Old 11-02-2009, 11:31 PM   #1
iboost808
Member#: 223849
Default Wrx Trunk Lock
I was wondering how everyone swaps their locks on the trunks because I don't know how to remove the lock and put it on the new trunk I am receiving. Any help will do, thanks.
iboost808 is offline   Reply With Quote
Old 11-03-2009, 11:18 AM   #2
ROFLBOXER
Member#: 188503
2003 Built EJ257 WRX
2.5xtr+W2A IC
Basically, when you look at the inside of your decklid, there should be the glow in the dark handle in case you "accidentally" lock someone in the trunk.
There are 5 twist-tabs to remove on that, then just pull that away so it hangs down. If you need this for your new trunk, rotate it so you can pull out the metal cable.
With the handle removed, you should be able to see the backside of your lock. there is a plastic peice (orange on mine) that you need to unclip from the connecting rod, and then pull the rod out.
Now all that is holding your lock in is a "U" shaped metal bracket. You just need to grab the edge of it that sticks up, and shimmy off of the lock.
Your lock should now just slide out the front of your trunk, and you can reinstall it by going through these steps backward for the new trunk.
Hope this helps.
ROFLBOXER is offline   Reply With Quote
Old 11-03-2009, 11:41 AM   #3
Anderscene
Member#: 193796
^^^ amazing explanation (:
+1 for you sir
Anderscene is offline   Reply With Quote
FS : 05 sti bbs/psm wrx trunk shift0246 Tri-State Area Private Classifieds 4 06-12-2010 07:28 PM
Help: Taking trunk lock off trunk PSM_02_WRX Mid Atlantic Impreza Club -- MAIC 13 09-20-2009 07:43 PM
wtb: door locks, trunk lock, and ignition slot with keys and remote system for 02 wrx M.R.blue Private 'Wanted' Classifieds 2 03-30-2007 11:41 PM
Trunk Lock (sedan) WRX Wheels Warranty Issues & SOA Problems 0 10-15-2001 03:23 AM
