Old 05-14-2002, 05:24 PM   #1
jack_uw
Member#: 8212
2001 2.5RS SEDAN
Silverthorn
Default Is it bad to not step on the clutch all the way?
I have this habit of being lazy and not stepping on the clutch all the way when I'm at a stop light for instance. I push it enough so that the car does not rool when I release off the brake petal. Some one told me this is bad for the clutch. Is it?
Thanks!
jack_uw is offline   Reply With Quote
Old 05-14-2002, 10:17 PM   #2
WizardBlackWRX
Member#: 14979
It is hard to say for your particular car, but in general, a new car doesn't have to have the clutch pressed to the floor to be completely disengaged, but just because you are not rolling at a particular light does not mean that there isn't a tiny bit of slip going on. It can add up. I came from (among other things) 2G DSMs. Consequently, I always pull it out of gear and sit at the light in neutral without touching the clutch.
WizardBlackWRX is offline   Reply With Quote
Old 05-15-2002, 12:30 PM   #3
goobie
Member#: 8273
2006 WRX Wagon
Question Why do people do this?
If I understand your post correctly, It seems that you slip the clutch a little to hold your car from rolling as opposed to using the brakes and putting it in neutral. I have to ask the question: Why?
What you are doing is every so slightly engaging the clutch. This will cause extra wear on the disk and also the possibility of glazing the disk which will eventually cause the clutch to slip under accelration/engine braking.
For what time it takes to put the car in neutral, release the clutch and hold the car with the brakes at a traffic light IMO is far better than causing extra wear on the clutch.
Chad
goobie is offline   Reply With Quote
Old 05-15-2002, 12:57 PM   #4
crayon
Member#: 16073
2002 WRX Sport Wagon
WR Blue
Default Re: Is it bad to not step on the clutch all the way?
Thanks!
This will destroy your clutch in short order. It will most likely, destroy the flywheel and throw out bearings as well.
My advice...Stop now before you cause further damage.
crayon is offline   Reply With Quote
Old 05-25-2002, 09:53 PM   #5
WizardBlackWRX
Member#: 14979
Ah, I just reread his post. Indeed, if you are slipping the clutch to keep the car from rolling backwards you are wearing the clutch and FW badly.
Is it bad to run Staggered on AWD??? Silver'04 Tire & Wheel 25 05-01-2008 11:23 PM
Is it bad to drive with DCCD in manual all the way back daily? elitescouter Newbies & FAQs 6 03-27-2008 04:44 PM
is it bad to not be hungry for 28 hours? Protege Menace Off-Topic 20 04-05-2005 02:50 PM
do i have to push the clutch all the way down? b_tapper Off-Topic 29 04-21-2003 04:16 PM
is it bad to rally-x on steel wheels? FlooredSubaru Motorsports 22 01-14-2002 05:19 PM
