Old 11-01-2009, 06:26 AM   #1
GeneralTJI
Member#: 152680
Stock EJ205 with 172,000 miles
Event: quarter mile
Ambient Temp: around 70-75
Elevation: 4800+
Weather: sunny
Track and Conditions: Slight headwind
Tires: Hankook k106 (225/50/16)
Car: 2002 WRX Wagon
Tuner: Myself
Dyno Info: Road Dyno
Peak HP at RPM: 380ish about 7000 rpms
Peak Torque at RPM: 315lbs around 5600 rpms
Target Boost: 22 relative to sea level
Target AFR: 12.2:1
Fuel: E85
Engine/Power Modifications: Stock Internal 2.0
Driveline Modifications: 2007 STi 6 speed, Exedy st1 STi Clutch, ACT 14lb flywheel
Suspension Modifications: Eibach springs, Perrin 24mm RSB, whiteline endlinks
Other Modifications: Rear seats gone, rear interior stuff removed. Rear bumper beam gone. (trying to offset 6 speed extra weight). Gauges, homemade surge / A1000. Custom FMIC setup etc. http://www.generaltji.com
VIDEO:
I made 6 passes today. Some 12.0's, dipped into the 11's again with a best of the 11.75. I decided I was going to go for CoolRex's 11.6 record And I switched my UTEC over to Ignition cut LC/FFS and upped the boost another 2 psi. I launched, knocked my 60 down to a 1.70 and then blew a rod out the top of the block somewhere before the 1/8th. I was MOVING!!! It's a shame she didn't hold together for 1 more pass, I think I may have been setting up for something impressive, but the 172k stock block said it was enough abuse!
And it figures I didn't turn on the in car cam for that run
Anyway, I had a great day!! I pushed it hard knowing what could happen.. and it did. Thats why I have another block and almost everything I need to put together a solid built cam'd motor. Winter is here... it was good timing.
Thanks for checking out my post, comments welcome.
GeneralTJI is offline   Reply With Quote
Old 11-01-2009, 07:09 AM   #2
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
Congrats. Impressive 2.0 run.
Which turbo?
RonJitsu is offline   Reply With Quote
Old 11-01-2009, 08:54 AM   #3
hauntedwrx
Member#: 115104
2003 WRX
Sedona Red Pearl
Holset HE351
Man General, you have put that block through the ringer a few times. I am still working on getting a few more parts to build my own custom rotated kit. You are the man.
hauntedwrx is offline   Reply With Quote
Old 11-01-2009, 09:01 AM   #4
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Nice work that 2.0 went out in glory bro, Again nice work loveto see bugeyes with the 2.0haulin ass! Doyou have the 2.5 or another 2.0 to throw in?
TDagen is online now   Reply With Quote
Old 11-01-2009, 10:27 AM   #5
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
the shaking
congrats man
Old 11-01-2009, 12:38 PM   #6
CatfaceType-R
Member#: 81102
damn, perfect timing to lose the block. I wish I could have been that lucky with timing.
Love your engine bay, guys this is one guy that I can tell looks after ever inch of his engine and that's why he runs good times
CatfaceType-R is offline   Reply With Quote
Old 11-01-2009, 01:01 PM   #7
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Awesome...I love to see stock block 2.0L's go like this...
thefoos is offline   Reply With Quote
Old 11-01-2009, 01:04 PM   #8
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Nice!!!!
Congrats on the time man, and nice driving! Im sure you had that sub 11.6 record in it. But hey, time for a built and time to go even faster.
Good luck with the new build, and way to hit impressive times at elevation
STi Mikey is offline   Reply With Quote
Old 11-01-2009, 01:24 PM   #9
vivalaWRX
Member#: 186371
07 rofl wagon
+1 for such sick times at 4800 ft!! i cant even imagine how much better your times would have been at a sub 500 elevation. cant wait to see your next build. gl!
vivalaWRX is offline   Reply With Quote
Old 11-01-2009, 02:15 PM   #10
SharpByCoop
Member#: 199906
2008 Infiniti G37S
World's quickest: 11.13"
That was good clean driving. Nice launch--keepin' the nose up and a quick second gear.
Glad you're excited despite the loss.
Coop
SharpByCoop is offline   Reply With Quote
Old 11-01-2009, 04:00 PM   #11
GeneralTJI
Member#: 152680
Thanks for the comments guys!!!
I knew I was asking for trouble when I cranked it up.. so it's all good
Old 11-01-2009, 05:08 PM   #12
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Were there two catch cans I seen under the hood? I may need two... Also whats the new block 2.0 or 2.5?
Old 11-01-2009, 07:34 PM   #13
GeneralTJI
Member#: 152680
Yea I ended up running 1 to the heads, and the other to the crank case... I also needed "something" to fill the gap where the a/c was And it gives everything nice large lines to breathe through.
New motor will be another 2.0. I like the high revving nature of the shorter stroke, slightly thicker stock sleeves, less torque (easier on the clutch, and driveline etc.) Don't have to mess with hybrid head to block setup... and I got the spare block very very cheap. I'd love to do something really awesome like destroke a 2.5 or get a closed deck 2.2 block etc. But this was affordable and should hopefully take the car quite a bit further down the performance path. And basically I just drag race it, so I can get by with lag and without the low end grunt.
Old 11-01-2009, 07:45 PM   #14
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Well done sir! Sorry to hear about the loss I was quite fond of seeing a motor with 75K more than mine go just as fast,... Gives me a glimpse of hope at that record as well (next year). Really nice build, look forward to what comes next for you,...
Change your info!
jmlaser is offline   Reply With Quote
Old 11-01-2009, 09:09 PM   #15
NickWRX
Member#: 15948
2001 2.5RS
317awhp-277ft./lb
I like how all the whites in your video are blown out. Its like foreshadowing for the block going to heaven! ahha, sick run and a sweet setup. Nice work
NickWRX is offline   Reply With Quote
Old 11-01-2009, 09:28 PM   #16
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
Always loved your build man. That motor sure gave you everything she had! It was great to see the emotion at the end of the run. Congrats man!
evan_impreza is offline   Reply With Quote
Old 11-01-2009, 10:02 PM   #17
GeneralTJI
Member#: 152680
HAHA.. I was sad at first when I saw what happened there.. something with the angle of the sun washed it out.... but this statement was great!
Change your info!
Thanks... I think if a person was to sneak up on it, especially with a lower miles motor, it can be done. CoolRex's record is very impressive, but it's not out of reach. I think using ign cut lc / ffs didn't help. It popped when I no lift shifted into fourth (I think, can't remember if it was third or fourth now) the added stress from that type of limiter probably didn't do the rods any good.
Very kind words, thanks I tried to keep things relatively clean and organized.
Thanks, I guess I didn't even realize how excited I get when I make a pass I feel was clean until I watched the footage I had some issues bogging yesterday (those Hankook's hook pretty good even with 38psi in them) and on one run I FFS'd into 5th from 2nd
Anyway, thanks to all of you for the comments. What an adventure! nice to be here and share it with others who are in to the same thing and who understand this.
Old 11-01-2009, 10:05 PM   #18
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Great times and can't wait to see what the new block has in store.
blkscooby is offline   Reply With Quote
Old 11-01-2009, 10:11 PM   #19
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
Hell yeah man thats what it is all about! Especially with a self built and tuned car I'm sure it's even more of a rush! You deserve a
Old 11-01-2009, 11:07 PM   #20
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Good job Todd!
That sucks about the motor though. I don't believe for a second that you're surprised
Audiosavvy is offline   Reply With Quote
Old 11-01-2009, 11:19 PM   #21
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Nice work... Time to build a good motor and go even faster!
Junior2JZ is offline   Reply With Quote
Old 11-02-2009, 09:51 AM   #22
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Too bad your not on this side of the rock I have a good 2.0 long block i pulled from my car you could toss in and go for broke lol
robbieshonda is offline   Reply With Quote
Old 11-02-2009, 09:54 AM   #23
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Hey,
Did you run the Group N file with all the Knock Control disabled or did you turn to turn it back on?
Was it easy to dial in the A/F's?
BUILTSTI is offline   Reply With Quote
Old 11-02-2009, 11:05 AM   #24
GeneralTJI
Member#: 152680
Thanks Brandon!!
Thanks Junior! I hope so!
hehe.... that would be tempting! how long are tracks open out there? ours are all shut down now.
Thanks man... me too.. lotta work and money still though
Hey,
I don't even have a knock sensor .. not something I would recommend btw.. so I didn't mess with enabling knock control on that group n rom. My knock sensor started acting up 25k miles back so I lost that... As far as dialing in afr's, it's a little time consuming, the way the SD fueling table is laid out is not quite as easy to understand as most are. Usually they don't go into negative numbers... (0 is 0% VE, 100 is 100% VE, you can go over 100 for things that are boosted etc.) .. in this rom, 1 is 100%, 15 would be 115%, and - 40 would be 60% VE etc.). You have to get an idea of the VE shape of your engine, which depends on what you have done- cams, heads, turbo, stroke etc. of course being the major factors in that, once you though do it's all down hill from there.. That and not being able to make changes on the fly takes more time. But it was very worth the trouble. The increased throttle response, better idle, nastier camp capability, just overall very smooth and nice to drive. Tuning timing by absolute MAP pressure instead of some imaginary load number is more straight forward like a lot of stand alones too. There are some other issues with this map, but they are all pretty small:
- Fuel pump duty cyle stays at 100% all the time
- CEL's that can't be removed unless you use a UTEC to cover it up (what I did)
- Idle control not functioning quite right. As soon as anything that puts an electrical load on the car turns on, idle goes to 1000. Can't seem to change that yet. Oh well...
- You HAVE to have TGV deletes or a way to keep them open manually. This rom doesn't control them right and they close off above 4k I believe (I didn't have this trouble I delete mine long ago, but this was an issue for others)
Old 11-02-2009, 11:05 AM   #25
Sammidavis
Member#: 189756
2000 Gc8 v7 STi Swap
[email protected] s366 2.35ltr
sorry for my curiosity why did you pull the block,going for a 2,5ltr? if so then why
Sammidavis is offline   Reply With Quote
