Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Vendor Classifieds
Closed Thread
Old 10-30-2009, 05:09 PM   #1
RaceComp Engineering
Vendor Sales Rating: (30)
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default Racecomp Oct/NOV/SEMA sale with RCE suspension model search info!!( OHLINS SALE TOO)
Feel free to give us a call to talk about suspension options for your car. We're local to the area and can help out the local autocrosser or competitive time attack racer.
Racecomp Engineering Super Sport Street/Track Springs
The car is lowered 23mm in the front and 20mm in the rear for an even look.
Spring rates are an aggressive 295 lbs/in front and 275 lbs/in rear.
Great for auto-x, track days, and canyon carving.
$339 Shipped
__________________________________________________ ____________
Racecomp Engineering Black "Regular Guy" Springs
These springs are intended for both the daily driven street driver as
well as the autocross and track day weekend warrior. Using similar
spring rates as the extremely popular and successful RCE Yellow
Springs, but having a much more subtle/mild drop in comparison, these
are perfect for STi owners not looking for a ride height much lower
then stock, and yet are still looking for increased spring rates.
$339 Shipped
RaceComp Engineering Swaybars
Another option for GD Impreza owners looking for a swaybar set that
will work well with stock springs, lowering springs, or coilovers.
Specifications:
25.5mm physical diameter
4142 Chrome Moly
Heat treated and cold finished.
Ends are hot forged on a 125 ton press.
Front and rear adjustable.
Washer tabs on front and rear to prevent walking
The settings for the front are 25.5 and 28.5mm.
Rear are 25.5, 27.0 and 28.5mm. So you could run these and not have to
go to a bar that is actually 27mm thick.
$209 each OR $409/pair
RCE WRX Wagon Springs and Koni Inserts
$1099
free shipping!
A performance lowering spring with rates perfect for users with Koni
Inserts in Wagon strut bodies or Tokico D-Specs. Firm rates, not for
use with regular WRX Wagon struts. These aren't poser springs.
__________________________________________________ ______________
Whiteline Com C Front Strut Mounts
Group N level rubber, adds caster and camber, no change to ride height.
Extra +0.75 deg caster & -0.5 deg camber for potential +5.0 deg total
caster & -3.5 deg camber depending on vehicle.
$180 shipped
GTWorx Camber Plates
NOW AVAILABLE FOR ALL 2002-2009 IMPREZA AND
LEGACY
These camber plates are currently available for both coilovers and OEM
style fixed perch struts.
- Very low stack height
- .8 degrees of caster are built in to the camber plate, which helps
minimize dynamic camber loss in a turn for the camber challenged
Impreza chassis.
- Lightweight alloy housing using the same high quality PROVEN
pillowball bearing used in the popular Racecomp Engineering Camber
Plates
- Smooth, long lasting, and quiet operation
- Hardware is zinc coated stainless steel
- Each bearing is rated at 37,000 lbs radial and 7,730 lbs axial force.
$389 Shipped
__________________
512 Shaw Ct, Suite 104
Severn, Maryland 21144
410-846-5407
RaceComp Engineering is offline
Old 10-30-2009, 05:10 PM   #2
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Well in 2010 Racecomp Engineering will have a booth at Sema in Las Vegas. We intend on having a few models there to represent us and to engage in conversations with vendors about RCE products and hand out catalogs and brochures. For this we will now start our RACECOMP ENGINEERING 2010 Suspension model search !! Look for details very soon posted.
__________________________________________________ _______________
Racecomp Engineering Tarmac II Coilovers
Separate bump and rebound adjustability
500 lbs/in front and 400 lbs/in rear spring rates
Custom spring rates available
We ship these already assembled, with ride height preset and settings
set. Making installation an ease !!
$2649 shipped and assembled with Group-N
Front and Rear Mounts
$2999 shipped and assembled with GTWorx Front and Rear Camber
Plates
Racecomp Engineering Tarmac Zero coilovers
Built by KW Suspension in Germany to our specs, these use the same
high quality stainless steel corrosion resistant construction as our
RCE T2s.
The difference here is our Tarmac Zeroes have preset damping that
maximizes both performance and ride quality. This allows the end user
to just put them on and drive without worrying about playing with too
many adjustments. It also keeps them more affordable. Ride height is
still adjustable of course.
Linear spring rates:
400 lbs/in front
340 lbs/in rear
Front and rear helper springs included. Can be used with camber plates
or Group N strut top mounts.
04-07 STI and 02-07 Impreza WRX
1699.00 plus shipping.
RCE Kool Brake Kit
$399
This kit was designed to cool and vent the braking system, thus
reducing rotor temperatures. Initial testing at Summit Point Raceway
showed up to a 200 F drop in rotor temperature on a GD STi when using
aggressive pads. Testing was done with Pagid Blue RS-42, Pagid Yellow
RS-19 and the new RS-29 brake pads. Designed to work with both stock
STi rotors and any aftermarket 2 piece rotor.
The Kool Brake Kit includes 12 feet of high quality, motorsport grade,
high temperature hose far better then other options on the market.
There is no need to upgrade. Stainless steel hose clamps are also
included.
The RaceComp Engineering Kool Brake Kit is now exclusively offered in
dry carbon fiber to improve unsprung weight savings. The spindle ducts
are considerably lighter then the OEM dust shields that are replaced
during installation. The GR Kool Brake Kits are in production, look
for a press release soon!
__________________
410-846-5407
Old 10-30-2009, 05:11 PM   #3
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
SPECIAL NOTE: RCE sways for 2008+ Impreza STI are in FINAL STAGES of production NOW with an expected launch in early November.
---------GR SECTION----------
GR Impreza STI Parts
RaceComp Engineering “Regular Guy” Functional Lowering
Springs
Finally, a performance spring designed with function over form is
available for the latest Subaru Impreza STI. The Regular Guy
Functional Lowering Springs for the 2008+ Subaru Impreza STI are
designed as the ultimate performance spring upgrade for the newly
redesigned GR chassis.
Specfications:
5mm drop front and rear
320 lb/in front and rear
Shortened bump stops included front and rear (12mm shorter front, 18mm
shorter rear)
$359 Shipped
__________________________________________________ ______________________
RaceComp Engineering Tarmac II Clubsport Coilovers
These coilovers feature the same inox-line stainless steel corrosion
resistant construction as previous versions of KW suspensions. Spring
rates are 8kg front and 8kg rear. These are aggressively valved, 2 way
adjustable, performance coilovers. These are valved more aggressively
then the standard KW Variant 3's, yet still offer an amazing ride
quality not felt with other brands.
$2180 Shipped (Coilovers Only)
$2550 Shipped (Group-N Front Tops, STi Rear Tops-Fully Assembled)
$2699 Shipped (GTWorx Front Camber Plates, STi Rear Tops-Fully
Assembled)
Project New York Package
This was one of the first packages we ever put together for a GR
chassis STi. We were so impressed with it that we have continued to
offer it, now at a reduced price! This is the ultimate suspension
package for the street or the track. It includes:
-RaceComp Engineering T2 Clubsport Coilovers
-GTWorx Front Camber Plates
-Whiteline Roll Center Kit
-Whiteline Steering Rack Bushings
-Whiteline Anti-Lift Kit
-Whiteline Rear Camber Adjustment Kit
-Kartboy Pitch Stop Mount
-Cusco Front Lower Brace Type-2
-Cusco Front Strut Tower Brace Type-OS
$3595 Shipped
Call to inquire about adding parts to this package, such as swaybars
or custom spring rates!
Ohlins Sportline DFV Coilovers
Highly flexible damping range allows for comfortable street ride and
excellent track performance. A first for Ohlins Sportline on a Subaru,
these coilovers are dual height adjustable, allowing separate preload
and ride height adjustments.
*Includes front camber plates and rear pillowball top mounts
*Separate ride height and preload adjustment
*Spring rates are 500 lbs/in front and 400 lbs/in rear
*Custom spring rates and valving are available
$3250 Shipped
__________________
410-846-5407
Old 10-30-2009, 05:11 PM   #4
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
SPECIAL NOTE: RCE sways for 2008+ Impreza WRX( NON STI ) are in the works NOW for a late December launch and rear bar done in early November.
---------------------GH section-------------------------------------
09 Impreza WRX
You 09 WRX guys and gals are in luck....Myles recently took delivery
of his very own 09 WRX. Since he can't really leave the car alone, it
can only mean one thing: 09 WRX specific suspension parts are COMING!
Details here: http://forums.nasioc.com/forums/show....php?t=1798548
Swaybars:
Whiteline 22mm front adjustable swaybar - $175 shipped
Whiteline 20mm or 22mm rear adjustable swaybar - $197 shipped
Bushings:
Whiteline Anti-lift kit - $120
- adds caster
- firmer bushing, less deflection and dynamic alignment changes
- removes anti-lift
Whiteline Rear Camber bushings -
$137
- allows rear camber adjustment
Whiteline Rear Trailing Arm Bushing
- $80
Whiteline Front Control Arm Bushings - $40
Whiteline steering Rack Bushings -
$63
- reduces some of the stock sloppiness, less deflection,
improves steering feel. all around makes your car just feel a lot
better.
OR get our Whiteline bushing package. Give us a call.
Racecomp Engineering Tarmac II for 08 and 09 WRX
$1799 shipped
Racecomp Engineering has a long history working side by side with KW
Suspensions on many projects to serve and meet the demands of the
Subaru enthusiast driven market. KW Suspension has continually
impressed with their high quality construction, excellent valving, and
ease of use. Racecomp Engineering is excited to work with KW
Suspensions yet again to offer an excellent double adjustable coilover
at an affordable price to 2008 and 2009 Subaru Impreza WRX owners.
In stock and ready for delivery now!!!
CALL FOR SPECIALS ON T2's for 2008 WRX( non STI) assembled with Group-N front and OEM rear mounts for 2099.00 shipped.
__________________
410-846-5407
Old 10-30-2009, 05:11 PM   #5
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
--------JRZ--------------
JRZ RS Pro Coilovers from Racecomp Engineering
GTWORX is proud to offer the JRZ RS Pro coilover and
announce their new partnership with JRZ Suspension Engineering.
Intended for the dedicated time attack competitor, serious track day
enthusiast, or committed club racer, the JRZ RS Pro dampers are the
natural step beyond RCE’s popular Tarmac 2 coilovers.
These dampers are a 2 way adjustable damper with separate adjustments
for compression and rebound. Additional adjustments can be made with
adjustable gas pressure in the remote gas canisters. The gas canister
can also be fixed to the strut as a piggyback canister for easier
installation. Spring rates start at 650 lbs/in front and 550 lbs/in
rear, with custom rates available.
Features:
• 22mm rod strut, 16mm rod damper
• Mono tube
• Adjustable gas pressure
• piston sized for high performance
• street compliance valving
• precise canister
• large adjustment range
• Fixed hoses for easy mounting
• Steel piggyback
Valving is ideal for the track, yet compliant on the street through
the use of a progressive blow off system allowing stiff compression
while maintaining smooth response. The large adjustment range and
precise damping control with consistent, predictable settings allow
exceptional tuning of the chassis.
JRZ dampers come with unbeatable after sale technical and set-up
support from Racecomp Engineering and JRZ USA, which are housed in the
same building.
For more information,
please call 410-579-1501.
RCE Parts in Development
At RCE/GTWorx, we are constantly working to expand our line of
performance products. We have some exciting new products for the GR
chassis STi/WRX on the horizon, building upon our already successful
catalog. You can expect to see these products released very soon, but
for now here’s a preview of what’s to come!
RCE Swaybars
(GD swaybars pictured)
Using the knowledge we have gained in the process of developing our GD
swaybars, as well as extensive testing of the GR chassis, we are in
the final development stages for our GR swaybars! Made from heat
treated and cold finished 4142 Chrome Moly with ends hot forged on a
125 ton press, the bars are then powdercoated black for a durable,
rust-free finish. They feature washer tabs on the front and rear to
prevent walking, and include polyurethane bushings and lube. More
details and a full press release coming soon!
__________________
410-846-5407
Old 10-30-2009, 05:12 PM   #6
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
space.
__________________
410-846-5407
Old 10-30-2009, 10:32 PM   #7
sti robot
Member Sales Rating: (35)
Member#: 110932
2013 BRZ
^ ... the final frontier.
Ok, on to my question. On an 04 sti with RCE yellow springs how much camber do you think you could get with the Com C strut tops? I have Cusco plates right now and they will probably die soonish and if the camber provided by the Com C's is good enough I might use them.
Another question, could you use the Com C's with tokico d-specs?
sti robot is offline
Old 10-30-2009, 10:48 PM   #8
GTWORX.com
Vendor Sales Rating: (10)
Member#: 97303
2009 WRX and Boxster
Gray and Black
Com-C adds 1.0 camber over stock max camber. So about
-2.2ish.....
yes D specs.
Myles
__________________
GTWORX - 410-846-5633
- BILSTEIN- Cobb - WHITELINE- Kartboy - KW - AST - STOPTECH - SPARCO-JRZ
GTWORX.com is offline
Old 10-30-2009, 11:43 PM   #9
rallyracersti
Member Sales Rating: (13)
Member#: 147522
2015 wrx
Wrb
pm'd u
rallyracersti is offline
Old 11-14-2009, 02:46 PM   #10
rexster
Member#: 22863
2015 WRX Premium CWP
are the com c front mounts available for a legacy GT?
rexster is offline
Old 11-14-2009, 06:34 PM   #11
GTWORX.com
Member#: 97303
Gray and Black
not yet, but soon.
GTW
__________________
Old 11-15-2009, 05:56 PM   #12
vinnyd
Member Sales Rating: (22)
Member#: 148219
2013 Mazdaspeed 3
Liquid Silver
sale price on the ohlins struts or just the coilovers?
vinnyd is offline
Old 11-16-2009, 11:35 AM   #13
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Ohlins struts are 1999.00 plus shipping.....which coilovers?
Mw
__________________
410-846-5407
Old 11-19-2009, 02:56 PM   #14
GTWORX.com
Member#: 97303
Gray and Black
Default From our friends at GTWORX.............
NEW GTWORX by BILSTEIN OEM fitment SPORT SHOCKS for 08+ WRX !!
ACTUAL PICTURES NOT AVAILABLE YET
Manufactured by BILSTEIN Exclusively for GTWORX using SPORT VALVING matched for a forth coming NEW "YELLOWS",350/350 spring rate or Regular Guy lowering springs 320/320 rates for more of a OEM ride height.
Details:
Front:
Monotube, Gas, inverted struts.
NON DAMPING ADJUSTABLE.
For use with OEM springs or lowering springs and top hats.
Rear:
Monotube, Gas, shock absorber.
Adjustable sir CLIP for + 10 or -10mm rear height.
For use with OEM springs or lowering springs.
Shocks will come with dust covers and be powder coated.
869.00 plus shipping for SHOCKS ONLY!!
999.00 is MSRP.
Look for package deals for up and coming GH YELLOWS and BLACKS and SWAY BARS.
JANUARY 2010 RELEASE DATE.
__________________
Old 11-25-2009, 07:48 PM   #15
GTWORX.com
Member#: 97303
Gray and Black
Call Friday for special BLIZZACK Friday specials on unannounced parts !!
wickedy wacked sale prices and specials !
Myles
__________________
Old 11-26-2009, 09:28 AM   #16
rexworx
Member Sales Rating: (64)
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Did you folks redesign the GD front swaybar? I have the OG bar you have a pic in post 5.
But Ive seen more recent pics like in post # 1 it looks bent so its easier to get at the Motormount nuts.
rexworx is offline
Old 11-26-2009, 06:31 PM   #17
GTWORX.com
Member#: 97303
Gray and Black
We used the bent ones as the first round of prototypes that 8 people tested in early 2008. Final production bars are straight.
Myles
__________________
Old 02-17-2010, 04:02 PM   #18
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Closing thread. Ohlins FPS are no longer available. New thread coming soon.
__________________
410-846-5407
Closed Thread
Racecomp Oct/NOV/SEMA sale with RCE suspension model search info!!( OHLINS SALE TOO) RaceComp Engineering Suspension/Brakes/Handling 19 11-18-2009 03:22 AM
Racecomp rolls the clock back with 2007 prices!! 2nd Annual RCE Summer Sale !! RaceComp Engineering Suspension/Brakes/Handling 31 09-14-2009 10:43 AM
Racecomp rolls the clock back with 2007 prices!! 2nd Annual RCE Summer Sale !! RaceComp Engineering Vendor 'General Sale' Forum 33 09-02-2009 07:08 PM
This thread tastes like Texas Toast: RCE Suspension and Brakes BIG TEXAS SALE!!! RaceComp Engineering TXIC Vendor Classifieds 14 05-14-2008 08:15 AM
Wagon owners read here: HUGE SALE on RCE Wagon Springs + Koni Inserts! Overstock SALE RaceComp Engineering Suspension/Brakes/Handling 65 03-07-2008 02:50 PM
