Old 05-14-2002, 05:13 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Running TMIC without hood scoop?
Is this a bad Idea? I am getting my new Impreza tomorrow and well I won't have the money for to do the hood and what other things I plan to have done when it goes it for painting for a bit. Would I be okay running low boost with just a stock hood?
Joshua
yebokmj is offline   Reply With Quote
Old 05-14-2002, 05:57 PM   #2
ObsidianRS
Member#: 17042
2004 Impreza WRX STi
Blue/Gold
Well it seems like it would make it a type of short ram intake?
It wouldn't be cold air. And since it's probably taking air in from the center back of the hood, it's probably going to be a hot air intake.
Even if it runs okay, I would still recommend saving up for a hood.
I'm doing that with my new age rs: getting a wrx hood and getting a top-mounted CAI built for it.
ObsidianRS is offline   Reply With Quote
Old 05-14-2002, 05:57 PM   #3
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
At least you HAVE an intercooler. I run 11PSI without one, cause the Legacy Turbo didn't have one from the factory.
But then again, i have low-comp pistons, and my car was made to work with this setup.
You could run no-boost, and it should be fine.
Dave
DLC is offline   Reply With Quote
Old 05-14-2002, 08:07 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
It'd then effectively be an interheater. Bad... definitely bad. If anything run real low boost and a straight tube between the turbo and TB.
Old 05-14-2002, 09:59 PM   #5
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Exactly
You took the words right out of my mouth. You'd be better off just running a straight tube from the turbo to the throttle body. To go even a step further, have the tube wrapped in some type of 'anti-heat' material so as to not allow any heat to be absorbed by the tubing.
Hold on to the intercooler until you can either get fresh air to it or sell it.
Kevin Thomas is offline   Reply With Quote
Old 05-14-2002, 10:27 PM   #6
yebokmj
Member#: 2213
Brilliant Red
Default Holding off
I am just going to wait and do it right. I figure I can use my Cone filter and MAF adapter to make a home made air intake and put my turbo exhuast on for a bit more pep. I can also install all my gauges and such and this way get everything sorted out before the install. I figure with the exhaust, intake and some adjustments from the S-AFR I might be able to be right around stock RS power till I put the turbo on.
Joshua
Old 05-15-2002, 05:14 AM   #7
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
you could 'try' running electric fans on the intercooler like constantly to do some sort of heat dissapation
akcel is offline   Reply With Quote
Old 05-15-2002, 09:54 AM   #8
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Default Re: Holding off
Originally posted by yebokmj
I am just going to wait and do it right....I figure with the exhaust, intake and some adjustments from the S-AFR I might be able to be right around stock RS power till I put the turbo on.
Joshua
Well waiting is good.. however those mods won't even get you close to stock RS power. Are you nuts?
Why not sell your top mount, cut up your front bumper or get a version 4 or version 5 front bumper and get a front mount intercooler. I would likely have done that if I bought an L instead of an OBS, but I don't have a top mount to sell to help pay for a front mount if you catch my drift
Good luck.. What paint work is being done?
Jon
omahasubaru is offline   Reply With Quote
Old 05-15-2002, 10:12 AM   #9
yebokmj
Member#: 2213
Brilliant Red
Talking Wish Full Thinking?
Okay maybe not close to an RS but it's nice to hope. I personally like the Top mount interms of Lag and I don't need front mount for my HP goals. Plus I really like the look of the hood scoop. So paint work is scrape off the antena add spoiler, paint side moldings and hood.
Joshua
Old 05-15-2002, 10:50 AM   #10
mn10roo
Member#: 9709
1993 Impreza L wagon
green
Custom mount just the rs hood scoop, save you plenty O' money and look dope, I still am going to try this just for fun. Careful when the kit goes on try to have extra cash for misc. parts you want/need. Happy boosting!
mn10roo is offline   Reply With Quote
Old 05-15-2002, 11:08 AM   #11
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
You could always sell the TMIC and get a top-mount air-to-water IC, now that I think about it.
Old 05-15-2002, 12:25 PM   #12
Brady
Member#: 14838
2005 LGT--Garnet Red
197 Iggpoints
just modify your AC to blow directly on your intercooler!
Brady is offline   Reply With Quote
Old 05-16-2002, 07:20 AM   #13
GimmeScoobySnacks
Member#: 2094
1999 2.5 RS-T
RBP
why don't you just drive around without a hood?
kidding
GimmeScoobySnacks is offline   Reply With Quote
Old 05-17-2002, 04:56 AM   #14
NateDogg
Member#: 6467
1999 Impreza 2.5 RS
i always thought it would look cool if someone just let the topmount IC stick out of the hood. no scoop. it would work perfectly only downside is that people would be able to see it.
Nate
NateDogg is offline   Reply With Quote
Old 05-17-2002, 05:22 AM   #15
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
2015 Forester XT, Tribeca
I would run the air/air IC till you get a hood.
I did see a air water IC for sale on ebay at about $160 so far. Search there too. Might be a better option for the stealth approach.
Larry
ImprezaRS dot com is offline   Reply With Quote
05 STi stock hood Aspen white without hood scoop subiebotz Exterior/Styling 77 06-05-2010 06:14 PM
FS in CT: MBP 02 WRX hood with or without hood-scoop with slight damage gling Exterior/Styling 2 06-16-2008 08:33 PM
FS in CT: MBP 02 WRX hood with or without hood-scoop with slight damage gling NESIC Private Classifieds 0 04-24-2008 11:21 PM
04 sti, vf 39, large tmic, small hood scoop? aschen Off-Topic 41 08-01-2006 02:05 PM
lookin for pics of sti's without hood scoops chibich Member's Car Gallery 50 02-13-2005 07:54 PM
