Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 10-31-2009, 12:52 PM   #1
sabber
Member#: 224705
2003 NA Baja sport
Default request for help with ongoing electrical problem
I am cross posting this like a mo-fo, just so you know. This is actually a continuation of an electrical problem I have been having for awhile now and I posted something about it before under a different user name (lost access to the account some how) so if this seems familiar it probably is. Also bear with me as this represents a long process and is kind of wordy;
OK, so for quite some time now I have been having a problem with something causing a battery drain while my Baja was turned off. Basically what this means is that if I leave it sitting for 4+ hours, my battery didnt have enough juice to start the car. I checked through all the basics, made sure no lights were on, checked alternator, checked battery, checked all the fuses to make sure none of them were burned out, even tried pulling individual fuses and testing the individual with a multi-meter to see if there was a draw, but it all came up with nothing. Got the battery itself tested (one idea was that there might be a short in the battery itself, the alternator readings were a little weird, but the battery was fin and there was most definitely a drain, specifically of 1.32A. A couple of days a go a friend of mine who is into cars and has been keeping tabs on my problem talked to a friend of his that suggested we hook a multimeter up to the battery itself and pull fuses to see if there was a change in draw, *facepalm* I dont know why I didnt think of that.
So last armed with a multimeter and a "sick of this BS" attitude me and my "car guy" guy friedn that has been helping me with repairs went through the process of checking the fuses for Voltage changes. Pulled and reconnected all the fuses and relays on the inside first with no changes, started pulling fuses in the main box and just about when we were starting to think that the whole thing was a waste of time (with comments made to that effect) I pulled No.5 and the Voltage shot up (well maybe not "shot" up, but it definitely showed a marked increase); sweet! results! Took a look at the fuse (I call it a fuse because it was in the fuse box, but the car guy says its a diode, what do I know?, but regardless...) it looks good so its probably not the fuse (diode?) anyway we do some more testing and to make a long story short (too late) if we pulled the fuse and put it back in it no longer showed the voltage draw, but when we started the cruck back up and turned it off it showed the draw until we pulled the fuse again. Switched No.5 with No.6 (same type of fuse) to make sure their wasnt something wrong with the fuse itself with the same results. When I got home I pulled the No.5 fuse to test it out and it started up fine in the morning. So whatever is causing the draw is connected to that fuse. I have the Haynes repair manual but I cant read wiring diagrams so good (at all) and I was hoping that someone on here may have some idea as to what I need to do next or what the root problem may be. In the mean time I will continue to do tons of internet searches, try to comprehend these wiring diagrams and in general keep my fingers crossed.
And just for the sake of having a visual aid here is the fuse box label:
sabber is offline   Reply With Quote
Old 11-02-2009, 12:06 AM   #2
steven765
Member#: 105920
2006 Baja 5 Speed
so looking at the wiring diagram
SBF-5 feeds 2 secondary fuses
MB-4 in the box there and FB 9 (main box and fuse box numbers)
MB-4 is the data link connector, engine control module and main relay.
This bad boy feeds the main relay, pin B9 on the engine control module and pin 1 on your odb II connector (do you have something plugged in here?)
FB9 feeds the fuel pump relay.
If you pull fuse No. 13 (15amp) in the main box it will disconnect FB-9. This would effectively isolate the two circuits. So you can see which half has the drain.
I would say try that first and let me know. I'll dig into the wiring diagrams after that. There are just too many possibilities until you start to narrow it down.
Oh and all this was for the N/A model
steven765 is offline   Reply With Quote
Old 11-10-2009, 06:55 PM   #3
steven765
Member#: 105920
2006 Baja 5 Speed
any progress?
help with ongoing problem indolegend89 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-02-2007 01:02 AM
request for help with UTEC/laptop interface m4r10 Engine Management & Tuning 9 07-01-2005 02:41 AM
Help me with my electrical problem scoobyimprza Mid Atlantic Impreza Club -- MAIC 11 04-12-2005 01:30 PM
Need help diagnosing several electrical problems probably connected... The Modaholic Electrical & Lighting 2 12-28-2004 12:50 AM
I need help with an electrical (?) problem LJG33 Electrical & Lighting 5 08-18-2004 02:51 PM
