Old 11-02-2009, 08:26 PM   #1
DuCash
Member#: 198714
04' JDM STi EJ207
437whp/357wtrq Dom3 24psi
Default Dyno Tuned:JDM-STi.EJ207.Dom3(3" Inlet/10cm Hot-Side).430+whp.350+wtrq
Event: Dyno Pull
Ambient Temp: Tropical
Elevation: ~500ft
Weather: Tropical
Car: 04' JDM STi
Tuner: Ian Galibreth aka Swiffy
Dyno Info: DynoJet
Peak HP at RPM: 437whp @ 7,000rpm
Peak Torque at RPM: 355wtrq @ 5,900rpm
Baseline hp/tq for a stock on same dyno: 230whp
Target Boost: 24.5 psi
Target AFR: 10.9 - 11.2
Fuel: 90 Oct + 100%Meth
red-08mods blue-09mods
Engine/Power Modifications:
- Fujitsubo Power Getter 3" Exhaust
- Zero Sports Radiator Cooling Panel
- Custom Grounding Kit
- Perrin Crank Pulley
- Cosworth Oil Pan Baffle
- Walbro 255 lph High Pressure Fuel Pump
- Samco Sports Radiator Hoses (Black) with Stainless Steel T-Bolt Clamps
- Cusco Radiator Cap * 2
- Cusco Motor Mounts
- Fluidyne Aluminum Radiator
- AMS Lightweight Battery Kit
- Gizzmo Thermal Intake Manifold Gasket
- Perrin Top Feed Fuel Rail Kit - Black
- M Factory Oil Cooler & Filter Relocation Kit
- Perrin FMIC Kit (Stealth Black)
- Synapse Synchronic BOV (w/ Anti- Stall Valve)
- Fuel Injector Clinic Top Feed Injectors 876cc
- Gates Timing Belt
- Cosworth Timing Belt Guide
- Cosworth High Pressure / Volume Oil Pump
- AEM 5 Gal. Meth Tank
- AEM Meth Check Valve
- Gruppe-S Equal Length Headers S/S
- Grimmspeed Up-Pipe w/ 44mm EWG Flange S/S
- Synapse 50mm External Waste Gate
- Blouch Dominator 3 Turbo 10 CM Back Housing (Single-Scroll)
- Perrin 3" Turbo Inlet Hose
- Invidia 3" Down Pipe S/S
- ACL Main & Rod Race Bearings
- Manley Connecting Rods
- Wiseco Pistons
- ARP Head Studs
- Gates Accessory Belts
- Crawford Air Oil Separator (sprayed wrinkle black)
- Greddy Profec B 2 Electronic Boost Controller
- PTP Turbo Blanket
- P&L Racing Custom 3" Cold Air Intake
Driveline & Suspension Modifications:
- Cusco Coil-overs Zero-2E
- Cusco 22mm Sway-Bars Front & Rear
- Cusco Chassis Brace Version2 Front
- Cusco Chassis Brace Rear Sub-Frame
- Cusco Rear OS Strut Bar
- Perrin Rear Lock Down Kit, which incorporates poly bushings for the rear diff, rear sub-frame and some additional bolts for the rear sub-frame
- Perrin Anti-Lift Kit
- Cusco Type OS Front Strut Bar
- Cusco Type-OS-T Rear Strut Bar
- Whiteline Poly Steering Rack Bushings
- Beatrush Pitch Stopper w/ Poly Bushings
- Drive Shaft Shop Rear Axle Kit Stage 2
- GT Spec Fender Brace
- Cusco Pillow Ball Mounts (Front)
- Whiteline Roll Center Adjusters
Other Modifications:
- Perrin Short Shifter
- Perrin Poly Shifter Bushings
- Cusco Tranny Mount
- Whiteline Poly Gearbox Bushings
- Excedy Stage 2 Clutch Kit
- ACT Prolite Flywheel
- STi S/S Braided Clutch Line
- ATE Super Blue Fluid
-The turbo is a 3"Inlet with the newer 10cm hot-side...
-The heads are 100% stock...
-We usually street tune but we opted to dyno tune the car, there were a couple things we wanted to try with the new set-up that we needed to see the benefits or the downfalls of...I'd say we're almost there, the are in between 4,000-5,200rpm needs to be and will be worked on...it doesn't feel as laggy as the chart makes it look...
-This is @ 24.5psi and it holds 24psi to redline...
Here's a couple 3rd and 4th gear dyno-pull vids...
3rd:
4th:
DuCash is offline   Reply With Quote
Old 11-02-2009, 09:41 PM   #2
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
Nice breddah. Good to see you guys over in JA doing big tings.
csmithwrx'05 is offline   Reply With Quote
Old 11-03-2009, 08:17 AM   #3
DuCash
Member#: 198714
04' JDM STi EJ207
We're just having fun...
I'll be posting a couple on road videos soon...
Old 11-03-2009, 11:34 AM   #4
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Nice numbers. What do you guys think of the 10cm?
godforbid67 is offline   Reply With Quote
Old 11-03-2009, 01:37 PM   #5
DuCash
Member#: 198714
04' JDM STi EJ207
As far as i know its the only Dom3 in the island with it...the gains made up top compensate for the losses in the low end...i truly believe its the main reason the power stays above 400whp once it gets there...
I'm still amazed with how the stock heads flow...it leads me to think what would happen if cams, p&p, springs, retainers and 1mm oversized valves were thrown into the equation...
On the road, according to the logs i'm making 24.5psi by 4,450rpm in 3rd...but the AVCS is the saving factor in terms of response...plus i believe with the 10cm hot-side will begin to make even a bigger difference once to boost is turned up to 28psi...
Within the next 2 weeks the boost will be turned up to 28psi...so we'll see what happens, i'll post the dyno graph for that...theres a big drag race event at the end of the month that i'll be entering so 1/4 times are soon to follow...
Old 11-03-2009, 01:57 PM   #6
godforbid67
Member#: 137168
06 Built SGM WRX
That isnt too bad at all. My car spools around the same.
Yeah, once you turn up the boost the gains will be huge. I think that turbo could hold ALL the way to redline. With built heads it could make some serious power up top.
Looking forward to the results!
Chris
Old 11-03-2009, 02:38 PM   #7
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Nice! Looks like it turned out beautifully...those stock heads are amazing, even just cams would yield some good gains. The ports/valves are pretty big from the factory, so you may not even need to mess with those.
zeropsi is offline   Reply With Quote
Old 11-03-2009, 03:50 PM   #8
bones sti
Member#: 205318
Good numbers man car sounds awesome. Really looking forward to the follow up on 28 psi. Keep up the good work Swiffy
bones sti is offline   Reply With Quote
Old 11-03-2009, 03:51 PM   #9
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Cool thread. Nice power, looking forward to your track results!
STi Mikey is offline   Reply With Quote
Old 11-03-2009, 06:17 PM   #10
bertune
Member#: 107290
So u a move, gwaan Ducash
bertune is offline   Reply With Quote
Old 11-03-2009, 08:09 PM   #11
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Would you post a screen shot or log of the AVCS timing? I am curious how it looks with the 10cm.
Thanks!
TurboSetch is offline   Reply With Quote
Old 11-03-2009, 10:32 PM   #12
SharpShifter
Member#: 101484
2002 jdm sti {gt35r}
sti blue
the car is pulling nicely
SharpShifter is offline   Reply With Quote
Old 11-04-2009, 10:31 PM   #13
DuCash
Member#: 198714
04' JDM STi EJ207
Chris
I can't wait to see dyno #'s and feel the result of the 28 psi tune...
I'm sure that a cam upgrade would yield some interesting results...but there's more left in this set-up so I'm going for the rest of the horses in the stable...lol
Just trying to keep up with you...
Thanks!
I'll do it when we go for the 28psi tune, we have been forced to go ethanol out here now so I'm due for a retune anyway...where running E1090 out here as of tomorrow...
The AVCS cams where turned to 0* @ 5,000rpm in the 24.5psi tune...
Old 11-07-2009, 10:07 AM   #14
DuCash
Member#: 198714
04' JDM STi EJ207
Plan on getting retuned this weekend for the E10 90 gas we have now, the boost will be turned up to a min. of 28 psi...lets see how the bigger hot-side reacts...
Old 11-28-2009, 10:04 AM   #15
DuCash
Member#: 198714
04' JDM STi EJ207
I had a run against a friend of me who drives a JDM EVO VII with FP RED Tuned @32psi, i was running 30psi that night....we did standing starts, 1st gear and 2nd gear rolling starts...
He got his ass handed to him everytime...i even gave him the jump a few times and by 3rd gear i passed him...
I'm loving the new 10cm back housing...the top-end power is amazing...i can only imagine how the billet wheel version would perform...
Old 12-05-2009, 04:46 PM   #16
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
Smile dom 3 on a ej207 non avcs though thoughts
Ducash,
I have a V5 sti conversion in a GC8 (conversion done by Rallispec in NJ).
The V5 is a EJ207 but no AVCS.
I am looking for a turbo that would take advantage of the forged internals and higher redline of the engine but not immensely long spool up. I understand there is tradeoffs for higher output on a 2.0 .
Would you recommend the Dom 3 for my purpose?
We have 93 octane available and I have a greddy profec e-01 dual stage boost controller if that would help boost curve a little.
jkjersey is offline   Reply With Quote
Old 12-12-2009, 11:25 AM   #17
Ralliart4
Member#: 135927
2002 Impreza WRX RA
Jody, I was talking to Dimetri and he was telling me about a SR20 on the toll road please advise lol.
Ralliart4 is offline   Reply With Quote
Old 12-12-2009, 07:58 PM   #18
DuCash
Member#: 198714
04' JDM STi EJ207
Originally Posted by jkjersey View Post
Ducash,
The Dom3 would be perfect for your set-up, a friend of mine is about to run the same set-up on his 95' JDM Impreza Type RA...
The extra rpm of the EJ207 will do the trick, put it this way even if your spooled by 4,500rpm you'd have close to 4,000rpm of boost which is alot...
Let's not forget your carrying around alot less weight with your chassis...
PS. you should look into the AVCS
We passed him at 200km in 6th gear in vacuum...lol...
Dmitri got to see what cruising really is...
Old 12-12-2009, 11:04 PM   #19
KurtP
Member#: 44836
1999 Fozzy
Nice numbers. Looks like the motor is ready for a little more cam......
KurtP is offline   Reply With Quote
Old 12-13-2009, 01:38 PM   #20
DuCash
Member#: 198714
04' JDM STi EJ207
It definitely needs some cams, but i want to see how far the stock heads will go on this set-up before i move on to doing the head...
I see Kelford in my future...lol
Old 12-14-2009, 09:40 AM   #21
wrxwangjack
Member#: 205472
I love what you put in for weather up top Tropical... Its been a while since Ive been back to the motherland "JAMDOWN"!
wrxwangjack is offline   Reply With Quote
Cosworth & APS FTW Dyno Flash STI @ 704 whp and rising! alfriedesq Proven Power Bragging 2089 12-04-2014 03:13 PM
Sreet Tune, Dyno Results: JDM STi EJ207 Blouch Dom3, dyno video too DuCash Proven Power Bragging 46 11-01-2009 11:25 AM
PERRIN 08 STI Intake and Inlet Hose Dyno Results..... PERRINJeff Proven Power Bragging 18 03-21-2008 01:02 AM
Hit the dyno today, 306 whp, 350 torque.... reddevil Proven Power Bragging 4 03-09-2008 06:13 AM
430 whp pluss power package for sale koki Private 'For Sale' Classifieds 5 02-14-2005 05:30 PM
