Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 10-31-2009, 03:49 AM   #1
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Default 04 STI hubs same as 03 WRX hubs?
Is the 04 STI hubs (both front and rear) same as the 03 WRX hubs?
Meaning, will 03 WRX axles slide into 04 STI hubs and vice versa?
Fierysun is offline   Reply With Quote
Old 10-31-2009, 04:06 AM   #2
richy_21
Member#: 58670
2005 got muuuuu?
nope front hubs are the same as the sti.
richy_21 is offline   Reply With Quote
Old 10-31-2009, 04:11 AM   #3
Fierysun
Member#: 82745
2005 Subaru STI
You mean the front hubs are the same, but the rear is not?
Old 10-31-2009, 07:14 AM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
hub as in where you bolt the rear wheel,
wheel bolts lugs..yes..rear knuckles are
different..2 pot rear brembos don't bolt right up
w/o the use of adapter brackets..
Old 10-31-2009, 12:11 PM   #5
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
What about the axles? I know rear brakes won't bolt up right away, but curious about whether 04 STI axles from the R180 diff will bolt right up to 02-03 WRX hubs.
MConte05 is offline   Reply With Quote
Old 10-31-2009, 02:03 PM   #6
richy_21
Member#: 58670
2005 got muuuuu?
Nope the splines are also different in the sti hub vs the wrx hub.
Old 10-31-2009, 03:55 PM   #7
Fierysun
Member#: 82745
2005 Subaru STI
The splines are different on both the front and the rear between the 04 STI and 03 WRX?
Old 10-31-2009, 05:58 PM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
No, only the rear. The fronts are the same. There is nothing different in the front knuckle assembly from the wrx. They are identical.
Tony
Old 07-28-2010, 12:42 PM   #9
turbochico
Member#: 212067
2003 WRX
Default just to add to this ****ty mess
I got a 2003 wrx.
I got the brembo brakes from a 2004 STI
the front brembo calipers bolted straight into the original front spindles on the WRX.
The rear ones, needed an adapter.
So I got an adapted from Godspeed in the UK.
The adapter bolted on to the rear backing plate, and the caliper bolted on to the adapter.
The adapter also comes with taller shoes to reach the bigger diameter of the brembo rotors.
I later decided to get the knuckles from a 2003 JDM STI.
the front ones were identical to the WRX.
The rear ones, would bolt right up, but according to the shop, the original WRX axles wouldn't reach/fit.
Also the shop said something about the parking brakes not reaching the brembo diameter either. So I'm thinking the 2003 JDM STI did NOT use brembo brakes but instead used the subaru 2pot setup which comes with rotors smaller than the brembos.
Whatever the case, I know for a fact that the rear 2004 USDM STI knuckles will bolt onto a 2003 USDM WRX, my question is: do I need to change the axles too? what about the differential?
So one hope I have is that maybe the 2003 JDM STI rear knuckles and the 2004 USDM STI knuckles are indeed different and maybe the 2004 USDM STI knuckles WILL fit my WRX without any problems.
turbochico is offline   Reply With Quote
OEM STi Jack same as OEM WRX Jack??? jeffstar Newbies & FAQs 2 09-28-2009 04:23 PM
STi hood same as regular wrx hood? imblown-ru Newbies & FAQs 4 09-05-2007 05:10 PM
Stock Sti downpipe same as stock WRXs? rlim6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-02-2004 05:44 PM
STi Pullies - Same as the WRX? yeager Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 01-26-2004 02:26 PM
Forestor XT Trans Different or Same as 03 WRXs? MY99 2.5GT Transmission (AT/MT) & Driveline 4 07-11-2003 08:21 AM
