Old 09-02-2009, 02:00 AM   #301
wrx2oo2
Member#: 179891
2007 STi
Default My experience
I have a 07 STi and this is what I ended up using:
Quantity: 4 - IKEA cutting boards (comes in pack of 2 but they come with one black and one transparent grey/black) so buying 4 will = 4 black
Cost: $1.99 per pack
Quantity: 10 - 1/4" x 1 1/4" Hex Bolts (20 tpi)
Cost: $0.11 per bolt
Quantity: 10 - 1/4" x 1 1/4" Fender Washer
Cost: $0.18 per washer
Quantity: 4 - 1/4" Speed Nut Clips (20 tpi)
Cost: $0.92
Quantity: 1 - Black "FLAT" spray paint
Cost: $0.99
1) Cut the ikea mudflaps using the template they provided, the one that is marked in millimeters.
2) Google "mm to inches" converter
3) Mark and cut the mudflaps.
4) Spray the washers and bolts
5) Start on the back mudflaps. There are two holes already there exposed, so clip the "Speed Nut Clips" over the holes (4 total) and then attach the mudflaps to them.
6) This is the part that took me a while to figure out because with the STi's they have a full underbody diffuser, which I didn't want to mess with so here's how I attached the front mudflaps.
  1. Remove the 3 plastic pop tabs using a screwdriver.
  2. Start to pull back the wheel plastic inner lining slowly just enough to put your arm in it.
  3. Starting from the bottom bolt and moving up, attach the bolt by pushing it through the hole and with your arm inside the fender (by pulling back the wheel plastic inner lining) twist the bolt on the back. Your going to have to do this by feel.
  4. Tighten both up, with a open end wrench on the "bolt" end, and a screwdriver or wrench on the other end.
  5. Do this for all three, remember to use the washer!
  6. Tighten only enough to where it's snug because if you tighten too much it will start to warp the cheapy ikea cutting board material
7) Your done! Well almost, adjust the mudflaps accordingly because I guarantee, unless you're one with great eyesight, that you will put it on crooked the first time.
:::UPDATED - ADDED PICS:::
wrx2oo2 is offline   Reply With Quote
Old 09-02-2009, 02:17 AM   #302
hoffmanEstates
Member#: 122043
04 wagonier
psm
my ikea flaps are holding up still , but dam how do you get out of that much snow? i thaught central/north WI was bad for me with the drifts.
Originally Posted by neat-0-wrx View Post
that not good enough? this should do it....
the last pic i had to edit to a url to post this
hoffmanEstates is offline   Reply With Quote
Old 09-02-2009, 03:22 AM   #303
Bereta
Member#: 219119
04 2.5rs
san remo red
Cost: $0.92
Cost: $0.99
I will post up pics tomorrow morning~ Hope this helps
thank you please post your pics man !!!
Bereta is offline   Reply With Quote
Old 09-02-2009, 11:02 AM   #304
avionator
Member#: 210482
damn there not being any Ikea's anywhere near me... i wonder where else i could source these? eBay has the 2packs for 7 bucks. but that's dumb. maybe a dollar store will have them or something similar.
also, what color should i get? i ride a 2009 5 door 2.5i in dark gray metallic. i'm thinking yellow to match my headlights... but maybe black would look better? white?
avionator is offline   Reply With Quote
Old 09-02-2009, 03:28 PM   #305
wrx2oo2
Member#: 179891
2007 STi
Updated! Scroll up and check them out, just took a couple of quick pics before work. I'll take more when I get the chance.
Old 09-02-2009, 06:39 PM   #306
Subarudave09
Member#: 209316
if anybody wants these made i have made about 12 sets of black ones. PM if interested $5
Subarudave09 is offline   Reply With Quote
Old 09-07-2009, 04:36 PM   #307
imma_stocker
Member#: 97043
08 STI - 02 Z28
07 GSXR - 96 CBR
If you are looking for other colors, try Target or WalMart. The closest IKEA is about 30mins from my house.
imma_stocker is offline   Reply With Quote
Old 09-07-2009, 07:18 PM   #308
solidace46
Member#: 208431
2002 WRX Stage 2
I just bought a set and am about to cut them up now, though they look more gray than black. Has anyone painted theirs? I am scared to because I think they'll chip super quick and I'll regret it. When I say paint them, I mean the whole thing...not just the sti emblem or anything. I actually plan on painting SUBARU in WHITE on them . But I want them to be a more solid black. Anyways any feedback would be great. Thanks
solidace46 is offline   Reply With Quote
Old 09-07-2009, 11:17 PM   #309
hangmanfsc
Member#: 218655
1013 Legacy/STI
SWP/PBP
I got similar matts that I plan to custom make for y 2010 legacy, I'm wondering: how did you get the front two secured? what did u go through to get behind the wheel well covers?the rear are easy to fit on, but I'm not too sure how to get the front on.
hangmanfsc is offline   Reply With Quote
Old 09-07-2009, 11:19 PM   #310
hangmanfsc
Member#: 218655
1013 Legacy/STI
SWP/PBP
opps nm, I'll keep reading
Old 09-09-2009, 06:01 PM   #311
subimp6u08
Member#: 15440
2005 STi
does anybody have extra sets(already cut and holed) they would like to sell it to me? I would love to do this mod by myself, but I don't have any time or tools to do it.
PM me if you have extra
subimp6u08 is offline   Reply With Quote
Old 09-09-2009, 07:45 PM   #312
Adrenaline981
Member#: 212884
05 EVO
TB
you dont have ten minuts, 12 screws a pencil and scissors?
Adrenaline981 is offline   Reply With Quote
Old 09-10-2009, 02:56 AM   #313
subimp6u08
Member#: 15440
2005 STi
what i meant by tools was a drill to make the holes.
Old 09-11-2009, 04:56 PM   #314
TurmultTee
Member#: 83897
A Subaru
Impreza
Dose anyone know a place online that sells the speed clips. My local home depot doesnt stock them.
TurmultTee is offline   Reply With Quote
Old 09-12-2009, 12:13 AM   #315
SharkWagon
Member#: 99788
2010 Cerveza
Negra Modelo
Most auto supply places keep them in stock, any Autozone, Pepboys, O'Reilly's etc should have them.
SharkWagon is offline   Reply With Quote
Old 09-12-2009, 11:50 PM   #316
littlec
Member#: 208934
09 2.5i
Originally Posted by W3StCoAsTSTi View Post
hey man best solution to build up on mudflaps is to buy Armorall Tire shine and spray it on your flaps every once and a while and everything slides right off. try it out it works
good idea. would wd40 also serve the same purpose??
littlec is offline   Reply With Quote
Old 09-13-2009, 12:24 AM   #317
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
WD40 breaks down rubber...so be careful.
CKxx is offline   Reply With Quote
Old 09-13-2009, 12:36 PM   #318
littlec
Member#: 208934
09 2.5i
ah yes, good call. thanks for the heads up.
Old 09-13-2009, 01:14 PM   #319
aurelius
Member#: 188548
MY97 LGT
Club Spec 2
My Kmart ones started to break the other day. Always go with the premium Ikea brand one lol.
aurelius is offline   Reply With Quote
Old 09-13-2009, 10:37 PM   #320
aweissenborn
Member#: 219181
2008 Impreza OBS
Newport blue/Steel metall
I pulled this off this weekend, I added a little local flare to them.
Created the stencil and painted it on. Will put them on my subaru soon.
aweissenborn is offline   Reply With Quote
Old 09-17-2009, 11:04 PM   #321
MightyMan908
Member#: 197069
2009 Impreza 2.5i
Dark Slate Metallic
What I am working on:
Rally Armor replicas (sort of speak) for the 08/09 Impreza/WRX. No i did not trace these from someone's. I am just going off of video and images I have found online.
MightyMan908 is offline   Reply With Quote
Old 09-18-2009, 09:27 AM   #322
fast5thgen
Member#: 144549
05 LGT 5MT
too sweet
I priced RA's mudflaps today for the first time, $126 for the urethane and $50 for their cheap ones!! GTFO with that ish! And that my friends is why DIY is King!
fast5thgen is offline   Reply With Quote
Old 09-18-2009, 09:59 AM   #323
Edvig
Member#: 16147
no more turbo
05 Legacy, 11 Outback
Did you know that they have a new Universal Basics set out for $15.99
http://forums.nasioc.com/forums/show....php?t=1840589
Edvig is offline   Reply With Quote
Old 09-24-2009, 07:16 PM   #324
kstorm88
Member#: 221562
'02 WRX Wagon
Default just went to the surplus store.
i just went to the local surplus store, and i picked up some rubber matting or whatever. anyway, got a 2ft by three foot section. it's a heavier rubber so i expect it to last a very long time. i just hope it's not going to be too floppy. floppy is good for parking lots, not so much for high speed. hopefully i can get them cut soon. and when i put them on ill take some pics, if anyone is interested, pm me, i have more rubber than i need, plus it only cost me $6! i swear everyone on here is an engineer or a person of gifted IQ, as are most people who love their subarus.
kstorm88 is offline   Reply With Quote
Old 09-24-2009, 07:32 PM   #325
ARBoost
Member#: 190876
2005 STI CGM
361hp/370tq Done by Jorge
Natty Boh!!! God bless Maryland .
ARBoost is offline   Reply With Quote
the Mudflap thread !! N'CTRL Member's Car Gallery 640 04-20-2013 05:23 PM
Deleting the weapon thread.. and the whining thread about me locking it is even lamer Fish Texas Impreza Club Forum -- TXIC 14 07-01-2010 12:29 PM
the official scoobies for boobies mudflap thread michelle2781 Interior & Exterior Modification 34 12-01-2009 06:08 PM
"M" is for The Mudflaps Ya Gimme for my Pickup Truck WagonMonster Off-Topic 16 08-17-2006 05:05 PM
Kris or Igg: Where do I get your directions for making/install the mudflaps? Schleppy New England Impreza Club Forum -- NESIC 4 10-22-2002 01:16 PM
Message Board Statistics All times are GMT -4. The time now is 03:23 PM.
