Old 11-02-2009, 04:17 AM   #1
The Blue Pilot
Member#: 101880
2012 Mustang GT
Default Turbo upgrade without the exhaust swap
My thoughts: putting a stock STI exhaust on my car + catted downpipe, catless uppipe, K&N intake (typhoon), then the fuel pump, injectors, and finally...the turbo.
Goal: car with an upgraded turbo + power while maintaining extremely close to stock dB levels.
How would a 16g/18g fare with the STI exhaust vs with a regular free turboback? I'm talking in terms of power, so a guesstimate of hp/tq differences would be nice..and I'm willing to run the maximum boost possible (with a good powerful tune).
Thoughts? Please don't suggest any aftermarket exhausts such as the borla hush or crap...since I'm asking specifically about the STI exhaust...thanks
The Blue Pilot is offline   Reply With Quote
Old 11-02-2009, 04:35 AM   #2
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Enjoy your boost creep. No point in spending all that money just to be so stubborn as to restrict your car like that. The only part of the STI exhaust you should bother yourself with is the axleback. The rest, for all intents and purposes, is the same as what you have now.
Byzantium is offline   Reply With Quote
Old 11-02-2009, 01:12 PM   #3
The Blue Pilot
Member#: 101880
2012 Mustang GT
Well, that's what I was saying...STI axleback + aftermarket catted DP / aftermarket catless UP with for the upgrade. I'm really only doing it for the sound, nothing else. And just a really newbie/brain fart question....boost creep? Is that where boost slowly builds?
Basically, if the difference is only going to be ~20 whp with minimal affect on turbo lag (difference of) then it's worth it to me. If I'm going to be having stage 2 power with stage 4 spool...then nty
Old 11-02-2009, 01:45 PM   #4
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
So just to be clear, you are going to use the OEM STI cat-back, but an aftermarket 3" or so down-pipe with a high-flow cat?
If so, this can work pretty well. The biggest restriction in the exhaust is the down-pipe with the OEM cats in it. As long as you are replacing that, this setup should work pretty well, and be just slightly louder than stock.
It sounds like you are basically going the Turbo XS stealth rout, and lots of people have done that with good results.
Good luck with your project.
J. Cooley
Flatirons Tuning Project Car
Flatirons Tuning F.A.Q. Blog
Flatirons Rally Team Blog
Follow us on Twitter
FlatironsTuning.com is offline   Reply With Quote
Old 11-02-2009, 01:50 PM   #5
The Blue Pilot
Member#: 101880
2012 Mustang GT
J. Cooley
Thank you sir...but the turbo xs route? You mean turbo xs downpipe? (assuming it's one that mates perfectly with the STI OEM catback...)
Old 11-02-2009, 01:58 PM   #6
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
TurboXS makes a "stealthback" which is a complete replacement exh, until you get to the muffler section, you can retain the stock STI muffer.
This will get you more performance than using a normal downpipe and full STI catback, but the same sound and volume level.
Its the best option out there if you are looking to keep the stock muffler, stock look and stock sound.
Defiant Autospeed is offline   Reply With Quote
Old 11-02-2009, 02:07 PM   #7
The Blue Pilot
Member#: 101880
2012 Mustang GT
Nice...thank you. Only reason I'm going with a catted DP is because the catless (invidia) downpipe I have now is making more than enough of a stench...and combined with my stock wrx axleback, the leak is making the stench even worse...
Old 11-02-2009, 02:08 PM   #8
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
More than likely you have a tune issue if your car stinks bad. IE you are too rich. Catless will smell a LITTLE more, but if its a LOT more, and especially if you get discoloration on the bumper, you have afr problems and are too rich.
unfortunately what makes this situation even worse, is that a lot of so called "professional" tuners (which in some cases means nothing more than they bought a laptop/cable and started charging people) leave their maps FAR too rich, to combat the detonation that is coming from their poorly mapped timing tables.
Old 11-02-2009, 02:19 PM   #9
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
You can get a 3" downpipe adapter that will help it mate up a flat flange DP to a stock catback section. If your DP has a taper to 2.5", then this won't be needed.
http://www.importimageracing.com/p/3...9-WRx-STi.html
For a short-term solution, a 3" flange WILL mate up to a 2.5" pipe w/ donut gasket. Just get some longer bolts and it'll hold. I did that with my 3" catback mated to the stock DP, at least until I get my 3" DP in.
2point0 is offline   Reply With Quote
Old 11-02-2009, 02:26 PM   #10
The Blue Pilot
Member#: 101880
2012 Mustang GT
Unfortunately, I'm running the v.1 AP and I'm using their OTS stg. 2 map currently with my invidia downpipe/uppipe (everything else remains stock). Their maps are known to run rich...hence why that's probably the case...thanks for the explanation though, I had missed that. Although there is no discoloration of the bumper (or so I think, haven't checked lately)
Thanks for the link + advice bud.
Old 11-02-2009, 02:54 PM   #11
Byzantium
Member#: 207826
85k 2002 WRX
This. I've been catless for longer than most people here have owned their cars, and until my current tune (which the tuner did a terrible job on) I've never had a smell.
Old 11-02-2009, 03:44 PM   #12
The Blue Pilot
Member#: 101880
2012 Mustang GT
Even if you leave your car idling in some sort of closed space for a bit?
Old 11-02-2009, 03:48 PM   #13
Byzantium
Member#: 207826
85k 2002 WRX
I never parked my car in reverse in my garage. Parking garages, no.
Old 11-03-2009, 04:27 AM   #14
The Blue Pilot
Member#: 101880
2012 Mustang GT
Excellent. All that talk about harming the environment...psh
This diverts me to another simple question: which turbo to run? A 16g variant (preferably evo3) or the TD05-18g? Which turbo could I run higher boost on? My overall end setup should look like this:
K&N typhoon intake
invidia catless uppipe
turboxs stealthback
sti axleback
xx turbo
walbro FP
injectors
damn good ass tune on the v.1 AP
What do you guys think?
Old 11-03-2009, 10:11 AM   #15
FlatironsTuning.com
Member#: 171650
The Evo III 16G will give you a wider powerband, but the 18G will give you more power up top.
Also, the 16G will spool up a bit faster than the 18G.
You might also want to look into the FP HTA68.
Old 11-03-2009, 12:05 PM   #16
Davenow
Member#: 23676
On that subject, here is what I have found.
The EVOIII-16G is a miserable performer on a 2.5L motor. But is OMGAMAZING on the 2.0L motor.
The FPHTA68 is one of the most over rated turbos ever. But, its dirt cheap, and does work well on the 2.0L motor, so its hard to actually slam it.
On the 2.5L motor, again, miserable match. The housings choke the engine off badly. You cant get around small housings by using high tech machining on the compressor wheel. Its the same reason the small housing 18Gs dont work well on the 2.5L motor, but the large housing 18Gs work VERY well on that same motor. (conversely, the small housing 18G actually works better than the larger housing, on the 2.0L motor)
If they stuck the HTA68's compressor wheel into a TD06 compressor housing, retained the TD05 hot side, but went to an 8cm exh housing, I am betting it would be an AMAZING turbo on the 2.5L. But they dont, and the performance compared to a large housing 18G 8cm on the 2.5L, show this.
turbo upgrade without standalone ecu ? azn0boi04 Pre-2002 Factory Turbo Powertrain 13 11-18-2008 09:55 AM
turbo upgrade without a dyno tune? hirevn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 03-18-2005 02:37 PM
For those who want turbo power without the problems. reddevil Normally Aspirated Powertrain 9 08-09-2004 06:56 PM
to the powers that be: what are the best turbo upgrades for the STI bikerboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-25-2003 07:43 PM
Car feels faster without the exhaust silencer WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-26-2002 03:58 PM
