Alaskan Impreza Club
Old 10-30-2009, 03:06 PM   #1
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Default Recent TS-Tune Dyno 04 STI, 19PSI-20g, Pump Gas
TurboSetch is offline   Reply With Quote
Old 10-30-2009, 03:23 PM   #2
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
FYI--- He wanted to go fast....... but be on the conservative side.
Old 10-30-2009, 03:26 PM   #3
AKLGT
Member#: 85199
2012 turbo rollersk8
EvolvedAK's hood ornament
very nice. on a full can of Torco?
AKLGT is offline   Reply With Quote
Old 10-30-2009, 03:30 PM   #4
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
I think thats what he said. I never saw any knock except a small -2 correction on a shift but that only happened once and it was outside of the danger zone.
The 20g is an easy to live with turbo it seems. The MAF sensor doesn't have much left so he needs a bigger MAF tube for much more up high. What was nice is the dyno agreed with the measured g/s on the MAF. Typically with these cars the measured air in g/s seems to = WHP.
Old 10-30-2009, 03:42 PM   #5
AKLGT
Member#: 85199
I have no idea what I was running on mine. the tuning wasn't done but I'm sure it was pretty high. my MAF was able to handle a lot and my very last runs in the car was on 22 psi. Tuner planned to turn that up to about 26 psi by the time he was done
Old 10-30-2009, 03:53 PM   #6
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Yeah maybe you had a larger MAF then. Didn't you use the Perrin?
The max measurable g/s on a stock 04 STI is 348.45 g/s. On an 08 STI its 383.89 so you could in theory make near 400WHP peak. You can over shoot a MAF sensor but essentially you just run it real rich towards redline since you have no resolution anymore. You can do some hacks/tricks in the ECU but I personally won't do that for someone.
Old 10-30-2009, 03:57 PM   #7
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
26PSI on stock internals won't last long, good thing you would have been on a built motor. I run 24psi from time to time on my 05 STI, it seems to take it but I'm about to swap out the motor so I don't care if she blows.
This guy I posted the dyno for can do 21psi and still stay on the safe side as long as we keep the fuel a little rich and the timing down. He is happy with what he has so I'm glad about that.
Old 10-30-2009, 04:11 PM   #8
AKLGT
Member#: 85199
no, AMR intake and AMR TMIC. both the largest on the market. plus yes, built motor could handle the 26 psi.
and I ran 21-22 psi on my LGT and also on my stg 2 STI.
*edit* only with Torco, not on our 90 crap pump!
Old 10-30-2009, 04:38 PM   #9
Brando5185
Member#: 189926
2006 GC 5.7L
I think he only uses 1/3-1/2 can of torco per tank. :-)
Brando5185 is offline   Reply With Quote
Old 10-30-2009, 08:13 PM   #10
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Well there you have it. I have a few more Dynos to post up and I am going to try and do before and afters where I can. A lot of this work though is fresh builds or upgrades so its impossible to do a before run. Best comparison would be to stock.
Element Tuning GT65 Bolt On, Hydra, [email protected] psi, 07 STI 2.5 Pump Gas Element Tuning Proven Power Bragging 15 06-16-2010 01:45 PM
The 20g pump gas thread khyree05 Proven Power Bragging 52 04-02-2010 12:26 AM
Element Tuned Hydra, Cosworth, Intake, 503 whp pump gas Element Tuning Proven Power Bragging 46 10-08-2009 07:16 PM
ICS Project '08 STI - new dyno best - 529 WHP on Pump Gas & Meth ! Dyno Flash Proven Power Bragging 52 02-29-2008 09:03 AM
Holy butt dyno Batman...500 whp on pump gas!!! Hydra+Aquamist bboy Proven Power Bragging 57 05-02-2006 06:19 PM
