Old 07-08-2012, 06:10 PM   #1201
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
Originally Posted by ManualOverAuto View Post
Are there shorter RA mud flaps I can buy, but would still fit my car (2001 impreza)? Liking them a lot so far, except I don't like how far down they hang in the rear. They're like 2-3 inches from the ground :/
I'd cut/resize them myself, but trimming the bottom would take off the logo.
Trim them from the top and re-drill the mounting holes.
Dale2011WRX is offline   Reply With Quote
Old 07-08-2012, 06:39 PM   #1202
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
I actually thought of that after I posted this. I may go that route. Just have to make sure I align the holes right.
All the hardware is in use though. So wouldn't having to re-use all the plastic clips be pushing it as far as durability goes? Double threaded plastic seems like it could break the threads and not hold well.
ManualOverAuto is offline   Reply With Quote
Old 07-08-2012, 11:48 PM   #1203
ManualOverAuto
Member#: 304662
Sedona red Pearl
Here's a pretty cool pic I got of my RA's.
They look like they hang WAY low is this pic but they are actually higher up. They still hang too low for my liking, but the protection they offer allows me to deal with it, haha.
Old 07-11-2012, 01:51 PM   #1204
ManualOverAuto
Member#: 304662
Sedona red Pearl
Did this today. I actually didn't trim the top at all. Just cut new mounting holes 2 inches lower, and re-mounted them.
Now they're kinda "adjustable" lol, with 2 sets of mounting holes.
Old 07-11-2012, 02:23 PM   #1205
Dale2011WRX
Member#: 304299
2011 WRX, white
That's a great idea, I wish I'd thought of that before I mounted mine.
I wonder how high we can go and still get full protection. Let us know when you hit your first big mud-hole.
Old 07-11-2012, 02:30 PM   #1206
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
My Rokblokz flaps look way better than any RA flaps, and they were half the price. boom.
http://www.rokblokz.com/08-12-subaru-sti.html
blehhh is offline   Reply With Quote
Old 07-11-2012, 02:46 PM   #1207
ManualOverAuto
Member#: 304662
Sedona red Pearl
Well I only adjusted and made new mounting holes for the rear flaps. For some reason they were way lower than the front. I figured the rear ones don't really have much to "protect" much besides the rear bumper, so a 2 inches shorter won't make much of a difference.
I don't do actual rally events so I don't need to worry about gravel and rocks flying at other cars.
The fronts do offer great protection though. Couldn't hear nearly as many rocks pinging off the side of my car on gravel roads recently. Plus they keep ALOT of dirt/dust off my car. Since I've put them on, my car hasn't gotten any dirtier and I still go on a few gravel roads every day.
Edit: and I only got the basic flaps (plastic). I can only imagine how nice the urethane ones are. Rubber-like material right? I just didn't have $150 to spend.
Old 07-11-2012, 03:34 PM   #1208
nategr8ns
Member#: 198413
1999 Impreza OBS
Ninja 650r
I spent ~$25 at NAPA on a single truck flap, cut it in quarters, rounded the corners, and mounted them up. They're giant, and even jumping into a mud puddle at Oregon Trail Rally and spinning the tires, I barely even got splatter on the car. The wheels, however, are still filled with the dirt two months later.
Great coverage because of how far out they stick, but unfortunately you have to be mindful of curbs when parallel parking. My dad ripped one of them off once.
nategr8ns is offline   Reply With Quote
Old 07-13-2012, 12:51 PM   #1209
Lightwysh
Member#: 324799
Does the 2012 wrx 5dr have predrilled mounting holes and will the 2011 wrx Rokblock flaps mount up without drilling?
Lightwysh is offline   Reply With Quote
Old 07-13-2012, 01:25 PM   #1210
Dale2011WRX
Member#: 304299
2011 WRX, white
Yeah they look so different than the RA's, it's like night and day.
Old 07-17-2012, 05:00 PM   #1211
Freedog
Member#: 293551
Originally Posted by amart21 View Post
How I fixed mine:
Take the Inner most part on the "L" Bracket and slightly bend it towards the tire. Its a good idea to loosen the outside bolts attached to the fender to allow for mudflap movement. Then when the flap is strait snug the outermost bolts up again. by pulling that inner bracket end closer will give you less of the "curling" - Hope that helps
Thanks for the helpful response. I contacted RA with this question and they suggested the same fix... I now have them loose enough for me to pull/reposition the flaps, and i have bent the L Bracket in slightly (measured inner and outer spacing from tire to check that it's perfectly parallel.) It's been this way for over a month, and still have just as much curl. Going to give it some more time, then follow up.
Freedog is offline   Reply With Quote
Old 07-17-2012, 09:35 PM   #1212
ManualOverAuto
Member#: 304662
Sedona red Pearl
Mudflaps doing their job pretty well so far.
Old 07-17-2012, 10:18 PM   #1213
Kerplunk105
Member#: 165115
07 Impreza
A guy in my complex has these. I never even heard of them until I googled after seeing them on his car.
Kerplunk105 is offline   Reply With Quote
Old 07-17-2012, 11:55 PM   #1214
scoobyd00d
Member#: 277301
2010 Impreza
Satin Pearl White
They do look really nice. I have RA and they're all warped and my car isn't even that low. I should make the switch. How long have you had them on? Any warping or twisting?
scoobyd00d is offline   Reply With Quote
Old 07-18-2012, 12:15 AM   #1215
SilverSubie2.5
Member#: 136144
2010 STi
I like those a lot, first I've heard of them. RA was just first instinct, didn't even think to look for something else. If/when I need to replace, I know what I'm looking for.
SilverSubie2.5 is offline   Reply With Quote
Old 07-18-2012, 12:22 AM   #1216
Vrooom_Psh
Member#: 311923
04 STi
it's worth mentioning though that they are 10.5" wide vs. the RA UR which are 8" wide. Some people already think the RA are too wide..
Vrooom_Psh is online now   Reply With Quote
Old 07-18-2012, 12:30 AM   #1217
KLZCYA
Member#: 281146
95 6 spd GC8 STi
KLZCYA is offline   Reply With Quote
Old 07-18-2012, 06:41 PM   #1218
Kerplunk105
Member#: 165115
07 Impreza
I'm debating between the mudflap companies..do any of them not require modification for installation for an 07 wagon?
Old 07-19-2012, 02:10 AM   #1219
nategr8ns
Member#: 198413
1999 Impreza OBS
Ninja 650r
Any of the flaps that come with precut holes in the right place for the '07 should do. Personally its really not that hard to line a new flap up to the old mudguard and just drill your own holes where you want them. That's what I did with my 18-wheeler flaps.
Old 07-19-2012, 02:04 PM   #1220
Nellus
Member#: 325999
2011 WRX
B.A.B.
I have my dark gray 99 impreza with a wrapped flat black hood - should i go with plain black mud flaps?
Nellus is offline   Reply With Quote
Old 07-21-2012, 01:32 AM   #1221
WRXMunkey
Member#: 286400
2006 WRX Wagon
Flapatax flaps are what you should get
WRXMunkey is offline   Reply With Quote
Old 07-21-2012, 02:37 AM   #1222
Francois_
Member#: 284101
2004 STI
world rally blue
Originally Posted by KLZCYA View Post
Well done, sir.
Francois_ is offline   Reply With Quote
Old 07-21-2012, 03:46 AM   #1223
Joe522
Member#: 308205
12 Grocery Getter
WRX WRB
Thinking about buying some RA's for my 06 but im unsure if i should just buy the classics or spend a little extra on the URs what do you guys think?
Joe522 is offline   Reply With Quote
Old 07-21-2012, 07:07 AM   #1224
Yakattak
Member#: 284332
2003 Impreza WRX
Platinum Silver Metallic
I'd spend the extra on the URs, they're a lot better quality.
Yakattak is offline   Reply With Quote
Old 07-21-2012, 10:45 AM   #1225
Dmochowski
Member#: 306478
2016 Focus RS
stock
do these look like they are not level vertically speaking:
Dmochowski is offline   Reply With Quote
the Mudflap thread !! N'CTRL Member's Car Gallery 644 06-30-2014 12:21 PM
the scoobies for boobies mudflap thread michelle2781 Interior & Exterior Modification 35 05-28-2013 11:42 PM
Deleting the weapon thread.. and the whining thread about me locking it is even lamer Fish Texas Impreza Club Forum -- TXIC 14 07-01-2010 01:29 PM
"M" is for The Mudflaps Ya Gimme for my Pickup Truck WagonMonster Off-Topic 16 08-17-2006 06:05 PM
Kris or Igg: Where do I get your directions for making/install the mudflaps? Schleppy New England Impreza Club Forum -- NESIC 4 10-22-2002 02:16 PM
