Mid Atlantic Impreza Club
Old 11-02-2009, 04:36 PM   #1
Blakestr018
Member#: 205647
2005 WRX
Exclamation Need Opinions On Build
I have a 05 Wrx with 124000 miles on the motor. All stock minus the intake and turbo back. I am still learning about this motor and it's needs so I need opinions. Not just bulls***. I am looking at possibly spending 12-1500 dollars. I don't know if I should just rebuild to stock and bank the rest for the future boltons or what. Thanks
Blakestr018 is offline   Reply With Quote
Old 11-02-2009, 04:44 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
did you get a tune for the intake and exhaust?
Old 11-02-2009, 04:52 PM   #3
madcatz
Member#: 187530
Fuk UrSelf
this
our cars/engines (I drive a Legacy, but have the EJ257) are finicky and need to be tuned for the parts....but it is drivable.....go ahead and ask me how I know Nov 10 cannot get here soon enough
madcatz is offline   Reply With Quote
Old 11-02-2009, 05:35 PM   #4
Blakestr018
Member#: 205647
2005 WRX
No tune AP is the plan come income tax money. My friend said he can port and polish my heads with a 3 angle valve job for 500.
Old 11-02-2009, 05:39 PM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
you got 2 options:
1. don't drive the car
2. get an opensource stage 2 map flashed
don't worry about the heads, they won't matter if you blow the engine before you even get a chance to install them. the money you could've spent on any other mods will go towards just getting your car back on the road.
Old 11-02-2009, 05:55 PM   #6
Blakestr018
Member#: 205647
2005 WRX
What if I were to rebuild the engine. Then a few months later get accessport? The main thing is down the road I want to push 300/300 reliably. But with 124,000 I am real skeptical. Would I be better to just wait it out 6 months and just do a Sti swap?
Old 11-02-2009, 06:08 PM   #7
MasterKwan
Member#: 98961
2003 WRX
Put the stock intake back in it and it should be fine till you get a tune. Sadly, $1200-1500 isn't going to buy you 300/300 or an STI motor installed. I doubt it'll even pay for refreshing the shortblock. Injectors and a turbo is about all I think that'll get you. Not including the AP.
Old 11-02-2009, 06:09 PM   #8
nhat
Member#: 140163
03 STi
hellaflunctional
nothing is going to be reliable as long as you don't get a tune...rebuilt engine or not. you can drive the current engine into the ground, spend money to rebuild it, and throw the same parts back on...but if you don't tune it right then, you're wasting a lot of money.
you skipped the part where he mentioned a turboback with no tune
Old 11-02-2009, 06:13 PM   #9
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Yeah, that's what I was going to say...
We are rebuilding what for $1,500?
You could possibly buy a turbo for that much, but forget motor...
Jard is offline   Reply With Quote
Old 11-02-2009, 06:20 PM   #10
MasterKwan
Member#: 98961
2003 WRX
05 is a 2.0. As long as he's not overboosting and has a stock intake, I don't see the problem. As long as the MAF is able to read airflow, the ECU will be able to compensate. I think the intake is the more dangerous of the mods. If you mess up the MAF calibration, you're really looking at a popped motor.
I was never a real believer in "tune for every change" mantra that Nasioc seems to follow.
Old 11-02-2009, 06:44 PM   #11
nhat
Member#: 140163
03 STi
hellaflunctional
everything i've read has stated that only the 02/03 ecu is able to handle no tune. yada yada yada CL/OL delay...wasn't aware the 04/05 wrx 2.0 could do it as well...
Old 11-02-2009, 06:52 PM   #12
MasterKwan
Member#: 98961
2003 WRX
Every car has some leeway built into the tune. That's why the overboost limits on the 2.0's (in the ECU) are 17 something PSI even though stock boost is 14ish. In closed loop, the ECU is looking at the front AF sensor and the MAF to know how much fuel to inject. In open loop, it's just looking at the MAF and squirting fuel based on measured airflow and requested AF ratio in the ECU load/RPM table.
I think about how all that works and assume the ECU can compensate for more airflow automatically. You're correct though that the OL/CL delay will delay when it transitions to OL though. Maybe I'm comfortable because I've zeroed out the OL/CL table in my 05 ECU.
Well, he's not popped it yet and I assume this isn't a new change so, I think in practice it seems to have worked out for him.
Old 11-02-2009, 07:12 PM   #13
TurbojonLS
Member#: 38772
2 Cars, No Bling
The 04/05 2.0L motors have a long OL/CL delay, much longer than the 02/03s. Some people have logged 5 seconds of PTFB OL fueling before the switch.
TurbojonLS is offline   Reply With Quote
Old 11-03-2009, 07:12 AM   #14
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Get a tune and spend the rest on suspension. Sways. Koni Inserts or d-specs with good springs. And whatever bushings you can replace.
Old 11-03-2009, 09:28 AM   #15
RicerJim
Member#: 39824
SPB- I'm waaay more
shower pocket than you!
This.
RicerJim is offline   Reply With Quote
Old 11-03-2009, 08:17 PM   #16
Blakestr018
Member#: 205647
2005 WRX
Ok so I understand the tuning process. I will get that asap. So then comes the engine. I go on deployment for 3.5 months I am looking at what I should do then. Would i be better off just rebuilding or better of just starting off with the sti block? A lil above or a lil below 300/300 to the wheels is the goal. I am afraid of putting more on a 124k engine.
Old 11-04-2009, 10:17 AM   #17
02blurex
Member#: 83678
2002 WRX PPG 1-4
fp green hta 477hp/449tq
1200-1500 isn't going to get you even close to 300 to the wheels reliably... you should also look at a clutch that could handle the power, a transmission upgrade to handle it (our transmissions suck), injectors, and everything else you'll need to do it reliably and safely... not to mention the stock turbo will not be able to get you to that kind of power so a turbo upgrade would be needed as well. There's a lot that goes into making power that a lot of people don't realize... start doing a lot of research about it and you'll find a lot of knowledge on these boards.
Like everyone else said a tune is the most important thing.
02blurex is offline   Reply With Quote
Old 11-04-2009, 02:55 PM   #18
Blakestr018
Member#: 205647
2005 WRX
Thanks for the insight everyone.
Old 11-04-2009, 03:42 PM   #19
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
A Tune then driving lessons with a certified instructor at a local track.
RALLYT-WRX is offline   Reply With Quote
Old 11-04-2009, 09:47 PM   #20
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
300WHP on that car will cost you at least 6K IF DONE PROPERLY..... probably closer to 8K.
Mav1c is correct, get an AP and suspension mods if 1.5K is your budget limit.
gagliano is offline   Reply With Quote
Old 11-05-2009, 09:56 AM   #21
02blurex
Member#: 83678
2002 WRX PPG 1-4
It would be nice to get some quality tires too... they play the biggest role in handling.
Old 11-05-2009, 10:08 AM   #22
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
I would say an open souce reflash would be your best bet if you plan on staying stock turbo.
For the price of the AP, you can get a quality road tune done at DPS.
After that, everyone else is right, make it turn faster... Struts (Seriously, at 124k your stock struts are DONE), springs, and a big front sway.... Nice tires, alignment, and enjoy!
Abnormal is online now   Reply With Quote
Old 11-05-2009, 10:12 AM   #23
ProDarwin
Member#: 134943
94 SW2, 95 SW2
9(?) Lemons Car
Wait, what?
Rings, bearings, hone, maybe even pistons+overbore... That can't be more than like $500
ProDarwin is offline   Reply With Quote
Old 11-05-2009, 10:28 AM   #24
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
Seriously? Really? Are you high?
Super 16G or a normal/small 18G, w/ 650 injectors and a tune will get you close to your HP goal. Hell, even a VF series turbo tuned aggressively or with water/alk injection will get you there.
Its not ideal but you can still use your stock TMIC, though I would look at a STi TMIC at the very least.
650-1000 for the turbo
200-300 for the injectors,
200-300 for OS tune or AP + tune (700)
How does that resemble 6K?
To the OP, the best overall thing you can do to your car for that much is spend some time on the classifieds here. See what you can get cheap and go from there.
Absolutely find a cheap APV1 and run a St2 map.
Then look for (sort of in order, but when you find a deal, jump on it):
Better wheels/tires (not huge since you are leaving before next summer)
Decent shocks (Koni Yellows, D-specs)
Shifter bushings +SS
F/R sway bars and end links.
steering rack bushings
Brake pads
DiscoGsus is offline   Reply With Quote
Old 11-05-2009, 10:30 AM   #25
MasterKwan
Member#: 98961
2003 WRX
$500? That won't even buy the parts much less the machine work.
Pistons will cost you $429 for some weiscos.
Stock pistons and rings are about $300.
Gasket kit - $218
Bearings - $131
Replace the head bolts - can't find the cost. Probably $100
Head gaskets are $40 each. I don't know if the gasket kit includes them or not.
That doesn't include taking the motor out, disassembly and re-assembly. I'm skeptical the OP has the skillz to do this major surgery. I've refreshed a motor before. You'd be shocked by how much you forget you need and get nickel and dimed for.
To sleeve or not to sleeve? also need opinions on my build!!!!! STiGuy23 Built Motor Discussion 23 06-05-2010 11:55 PM
Need opinions on N/A build hybrid gti 2 Normally Aspirated Powertrain 4 04-05-2010 09:55 PM
Need opinion on if a turbo is right for my build up. DoctorNick Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-09-2002 11:38 PM
Need opinion on Diamond Audio sub's, and opinion on choosing a sub! well_armed Car Audio, Video & Security 12 04-18-2002 01:56 PM
Help...your opinion on building a 2wd Impreza Civic SiR! ZenDriver Normally Aspirated Powertrain 3 02-02-2001 07:54 PM
