Old 10-30-2009, 05:25 PM   #1
2006whitesti
Member#: 124311
2006 STi, 03WRX wago
10Tribeca,00 RS,99 Foz
Default Switching to Drive by Cable throttle body
Just wondering if this is possible on an 06? There just is not a big enough throttle body to not be a restriction. If anyone could point me in the right direction that would be great. Will be running AEM EMS.
Thanks in advance,
Dustin
2006whitesti is offline   Reply With Quote
Old 10-31-2009, 10:52 AM   #2
Nate8409
Member#: 44034
2006 Global Cooler
With a stand alone it should not be a problem. Just the mechanical stuff and then the TPS.
Only thing you are messing with is the DCCD. I don't know wiring if the DCCD receives its signals directly from the ECU or directly from the sensors themselves so I can't give you all the info.
But that doesn't change that it is possible. You just need the physical parts when using a stand alone and some wiring changes at the throttle body itself.
Nate8409 is offline   Reply With Quote
STI Drive By Wire throttle body howfast? SCIC Private Classifieds 8 02-10-2010 02:03 PM
switching to drive by cable from DBW cpturbo Other Engine Management 3 06-22-2009 10:39 AM
04 STI Drive by wire Throttle body! nick32 Engine/Power/Exhaust 22 12-09-2008 01:36 PM
FS. drive by wire throttle body hettchen Engine/Power/Exhaust 4 07-28-2008 08:02 AM
Drive by wire throttle body. P2109 ImportJunky Mid Atlantic Impreza Club -- MAIC 0 04-02-2008 04:33 PM
Message Board Statistics All times are GMT -4. The time now is 11:59 PM.
