Wiseco piston, Helix rods (super cheap!), Cobb Tuner crank (was not cheap), ACL Race bearings, STi heads with stock sized Supertech black nitride intake and inconel exhaust valves, Kelford 272 intake, 264 exhaust cams. DW1100 injectors, 044 fuel pump, GT35R Turbo, Oil dry sump. Engine is making 465 WHP, 430 TQ at 22 psi and E85.
The Autronic EM controls the Antilag but you still need some way of either opening the throttle or bypassing the throttle when ALS is enabled. I went the bypass route and connected two dash 12 hoses under the throttle.
The other side of the hoses connect to solenoids that are activated by the Autronic. Its not perfect but the IAC on it's own does not generate enough bypass air.
With ALS enabled the car will make about +1 psi at high idle (3200) and 7 psi between 4000 and 5000 with just free rev'ing. The ALS still needs some more tuning, that and I still need to install either a vac assist brake unit bypass or the electric vac pump that I have sitting in my garage.
The off to on throttle transition needs some work as well as the retarded ignition used for the ALS makes the car a little jittery going back on throttle. I just need to get back on the track (in 2010) and tune the transitions. Their is close to no turbo lag going from off to on throttle, it's pretty scary as the power onset is amazing.
You can reduce the bangs and pops (which is hard on the valve train) when ALS is enabled but for this video that would have been boring.
Hope you enjoy!
Video (it's shot in the dark for a reason) (~4M)
http://www.mickandsarah.com/Movies/m...-ginge-als.wmv
Same Video in a more HD format (~38M)
http://www.mickandsarah.com/Movies/m...nge-als-HD.wmv
mick_the_ginge is offline   Reply With Quote
Old 10-30-2009, 01:12 PM   #2
DJSuperSoul
Member#: 120004
2xx8 STI
grey
somebody call the cops, we have gunfire over here!
DJSuperSoul is offline   Reply With Quote
Old 10-30-2009, 01:43 PM   #3
mpj_becks
Member#: 6265
That's awesome Mick, have you run with it on on track yet?
Mike
mpj_becks is offline   Reply With Quote
Old 10-30-2009, 01:51 PM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Sounds downright evil! I too would like to know if you have used it on the track, and if so, how you find driving with it in such a setting.
jigga is offline   Reply With Quote
Old 10-30-2009, 01:52 PM   #5
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
your car hates you
BONFIRE074 is offline   Reply With Quote
Old 10-30-2009, 02:08 PM   #6
jutes85
Member#: 127232
E92 M3
98' Foz
jutes85 is offline   Reply With Quote
Old 10-30-2009, 02:10 PM   #7
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
Oh sweet jesus! I love it. I'd love to see the driving results and the lifespan of the turbo.
quadtard is offline   Reply With Quote
Old 10-30-2009, 02:25 PM   #8
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
MP4 version for MAC users
http://www.mickandsarah.com/Movies/m...ge-als-MP4.mp4
Mike
I used this twice on the track at the start of the year (other engine). I exited most corners sideways in the dry, screaming like a little girl. Even without the pops/bangs the turbo onset if very quick using Antilag. This is also when I found out that if you don't get any vac you don't have any brakes due to the vac assit unit. I have a electric vac pump to resolve that, then I can use it on the track again.
What do you mean?? raw fuel exploding in the exhaust system maybe bad for my car It's supposed to be hardest on the valve train and turbo. The turbo compressor surge you get can't be good for the turbo as well as the heat on the exhaust side.
I don't plan on running it all the time.
I just thought their are not many cars with Antilag setups so I thought I would share.
Old 10-30-2009, 03:19 PM   #9
CatfaceType-R
Member#: 81102
your the man mick, thank's for sharing
CatfaceType-R is offline   Reply With Quote
Old 10-30-2009, 05:00 PM   #10
jays05
Member#: 78165
05 STI 35r + e85
Oh man, I would totally use the antilag in traffic and act like nothing's wrong
jays05 is offline   Reply With Quote
Old 10-30-2009, 05:29 PM   #11
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
I'm sure it would quickly put off those annoying tailgaters who thinks it fine to be 2 foot off your bumper, while on their mobile phones, eating and reading a newspaper.
Old 10-30-2009, 07:19 PM   #12
nxttruck2002
Member#: 90879
Someone throw it on Youtube!
nxttruck2002 is offline   Reply With Quote
Old 10-30-2009, 08:04 PM   #13
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Old 10-30-2009, 08:17 PM   #14
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I can just imagine the look on an officer's face as he walks up to your window and taps it, while you are sitting there in idle with anti-lag banging away
Old 10-30-2009, 08:21 PM   #15
twizhimself
Member#: 58294
2004 WRX / 1998 Foz
SoCal F4 #20 / Area1320
HOLY JESUS!
twizhimself is offline   Reply With Quote
Old 10-30-2009, 08:23 PM   #16
DJSuperSoul
Member#: 120004
2xx8 STI
grey
mick, you need to fabricate a marshmallow holder. nothing like smores cooked over c16
Old 10-30-2009, 08:33 PM   #17
subenerd
Member#: 72630
2004 STi
God that is wicked!!
But can someone explain how the process works (in laymen terms). I don't understand from the pictures.
subenerd is offline   Reply With Quote
Old 10-30-2009, 08:46 PM   #18
wuuusaa
Member#: 92894
2015 Wrx
When it came to putting a set of good rods in your car... Why in the sam hell did you choose Helix rods for your build???
Old 10-30-2009, 09:03 PM   #19
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
This is my backup block, used when my main block is out of action which it is at this time due to a flywheel bolt failure. My main block is a darton sleeved closed deck 2.5L, Pauter rods, CP pistons, Cobb crank, V7 large ported heads.... blah, blah, blah.... I'm in the process of rebuilding this one.
When I rebuilt this block I needed to do it on the cheap, thus the choice of Helix no name rods, Wiseco pistons. I had the rods modified to work with this block as it's been surfaces 4 times and we had to cut the case halves and line hone to correct the main clearances. The rods were shortened so didn't want to do that to a good set of rods.
Hey, they seem to be working so far
Basically you retard the ignition and cut it once in a while to shoot burning and raw fuel into the exhuast system. There is continues to combust and keep the turbo spinning.
Old 10-30-2009, 10:21 PM   #20
BamBooI
Member#: 10945
2006 Evolution IX
So sick, but cannot be good for valvetrain and turbo.
BamBooI is offline   Reply With Quote
Old 10-31-2009, 12:33 PM   #21
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
i want.
Dubstar112 is offline   Reply With Quote
Old 10-31-2009, 04:41 PM   #22
weebs
Member#: 195727
Originally Posted by Dubstar112 View Post
i want.
weebs is offline   Reply With Quote
Old 10-31-2009, 09:27 PM   #23
Badler
Member#: 133597
Sick as usual Mick. I wonder about the muffler lifespan. Looks like it is going to explode!
Badler is offline   Reply With Quote
Old 11-01-2009, 04:53 AM   #24
ocean
Member#: 163259
2007 UGM STI
307 hp / 317 tq
I'm familiar with how bad anti-lag is on the turbo lifespan, but how is it bad for the valvetrain? Huge backpressure on the closed exhaust valves when the unburnt fuel explodes in the headers / turbo housing? I'm just curious because I've never seen the valvetrain mentioned with respect to an anti-lag system.
Also, I'm jealous and really want a setup like this on my car, despite not really tracking it...ever. Can't help but like the huge flames out the back
ocean is offline   Reply With Quote
Old 11-01-2009, 10:47 AM   #25
carnz-pj-410
Member#: 110994
Old japanese cars
are the best
That video was badass
carnz-pj-410 is offline   Reply With Quote
Mick's Antilag System - With Video mick_the_ginge Built Motor Discussion 24 11-18-2009 10:28 AM
A/F gauge acting srtange, video included Hyper Electrical & Lighting 8 06-06-2003 07:33 PM
WRX's Have this happend to you on the Freeway? Video includ. IMPEXRALLY Off-Topic 24 04-06-2003 09:30 PM
A couple more Summit Point videos, including the Ferrari F355 Patrick Olsen New England Impreza Club Forum -- NESIC 2 10-25-2001 08:28 PM
My 18" wheel/tire setup (pics included!) Force[FED] Brakes, Steering & Suspension 37 05-09-2001 11:56 AM
