Old 11-01-2009, 01:59 PM   #1
98tredsvt
Member#: 166975
2002 impreza wrx
black
Default drain oil for cam/crank seals?
Do I have to drain the oil to replace the cam and crank seals or does the oil sit low enough in the motor so that it won't spew out when I take the old seals out? Or can I get away with just draining a quart or two? I just put fresh oil/filter in a few weeks ago.
98tredsvt is offline   Reply With Quote
Old 11-01-2009, 05:40 PM   #2
69subaru360
Member#: 159682
1995 WRX
You don't have to drain the oil at all. None will come out.
69subaru360 is online now   Reply With Quote
cam/crank seal part numbers? 98tredsvt Private 'Wanted' Classifieds 2 11-01-2009 02:36 AM
Cam/Crank Shaft Seal Removal Trunk_Monkey Service & Maintenance 3 09-29-2008 01:34 AM
leaking cam or crank seal! how much $?!!?! ooberdoob Legacy Forum 2 12-31-2005 09:39 AM
Cam and Crank Seals 97 GT johndingk2 Legacy Forum 8 01-03-2005 12:25 AM
Picture of Oil crank seal? SubaruImpreza_power Service & Maintenance 3 02-26-2004 08:47 AM
Message Board Statistics All times are GMT -4. The time now is 09:46 AM.
