Old 08-03-2009, 08:02 PM   #276
Richd978
Member#: 190260
06 STI
i have a couple sets of these mud flaps still wrapped. i have no time to make my own mudflaps. if anyone wants to buy them and make their own but dont have a ikea near them PM me
Richd978 is offline   Reply With Quote
Old 08-04-2009, 06:02 AM   #277
Bereta
Member#: 219119
04 2.5rs
san remo red
can someone link to that printable tmeplate???
Bereta is offline   Reply With Quote
Old 08-04-2009, 06:56 AM   #278
neat-0-wrx
Member#: 175975
Originally Posted by AeroWRX View Post
Do we really need to go buy all those speed nuts, fasteners and new bolts, etc. from Lowes for this? Do the stock screws already in those holes not fit after the Ikea flaps?
for my car, i was missing a few of them fasteners anyway... so i just replaced them all... the op, said his gc had oem mud guards, and that he could reuse his stuff though...
neat-0-wrx is offline   Reply With Quote
Old 08-04-2009, 06:59 AM   #279
neat-0-wrx
Member#: 175975
Originally Posted by 96imprezaL View Post
ok so heres the front one:
width on top: 1.5"
width on bottom: 10.5"
height on left: 13.5"
height on right: 7.5"
Rear:
width on top: 1.5"
width on bottom: 11"
height on left: 16" but i did 14.5" b/c thats how long the cutting board is
height on right: 10.5" but i did 9" to keep it in proportion.
STI LOGO:
7" long
2.5" high
that not good enough? this should do it....
Originally Posted by phong View Post
Here is a write up I did for a my local forum.
This method requires no holes to be drilled in the car and no paint damaging u-nuts/j-nuts/speednuts. This is definitely incomplete picture-wise (I made these 4 years ago) but should give anyone interested good start with the template/pattern. This is based on on 02-03 cars so newer cars may be different.
Pattern for 02-03 STi mudflaps (the ridiculously expensive ones).
1. Find universal mudflaps big enough and thick enough: This will actually be the hardest part, I haven't been able to a good replacement set for my car at this point. The originals were NAPA brand "truck mudflaps" but they don't carry anything like that the last time I checked a few years back. I hit Autozone and Advance yesterday but no dice; seems like the stores in VT had a better selection. I need to hit an actual NAPA store again or find a plastic supply house. That being said, the material needs to be semi-rigid in order to hold its shape in the wind and not deform over time. The thickness also eliminates the need for the metal bracket used on some kits.
2. Make template and fit to your liking: I used paper and I would recommend this because you can see through it and it helps in locating the holes. Tape them on the car and eye them to your liking. Once you have them set where you want them trace the outline of the fender/bumper on the template and mark the holes (see fastener section for hole info). I don't really remember why traced the outline on the template but I am sure there was a good reason at the time.
When fitting/setting the rear flaps, there is a notch on inside of the wheel well that seems purpose build for holding the flap in place, so make sure if your car has this you take advantage of this built in feature. Basically, you want the inside of the flap to be flush/tight to the inside/inboard edge of the wheel well. Note that there is a cut in the rear flap that allows it to sit back farther when secured behind the aforementioned notch. If your car doesn't have this then the thickness/rigidity of the flap material will be more important. I never got far enough into producing these to research outside of 02-03 cars.
3. Trace and Cut: Trace your flaps and cut them out. I used a heavy pair of scissors and it all went pretty well. Obviously, use as many of the pre-cut edges and use the pre-cut curves as templates to get perfect curves. The cut on the rear flaps mentioned above is done pretty much by feel and use my pics as a guide. Trace the holes and drill pilot holes for fastening.
4. Fasteners are simple: Believe it or not, my mudflaps have been on for 4 Vermont winters/mud seasons (plus this joke of a winter in Albany) held on only by black anodized stainless self taping screws and nylon expanding nuts (license plate nuts). Finding the right sizes takes some work but a Dremel can be used to grind them down some to fit the holes. The front holes are smaller and harder to find the right size.
What real winter looks like...
On the rear there are two holes in the bumper cover used for fastening. Pop the nylon nuts in holes, place the flap and screw in your screws.
In the front there are three of those crappy expanding plastic screw fasteners that hold on the side skirt and trim that are removed. Pull the trim and skirt down/out pop the nylon expanding nuts into the holes (may need to grind them down to fit). Push the trim/skirt back up, the screws will replace the expanding fasteners holding the flap and trim/skit in place.
[img]http://i96.photobucket.com/albums/l188/phong468/DSCN0011-2.jpg
Dan
the last pic i had to edit to a url to post this
Old 08-04-2009, 05:25 PM   #280
filipin0y
Member#: 216968
2oo2 wrx sedan
psm!
can someone tell me how thisll work for the bugeye 02?
filipin0y is offline   Reply With Quote
Old 08-04-2009, 06:47 PM   #281
MightyMan908
Member#: 197069
2009 Impreza 2.5i
Dark Slate Metallic
I am looking for a template or measurements of 08/09 Mudflaps if anyone has or has made them.
MightyMan908 is offline   Reply With Quote
Old 08-04-2009, 09:01 PM   #282
Mobutusan
Member#: 118017
2004 WRX Waggin'
Thanks for that last post Neat-O. That's some good info.
Mobutusan is offline   Reply With Quote
Old 08-04-2009, 09:21 PM   #283
neat-0-wrx
Member#: 175975
every bit of it was pulled from this thread... in the first 5(n00b setting) pages
Old 08-05-2009, 05:15 AM   #284
Bereta
Member#: 219119
04 2.5rs
san remo red
i went through the whole thread to Neat-O but the main word missed was PRINTABLE TEMPLATE! lol so i can spray glue the on to my material then cut it out and drill holes in voile perfect fit pull off template and attach or whatever
and i saw all of those but thanks for re posting
Old 08-05-2009, 11:21 AM   #285
aurelius
Member#: 188548
MY97 LGT
Club Spec 2
Finally bought some today. I got larger ones from Kmart (Walmart) for a bit more and they're all sorts of fluro colours.
Shall be sweet and i'll post photos when done...
aurelius is offline   Reply With Quote
Old 08-06-2009, 02:59 AM   #286
96imprezaL
Member#: 145635
2005 LGT Stg4 soon;)
GRP
ooo do you have pics of the product?? deff post some pics when you can
96imprezaL is offline   Reply With Quote
Old 08-06-2009, 03:18 AM   #287
neat-0-wrx
Member#: 175975
i would either make friends with someone with rally armors, or, just make a cardboard cutout flap, and spray glue that for a look you made yourself...
Old 08-07-2009, 09:36 PM   #288
SharkWagon
Member#: 99788
1977 Chevrolet
Corvette
Originally Posted by Evo killerz View Post
why do people wreck look of a perfectly good car with these crap looking diy mods go buy a set of mudflaps made for the car if you buy a subaru then you are expected to be able to afford it not making cheap things for it and wreck look of it, its like me going to my front door and using my door mats as mudflaps
I have to respectfully disagree with your statements Evo Killerz. Things like this thread aren't what is wrong with the Subaru community, they are exactly what is RIGHT with the Subaru community.
It's more then just about the car and caring what people think of you "wrecking" the look of it. It is about the people you meet and the great experiences you have while having fun with your car. Not only are Subaru people creative and inventive (garage door lips and cutting board mudflaps, hell McGyver would be proud), there is at least one person in this thread who bought extras, for no other reason then that some one else might want/need them. Try to find that kind of spirit in other auto communities.
Creative suby mods and cool suby people= +eleventybillion
Evo Killerz = 0
NASIOC - its what makes a Subaru, a Subaru.
SharkWagon is offline   Reply With Quote
Old 08-09-2009, 01:02 AM   #289
toofast4u
Member#: 148061
2002 2.5 RS
Blue Ridge Pearl
+1,000,000,000,000,000
toofast4u is offline   Reply With Quote
Old 08-10-2009, 03:03 PM   #290
96imprezaL
Member#: 145635
GRP
thats whats up
Old 08-10-2009, 03:34 PM   #291
SupaHottSauce
Member#: 111725
2003 Dylan Peterson
is a scammer
Not to mention having a lip kit and side skirts makes fitment different. With the DIY I was able to cut them to the exact size I needed to fit properly and not worry about messing up $100 mud flaps.
mine dont curl but if youre worrying about them curling, just find some thin strips of stiffer plastic and bolt 2 of them vertically to the inside of the mud flap
SupaHottSauce is offline   Reply With Quote
Old 08-11-2009, 03:30 AM   #292
Adrenaline981
Member#: 212884
i just made a set of these and think they look amazing, im Spraying the Sti logos tomorrow and i will post some pics
Adrenaline981 is offline   Reply With Quote
Old 08-11-2009, 03:57 AM   #293
aurelius
Member#: 188548
MY97 LGT
Club Spec 2
They're in orange, red, green and blue. All covered in dirt though lol
Old 08-11-2009, 04:07 AM   #294
wtfh4xx
Member#: 220059
2004 JBP WRX
STAGE 2
Nice idea, Id have to paint PERRIN on mine though!
wtfh4xx is offline   Reply With Quote
Old 08-25-2009, 06:41 AM   #295
wrxmonster
Member#: 206388
i dont think 92$ is too much to throw for a set of proper rally style mud flaps
well, buy me a set
wrxmonster is offline   Reply With Quote
Old 08-25-2009, 01:22 PM   #296
Adrenaline981
Member#: 212884
heres the only pic i have of mine, you cant really see the fronts caus of the lighting but the point is still there
Old 08-25-2009, 01:26 PM   #297
wrxmonster
Member#: 206388
Looks good man!
Old 08-25-2009, 01:50 PM   #298
Adrenaline981
Member#: 212884
Originally Posted by wrxmonster View Post
Looks good man!
Thank you
Old 08-29-2009, 02:08 AM   #299
W3StCoAsTSTi
Member#: 219955
2006 WRX STi
Crystal Gray Metallic
Originally Posted by Voytek View Post
This is more of a generic "mud flaps" question: How do they (Ikeas or the real ones) hold up in winter driving? Do they clog up with snow and get frozen in place?
Basically what I'm asking is are mud flaps a "all year round" option? These are a real nice mod for the DYI type of person, but after reading about Rally Armour's flaps, I'm thinking about getting those...
hey man best solution to build up on mudflaps is to buy Armorall Tire shine and spray it on your flaps every once and a while and everything slides right off. try it out it works
W3StCoAsTSTi is offline   Reply With Quote
Old 08-29-2009, 02:27 AM   #300
Donutz
Member#: 148803
11 WRX 4dr
96 Impreza 3.6RS (EZ36R)
doh win, trying this, thanks man
Donutz is offline   Reply With Quote
the Mudflap thread !! N'CTRL Member's Car Gallery 644 06-30-2014 11:21 AM
the scoobies for boobies mudflap thread michelle2781 Interior & Exterior Modification 35 05-28-2013 10:42 PM
Deleting the weapon thread.. and the whining thread about me locking it is even lamer Fish Texas Impreza Club Forum -- TXIC 14 07-01-2010 12:29 PM
"M" is for The Mudflaps Ya Gimme for my Pickup Truck WagonMonster Off-Topic 16 08-17-2006 05:05 PM
Kris or Igg: Where do I get your directions for making/install the mudflaps? Schleppy New England Impreza Club Forum -- NESIC 4 10-22-2002 01:16 PM
