Old 11-02-2009, 11:40 PM   #1
snake32
Member#: 167338
02 Silver dollar
Default EMU on EJ18
i have the turbo installed on the car now, it's a 97 EJ18 with ej22T heads on, the thing is i don't know how to install the emu, if someone here have done the diagram to plug this thing to my stock ecu and if wants to share some info, i would love that!
i have a set of 550cc side feed yellows waiting for this too, i'm located in south jersey and looking to get my car tuned asap!
where i can go for a good tune in south jersey????
snake32 is offline   Reply With Quote
Old 11-03-2009, 06:09 AM   #2
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
Try Skidds DIY for his car. Great write up and I used most of it to follow.
Just find the ecu pin out for you car.
http://www.ludicrous-speed.com/wiki/...C_Build_Part_5
freeride is offline   Reply With Quote
Old 11-03-2009, 05:39 PM   #3
ScoobieBlue18
Member#: 214557
1997 ej18t Impreza
Not WRB
snake32: I also drive a 1997 impreza brighton. i currently have just a K&N intake and a stromung manifold back exhaust. im looking to add some power to my car. i was told by someone a while ago that both ej18 and ej20 have the same esencial block and head setup. So i started thinking that i could possably just buy the full stock WRX turbo setup and then just get my car tuned for about 10psi of boost and buy an ECU. from your experience does this sound like it would work or is it way harder than that? or would possibly swapping in an ej207 be easier? it would be great if you could let me know if you had any problems with your project.
thanks,
scoobieblue18
ScoobieBlue18 is offline   Reply With Quote
Old 11-03-2009, 08:57 PM   #4
Meat Supply
Member#: 137902
---- among the
lost we all shall survive
anyone want a 1.8L with 126K miles for super cheap?
Meat Supply is online now   Reply With Quote
Old 11-04-2009, 12:02 AM   #5
beaun-nus
Member#: 134629
'99 2.5rs
black
you have to have dual port heads to run a wrx setup. The wrx ecu does not work on a ej18 harness.
beaun-nus is offline   Reply With Quote
Old 11-04-2009, 12:32 AM   #6
snake32
Member#: 167338
02 Silver dollar
thanks,
scoobieblue18
well, i did the ej22t heads on my setup, this allow me to run at least 18psi, u can just leave everything stock and run 10psi, on rs25.com is a bunch of guys running ej18's with a good amount of boost.. i was my idea just bolt up an wrx turbo kit, and run 5-7psi without EM, but then i saw this guy running 20psi on his ej18+ej22t heads and i decided to go that way too... my car is running with the stock injectors now, this is until i can get EMU installed...
i'll say boost the hell out of that ej18, there's no other way u can add power to this engine...
a wrx turbo kit it's the best for budget! under $1000 u can have some fun for sure!
Old 11-04-2009, 12:34 AM   #7
snake32
Member#: 167338
02 Silver dollar
ej18's are dual port..
Old 11-04-2009, 07:36 PM   #8
ScoobieBlue18
Member#: 214557
1997 ej18t Impreza
Not WRB
so you think that it would be better to just get some ej22t heads? Are you running a stock WRX turbo setup or one off of a carborated ej18? what do you think the max boost i could push without harming my engine?
Thanks for the help,
Scoobieblue18
Old 11-04-2009, 08:34 PM   #9
snake32
Member#: 167338
02 Silver dollar
If i were u, i'll stay on a stock motor and run 5 or 6 psi, cheap power!! Lol! I have done flywheel, crank pulley, ej22t heads, clutchmasters stage 3, ebay header and downpipe, and gaskets, turbo waterpump, new timing belt.. Etc. Damm! It cost me good money, now i know why the others prefer a swap!
Old 11-04-2009, 11:08 PM   #10
nkx
Member#: 96951
2004 wrx sedan
'10 Outback 6mt-wifey's
Scoobieblue18
if by carborated ej18 you mean ea82 (the 1.8 found in the loyales), those setups are different from a wrx. ea82 turbo was mpfi, but had single port exhaust, and a crazy shaped turbo compressor outlet. also, since the ea82 is the old style motor, heads from one of those are probably not going to bolt up correctly to an ej shortblock.
nkx is offline   Reply With Quote
Old 11-05-2009, 07:14 PM   #11
ScoobieBlue18
Member#: 214557
1997 ej18t Impreza
Not WRB
Okay. so next summer i was planing on putting in a more aggressive clutch becasue the stock one is pretty girly and while im there put in a lighter flywheel. but now im starting to think that it will be easier but a little bit more expensive to just swap in an ej207 or something of equal power, than it would be to boost my engine and then put in an aftermarket clutch and flywheel? if i do swap in an engine, is there any type of plug-in wiring harness or does it have to be done by hand?
More discussion on WRX EJ20 heads on EJ18 block required... Kostamojen Subaru Conversions 18 11-23-2003 04:03 AM
S-AFC on EJ18 car?? does it work? supermoose Normally Aspirated Powertrain 4 05-25-2003 09:29 PM
SFAC on EJ18 ecu to run EJ25d??? supermoose Engine Management & Tuning 1 05-24-2003 09:33 PM
Installed Borla on EJ18 and an idea for 2nd cat eliminator pipe Kostamojen Normally Aspirated Powertrain 7 01-19-2003 04:45 AM
In which direction is the throttle body on EJ18? tonytiger Normally Aspirated Powertrain 1 03-23-2002 02:57 PM
