Old 11-01-2009, 01:35 PM   #1
mikaust
Member#: 7468
2008 Outback Limited
Default Andrewtech and Turboxs gt35r redux
Yes Im back, after the last motor failure (stretched rod bolt).We started with a new Andrewtech shortblock
Magnus heads
Jun cams
Ferrea 1 over valves
Brandon designed Turboxs front mount
Brandon designed Turboxs intake manifold
Brandon designed Turboxs down pipe
Brandon designed 3.5 Turboxs exhaust
Cosworth oil pump
1000 cc injectors
gt35r turbo
HKS ignition amp
dual walbro set up
GT Spec headers
Q 16 VP fuel
boost 29 psi.
2.5 block and 2.0 heads
dynapack
Tuned at Turboxs by Jermaine
Weather was 60 degrees a bit wet overcast
The car was tuned at Turboxs in Maryland so its a couple of hundred feet above sea level, Jermaine is the tuner. Jermaine ran into several boost issues,so he Mcgyvered my solenoids from my failing Blitz controller and finally got the boost under control. He outdid himself on this one though, but that should come as no surprise to those who know him. Andrew came through as always and stepped the engine building process, so the car was only down for a couple of weeks, once again Andrew, Sam and Dan stood behind their work. Brandon the resident "mad scientist" came up with his usual tricks and the mani he made is the real deal. Once I can get the dyno plot posted you will see why Doug and I use Andrewtech and Turboxs. Andrew has just finished Doug's motor ,so he's next
The Car made 629 whp with peak power @ 7248 rpms and 513 torque @6058 rpms. I left the car with Jeramine because he wanted to fiddle with the tune a bit, so I will pick it up this week and then off to the track. I know is been a while since I have driven a fast car, but trust me its frickin fast.
mikaust is offline   Reply With Quote
Old 11-01-2009, 01:39 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
congrats! can't wait to see some pics and see some runs
Old 11-01-2009, 01:39 PM   #3
Member#: 182734
03 Wagon
I'd like to add that this is a standard GT35R that has not been "HTA'd". Boost was 29psi.
Brandon@TXS is offline   Reply With Quote
Old 11-01-2009, 01:44 PM   #4
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i was just gonna pm you and DEF and see what was up, havent heard from either of you in a while.
the "almost" 10 second twins.
seemed like you guys were always pushing each other.
nice build. I hated my Blitz sbc-id with a passion. go ebcs+mbc and you'll get better control for $150 than the $600 for the blitz pos.
I'll call a 10.999999 with the new build
Old 11-01-2009, 02:17 PM   #5
Matt_H
Member#: 107000
2015 BMW X1
Man that car was fast enough before. Glad to see Andrewtech and TurboXS is still putting out high horsepower cars, but that is expected. Nice numbers!
Matt_H is offline   Reply With Quote
Old 11-01-2009, 05:19 PM   #6
mikaust
Member#: 7468
A 10.9 with me driving? I think I will have to throw the keys to Doug on that one I really did like the Blitz never had a problem with it before this.
Old 11-01-2009, 05:25 PM   #7
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Yours is a 2.5L, correct?
CKxx is offline   Reply With Quote
Old 11-01-2009, 05:28 PM   #8
mikaust
Member#: 7468
Yes 2.5 block and 2.0 heads.
Old 11-01-2009, 05:44 PM   #9
CKxx
Member#: 33458
93 RX7+09 Forester
Very nice.
Also, I just wanted to warn you, there is a new dictated format for PPB threads. It is stickied at the top of the forum. Someone will probably come along and lock the thread until you add the info. Just wanted to give a heads up.
Old 11-01-2009, 06:17 PM   #10
mikaust
Member#: 7468
Originally Posted by CKxx View Post
Very nice.
Thanks
Old 11-01-2009, 11:41 PM   #11
subysnak
Member#: 110817
I saw a few of the pulls on the dyno. Car sounded mean as hell.
subysnak is offline   Reply With Quote
Old 11-02-2009, 12:13 AM   #12
CatfaceType-R
Member#: 81102
what is your compression ratio on the hybrid?
Do you like that ignition amplifier? Did you have spark blow out?
best of luck on ten's, you sure do deserve it.
CatfaceType-R is offline   Reply With Quote
Old 11-02-2009, 12:37 PM   #13
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
Lunch was excellent too!
-Sam
AndrewtechAutomotive is offline   Reply With Quote
Old 11-02-2009, 01:51 PM   #14
mikaust
Member#: 7468
Really don't know about the ignition amp. The reason we used it was because we were having a rev problem on my first motor that turned out to be a crank sensor issue. As for the compression ratio I have no idea,but I did a test before we tuned and it was 170 to 172 all around.
Old 11-03-2009, 12:43 PM   #15
saint_foo
Member#: 64364
Congrats Mike! I heard the good news. Have fun at the track when you go.
-Ed
saint_foo is offline   Reply With Quote
Old 11-03-2009, 01:57 PM   #16
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Definitely a beast... can't wait to get it to the track!!!
def
dug-e-fresh is offline   Reply With Quote
Old 11-03-2009, 03:51 PM   #17
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
Also I might add, that this made about the same power on less boost than the previous set-up using the EXACT same turbo.
def
Old 11-03-2009, 06:37 PM   #18
CKxx
Member#: 33458
93 RX7+09 Forester
def
Do you guys still go to Cecil? Any idea of when you are going? I'd like to see/hear this thing in person.
Old 11-03-2009, 06:52 PM   #19
mikaust
Member#: 7468
hopefully this Friday.
Old 11-03-2009, 06:58 PM   #20
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
If all goes as planned, we will be lined up at Cecil @ 5pm. We should have our first run by 5:35pm
def
Old 11-03-2009, 11:26 PM   #21
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Was this on a .82 or 1.06 A/R hotside?
Crystal_Imprezav is offline   Reply With Quote
Old 11-04-2009, 01:03 AM   #22
Member#: 182734
03 Wagon
.82 T3 Housing
Old 11-04-2009, 09:15 AM   #23
69subaru360
Member#: 159682
1995 WRX
2015 F150
I might go to cecil friday night. I've been wanting to go to the track before the end of the year, I tried to make it to Atco last week, but ran into trailer trouble on the way.
I'd like to see the cars run. I saw both of yours last year I think.
Old 11-04-2009, 12:14 PM   #24
CKxx
Member#: 33458
93 RX7+09 Forester
O man...keep us updated! I'll certainly make the trip down to cecil if you guys are going to run.
Old 11-04-2009, 12:35 PM   #25
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
My car isn't ready yet (but I'm stepping up a little to an HTA3582, )... so this will be just for the Wagon... but we are 90% sure we'll be at Cecil Friday @ 5:00pm. When we hit 10's, we stop... so lets hope its a mid to low 10 for good measure and now low 11 crap to get us booted
def
Andrewtech and Turboxs mikaust dyno [email protected] Proven Power Bragging 33 09-28-2009 07:37 PM
Andrewtech and TurboXS strike again! Built 30R Street Monster inside forgedSTi Proven Power Bragging 77 06-02-2007 05:39 PM
Andrewtech/TurboXS GT35R STi - 505whp/424wtq forgedSTi Mid Atlantic Impreza Club -- MAIC 52 06-30-2006 12:27 PM
