Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Interior/Dressup/Audio & Security
Old 10-30-2009, 03:19 PM   #1
IA Performance
Vendor Sales Rating: (61)
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Default JDM Trim, RADIO Harnesses and Adapters, Tweeter Kits and much more for 93-2011 models
The inception of our Subaru Speaker Adapters began over 7 years ago. Through the years we refined the kits as well as expanded our audio accessory line up. Below you will find the most complete list of Subaru speaker installation products ANYWHERE. We've been published across the internet as well as Magazine print on several occasions. Each piece is designed specifically for your Subaru. Simply click on the photos to obtain more information. Feel free to post any product questions you may have directly in this post, via PM, Email, AIM or phone.
[email protected]
520-882-2821
sc12seconds4 - AIM
Adapter Plates These will make your install a SNAP! We've installed speakers in as little as 1 minute per door with the aid of our adapter plates. No sense in wasting a whole weekend 'trying' to make the speakers fit, do it right the first time!
DIN Pockets
Universal DIN pockets, fits 93-07 Subaru models, all. $15.99
Double DIN Fill Kit, fills the gap around the radio. Fits 08+ Impreza, Forester models. DIN pockets, fits 93-07 Subaru models, all. $29.99
JDM Double DIN Panel, Direct Snap in piece that fits beautifully around your Double Din Aftermarket radio. Fits all 08+ Subaru Impreza models and 2010+ Forester. $96.20 each
STi Silver/Black
Light Silver (2008 WRX and Forester)
Dark Silver
Front or Rear Kits. Starting at $15.99
Combo Kits + 10% OFF!! Starting at $41.39
Tweeter Options
08/10 Impreza Tweeter Mounts. Hard to find, but we have tons of them at an insane price of $13.99!!! This is 100% OEM, fits perfectly every time.
02-07 Universal Tweeter Mounts. These bad boys will allow you to mount virtually any tweeter in the 02-07 Impreza chassis.
Radio Harnesses
Universal, fits all Subarus 1993-present. This plugs into your factory wiring harness and then allows you to wire your aftermarket headunit to it. No need to cut a single factory wire!
__________________
IA Performance is offline   Reply With Quote
Old 10-30-2009, 03:19 PM   #2
IA Performance
Member#: 25194
Dark Gray
Factory NAV Equipped:$12.50
Factory nonNAV Equipped (am/fm/cd only):$12.99
Door Bezels
02-04 Impreza Front and Rear (same part for either door)$7.99
05-07 Impreza Front Bezels w/ tweeter honey comb- $10.77
05-07 Impreza Rear Bezels $7.35
Nuts, Bolts, and other Misc items:
Nuts
100% Drop in nylon nuts. Simple press these into the square OEM holes and you have a perfect place to screw in to.
Replacement Door Pins. $4.00These are great for replacing old worn out door pins. If you door panel keeps popping loose then toss a set of these in there and your problems will vanish. You can have the panel flush, or you can even space it out to clear your aftermarket speakers.
__________________
Old 11-06-2009, 05:26 PM   #3
Kiet
Member#: 212745
I have 5.25" comps I need to install into an 09 wrx prem. What adapters would I use? I'm looking through the site provided and I don't see the front adapters sold by themselves. Only in the set.
Kiet is offline   Reply With Quote
Old 11-06-2009, 08:34 PM   #4
IA Performance
Member#: 25194
Dark Gray
Kiet- Here you go:
http://www.iaperformance.com/product...roducts_id=235
Do you happen to know the cutout diameter and mounting depth of the speakers you wish to use?
Stephen
__________________
Old 11-06-2009, 09:59 PM   #5
Kiet
Member#: 212745
Originally Posted by IA Performance View Post
Kiet- Here you go:
Stephen
Thanks! I will also be needing the tweeter mounts from your site that I saw. Will be ordering soon.
Here is the info I pulled off of Polk Audio's website.
Driver Mounting Depth Top Mount 2-5/16" (5.87cm) Bottom Mount 2-7/16" (6.19cm) Grille Height 7/8" (2.22cm) Cut-out Driver Cut-out Diameter 4-11/16" (11.91cm) Tweeter Cut-out Diameter 2-1/16" (5.24cm)
Old 11-07-2009, 12:24 PM   #6
IA Performance
Member#: 25194
Dark Gray
Thank you for the sizing information. Those should fit nicely with our 5.25" front adapter plates referenced in the link above. Items are in stock and ready to ship.
Stephen
__________________
Old 11-15-2009, 01:39 AM   #7
Kiet
Member#: 212745
Do I have to order the tweeter pods if I want to use aftermarket tweeters? Can I use the stock tweeter pods? I haven't had the time to pull them off and see..
Old 11-15-2009, 12:39 PM   #8
East Coast Scooby
Member Sales Rating: (17)
Member#: 123642
2003 2.35L Wagon
East Coast Scooby is offline   Reply With Quote
Old 11-15-2009, 12:41 PM   #9
IA Performance
Member#: 25194
Dark Gray
Kiet- You should be able to pull the 08-09 stock tweeter pods apart and make the aftermarket tweeter fit. Have some silicone handy just in case the plastic retaining clip does not clip back on.
Stephen
__________________
Old 11-15-2009, 07:59 PM   #10
Kiet
Member#: 212745
Stephen
Thank you very much sir. I'm ordering the speaker adapters right now.
Old 11-17-2009, 11:53 PM   #11
IA Performance
Member#: 25194
Dark Gray
Happy to help any time
Stephen
__________________
Old 11-24-2009, 12:06 PM   #12
IA Performance
Member#: 25194
Dark Gray
PMs have been replied to.
Stephen
__________________
Old 11-30-2009, 07:57 PM   #13
IA Performance
Member#: 25194
Dark Gray
1 JDM Double Din bezel left in stock as of today. We have a large stock on everything else.
Stephen
__________________
Old 12-01-2009, 10:16 PM   #14
orwrx
Member Sales Rating: (102)
Member#: 33869
2002 wrx
rally blue
Do I still need the 02-07 Universal Tweeter Mounts on MY02 WRX when I already have the factory one by the door panel?
orwrx is offline   Reply With Quote
Old 12-02-2009, 12:04 AM   #15
Kiet
Member#: 212745
Are the tweeter pods the same design as the stock 09 tweeter pods? I took apart my stock ones and I already had stock tweeters in there which I took out and replaced with my aftermarket ones. I had to trim the stock ones and they still don't sit correctly.
From the looks of the pics on the site it looks like the ones you are selling are the exact same thing as the stock ones I have. Is that so? I don't want to order a pair only to find out they're the same thing as stock..
Old 12-02-2009, 09:15 AM   #16
IA Performance
Member#: 25194
Dark Gray
orwrx- no, you may reuse your factory tweeter bracket. Simply unscrew the factory tweeter and install your aftermarket one. Money saved
Kiet- That is correct, we offer the 100% OE pods. These would be the same units that you have currently. Have you considered cutting more of the plastic on the back side and then use clear silicone caulking to adhere the tweeter to the pod? The nice thing about this setup is that you do not have to use the factory screws and tie down plate for the tweeter. This should allow you to get the pods to fit nicely once again. Plus silicone caulk (bathroom type stuff) is pretty easy to remove if you opt to take out the aftermarket tweeters. HOpe this helps.
Stephen
__________________
Old 12-02-2009, 10:09 PM   #17
Kiet
Member#: 212745
I'll try and do some more cutting of the plastic. I did however screw the back piece back on without using the bottom screw because I cut that screw hole off. I used a glue gun and glued the tweeter down as far as I could. If I don't use the removable back piece (the piece held on by the 3 screws) then there is a gap on the side of the tweeter pod and it won't stay on the door by itself.
Old 12-02-2009, 11:32 PM   #18
IA Performance
Member#: 25194
Dark Gray
hmm, sounds like time to get out the dremel Be slow and precise, it will pay off in the end. Feel free to post of pictures too.
Stephen
__________________
Old 12-04-2009, 12:45 PM   #19
rizwan
Member#: 231780
How-to install a stereo in a 1993 Impreza?
rizwan is offline   Reply With Quote
Old 12-04-2009, 01:01 PM   #20
IA Performance
Member#: 25194
Dark Gray
Hello, I believe you want to post this question here:
http://forums.nasioc.com/forums/forumdisplay.php?f=25
This is a sales listing. The short answer to your question is:
Remove the dash surround piece for the radio, remove old radio, reuse the brackets on a new radio, wire, reinstall everything. For more details please visit the link above.
Stephen
__________________
Old 02-07-2010, 12:58 PM   #21
Arnie
Member Sales Rating: (5)
Member#: 1725
99 Subaru Impreza
GF silver
Are these guys out of business? Tried emailing and their website is down.
Arnie is offline   Reply With Quote
Old 02-08-2010, 09:08 AM   #22
IA Performance
Member#: 25194
Dark Gray
nope, our host company went down for a few days We're back up and running again. It will take until Wednesday to get caught up due to the outage. Thank you for your patience during this time.
Stephen
__________________
Old 02-08-2010, 11:30 AM   #23
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Oh great! I need 6 1/2" and 5 1/4" adapter rings.
Old 02-09-2010, 10:00 AM   #24
IA Performance
Member#: 25194
Dark Gray
Good news / Bad news:
6.5" are in stock
5.25 News:
IA Performance 5.25" speaker adapter applications have been put on hold while we change suppliers. A time projection of late February/ early March. There are no plans of discontinuing this product or any other items from our Speaker Adapter line.
Stephen
__________________
Old 03-22-2010, 01:53 PM   #25
IA Performance
Member#: 25194
Dark Gray
STi bezels are in stock, 4 while supplies last.
Stephen
__________________
STEREO Speaker Adapters, TWEETER Kits, radio harnesses and so much more~~~~~~~ IA Performance Interior/Dressup/Audio & Security 1 06-26-2009 05:06 PM
05 STi UTEC, Hydra Accessory Harness, UR CAI, Perrin, KB, Stock + Much more! LeeC MAIC Private Classifieds 33 12-07-2007 11:21 AM
2.0 Block And Much More For Cheap chia Private 'For Sale' Classifieds 0 07-26-2004 01:31 PM
I Have The 2.0 Block And Much More For Sale chia Private 'For Sale' Classifieds 0 07-14-2004 02:44 PM
13 More 02-03 Chargespeed Lip Kits and Full bumper kits and Ganador Mirrors! WorldOne Exterior/Styling 24 07-10-2004 07:34 PM
