Alaskan Impreza Club
Old 11-02-2009, 06:24 PM   #1
subarustate
Member#: 82314
2005 WRX STI wannabe
Darkness
Question Unmarry?
Do I need to unmarry my AccessPort before taking my car into IM?
subarustate is offline   Reply With Quote
Old 11-02-2009, 06:28 PM   #2
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Aspen White, WRB interior
You shouldnt have too unless your making you car back to stock. If you unmarry it from your car and you have mods that will change your A/f ratios that could cause problems.
coqui2004miguel is offline   Reply With Quote
Old 11-02-2009, 06:55 PM   #3
subarustate
Member#: 82314
Darkness
Ok...since I bought the car two years ago in it's current Stage 2 form, I haven't needed to get it IM'd, until now. Actually, the regular tags expired earlier this year, so I put temp tags on, for the time being. In any case, my temp tags aren't any good past yesterday, so I'm trying to figure out how to go about getting it to pass IM. Mods include TBE(to the back axle, anyway), uppipe and downpipe(and of course the AP). I've thought about borrowing someones stock exhaust and swapping it out just for the purpose of the test but I'm just curious what the easiest way to take care of this is. Any feedback would be greatly appreciated, as I know I'm not the only who has run into this!
Old 11-02-2009, 07:08 PM   #4
07_BluRex
Member#: 127922
2012 VW Golf Mk6 TSI
Supercharged AND Turboed!
Put it back to stock map, and take it down to a no pass no pay place and just have them test it and see. If they comment about the exhaust or other parts then you'll have an idea what to fix and then take it and try again. I'm betting they might not even notice the parts. From what I've heard about the way some of the Anchorage IM places work they sometimes don't pay much mind to anything as long as sniffer and obvious main visual passes.
07_BluRex is offline   Reply With Quote
Old 11-02-2009, 07:17 PM   #5
Intelligent Hoodlum
Member#: 158099
04 STi
I just took my car in on Friday to get IM'd. I have the TBE and stage 2 mapping and it passed just fine.
Intelligent Hoodlum is offline   Reply With Quote
Old 11-02-2009, 07:33 PM   #6
subarustate
Member#: 82314
Darkness
Is your uppipe catted?
Old 11-02-2009, 07:36 PM   #7
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
the stock 04 uppipe was not catted... so unless he added a catted UP, then no cat.
Arctic Assassian is offline   Reply With Quote
Old 11-02-2009, 08:12 PM   #8
Intelligent Hoodlum
Member#: 158099
04 STi
I have the stock up-pipe.
Old 11-02-2009, 08:15 PM   #9
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Without catted pipe = fail on sniffer and visual if the tech knows what he's looking for.
TurboSetch is offline   Reply With Quote
Old 11-02-2009, 08:19 PM   #10
retrac
Member#: 217208
Even if the car has the readiness monitors forced on and they do an OBD-II only?
My truck passed with no cats, cat efficency codes deleted, and a huge cam.
retrac is offline   Reply With Quote
Old 11-02-2009, 09:53 PM   #11
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
You'll pass man, Fbks IM Tech's usually don't know what they're looking at. Just go across from the DMV.
Big-Sexy907 is offline   Reply With Quote
Old 11-02-2009, 10:14 PM   #12
sol0
Member#: 152976
MkVI Jetta TDI, EF6
CRX, del Sol SiR
My WRX passed IM when I bought it, and it was stg II also. If your car is setup like mine, when they sniffer test it, they only take it to 25mph on the rollers, so you'll never get into boost. I'm pretty sure my car would pass right now with the VF39 and COBB TBE
sol0 is offline   Reply With Quote
Old 11-02-2009, 10:18 PM   #13
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
My car did NOT pass im with stock headers, sti uppipe, hks catless dp, and cobb cbe. FYI
Marlons101 is offline   Reply With Quote
Old 11-02-2009, 10:49 PM   #14
sol0
Member#: 152976
MkVI Jetta TDI, EF6
CRX, del Sol SiR
ooo. I do have a STI uppipe. At least I have a lil' cat in my DP. Hopefully that is enough
Old 11-02-2009, 11:12 PM   #15
subarustate
Member#: 82314
Darkness
Hahaha, new problem! I pulled into Peger Road I/M and hooked up my AP and upon trying to flash the stock map, the AP says that it cannot communicate with the ECU! However, if I have it read what map it's running, it's able to tell me that I'm running the Stage 2 V91 map. Hmm.
Old 11-02-2009, 11:14 PM   #16
sol0
Member#: 152976
MkVI Jetta TDI, EF6
CRX, del Sol SiR
I have had this problem as well. Did you connect the two green connectors under the dash that put the ECU in the reset loop? It could just be that simple.
Old 11-03-2009, 12:27 AM   #17
subarustate
Member#: 82314
Darkness
I didn't. I'll have to try that, tomorrow. I'll post my results, then.
Old 11-03-2009, 01:26 AM   #18
Alaskan_awd
Member#: 117002
2010 >40psi, oh yes!
POWERSTROKE
If you unmarried the ECU without a cat you will most likely show a CEL, the AP hides it when it is installed. I think it is a cat efficiency code or something, it has to do with the rear O2 sensor seeing that there is no cat.
Alaskan_awd is offline   Reply With Quote
Old 11-03-2009, 06:25 AM   #19
kbeefy
Member#: 197417
no more subaru
mostly dirty
HTML Code:
<<<@!1!@>>>
only if you want to loose half your stuff!!
kbeefy is offline   Reply With Quote
Old 11-03-2009, 06:26 AM   #20
kbeefy
Member#: 197417
no more subaru
mostly dirty
quote fail. darn phone.
Old 11-03-2009, 01:50 PM   #21
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
All of your deleted CEL codes will start to show up if you remove that tune.
Back to the top..Why do you want to unmarry it? The car will be tested in closed loop which is EXACTYLY the same between the stock tune and that cobb tune. The car will use the front O2 sensor to keep the fuel at 14.7:1 for the entire test as long as you don't get above 4000rpm or so and just gentle throttle.
If you really want to unmarry it, I will reflash your ecu to remove the codes with the stock tune. Just drop me a PM if you want that done.
Old 11-03-2009, 04:51 PM   #22
subarustate
Member#: 82314
Darkness
Ok, no. I really like my tune, as is. I still don't understand why my AP can tell me which map I'm reading, but can't communicate with my ECU when I try to change the Realtime map. The I/M test went the same way, saying that it couldn't communicate with the ECU. Bad OBD II? I have no idea...
Old 11-03-2009, 05:33 PM   #23
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Hmm sounds like it could be a wiring issue. The AP just knows the last tune flashed it isn't actually reading.
Port could be blown. Not sure. Might need a new ECU. You don't need the green connector jumped unless you are reflashing. Reading works fine without this. I don't know but there may be a fuse for the power to the diag port. <<More research required...google search like this >> site:nasioc.com whatever you want to search for << Googles search just on nasioc specific is better then the nasioc search itself...lol
Old 11-04-2009, 05:32 PM   #24
Arctic Assassian
Member#: 91875
91 legacy TD04
Call cobb. They will help you.
Old 11-04-2009, 07:08 PM   #25
retrac
Member#: 217208
Check the SBF-5 Underhood fuse for OBD-II power.
Help with unmarrying the AP V1 or not unmarrying it! DJS_02_WRX Newbies & FAQs 12 10-18-2009 09:53 AM
WTT: 02-03 AP v1 unmarried for 02-03 UTEC unmarried jus10 MAIC Private Classifieds 2 05-04-2007 06:06 PM
Help! Unmarrying AP now car won't start! ScoobyNubieToo! Engine Management & Tuning 7 03-09-2005 10:38 PM
How to unmarry my AP STUDAndring General Community 16 11-19-2004 10:54 AM
FS- Cobb AccessPort - Unmarried Warmwaffles Private 'For Sale' Classifieds 5 05-23-2004 02:22 AM
Message Board Statistics All times are GMT -4. The time now is 03:52 AM.
