Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 11-03-2009, 02:00 AM   #1
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Default Road Tune: 2.5L + FP Green (interesting differences in tuning strategies)
Event: Road Dyno
Ambient Temp: 55*
Elevation: 2700 ft
Weather: dry and mildly cold
Track and Conditions: CA 178
Tires: bridgestone RE01's
Car: 2006 STi
Tuner: Phatron
Dyno Info: Airboy
Peak HP at RPM: 378 whp @ 5930 rpm
Peak Torque at RPM: 386 wtq @ 4730 rpm
Baseline hp/tq for a stock on same dyno: 179 whp / 235 tq (sti)
Target Boost: 26 psi target in rom, 24 psi target after altitude correction
Target AFR: Target 12:1 in rom, Actual 11:1 at redline. Due to dual meth.
Fuel: 91 octane + VP M1 methanol
Engine/Power Modifications: tbe, perrin headers, ur up-pipe with tial ext gate, fp green, tgv deletes, aquamist hfs5 dual meth, spearco tmic, hallman mbc+perrin ebcs, aps cai, aps inlet
Driveline Modifications: act street clutch, gruppes flywheel
Suspension Modifications: sti pink springs, beatrush engine tranny and pitchstop
Other Modifications: Audio integrations sub box and amp rack. spec-c 12L meth tank, stri gauges, lc-1
Old 11-03-2009, 02:11 AM   #2
crand002
Member#: 129765
2006 EVO
439whp/412wtq (MD)
Just to be clear the only difference is 100% meth opposed to 50/50? Was there a significant ambient temp differential?
One thing that could explain this difference is your previous AFR. Paul (Yimi Sport) informed me that he liked to run 50/50 leaner at redline than 100%. We would have to ask him to chime in but my AFR's at Redline are north of 11.5 at redline with 50/50.
crand002 is offline   Reply With Quote
Old 11-03-2009, 02:19 AM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
the "old tune" log was done 2 days ago at the same time at night. the new one tonight. I just re-hooked up my hybrid boost control tonight, so that was a difference too.....old tune log was with a Hallman MBC only.
Something has to be screwy. The engine loads on the old log dont match up with the boost levels. Same boost, lower timing, same temperature, same road, yet the Loads are completely different.
And my boost control got worse with the hybrid setup this time than with just the mbc. Im just dumbfounded and pissed off tonight.
Im gonna throw the rest of the meth in my gas tank tomorrow and do some more logs
Hopefully i'll be going to Famoso Raceway for test and tune saturday morning.....so i wanted to get some logs in and work out any bugs.
Old 11-03-2009, 02:27 AM   #4
socalLGT
Member#: 89752
08 STI
Someone broke in to your car and swapped on a set of ported heads and some cams while you were asleep last night Ron... duh!
Seriously, pretty tough to explain what you logged. It would also be quite strange to be able to get past MTBT on just pump and meth. Ambient temp probably explains part of it but not all of it. Perhaps as crand002 mentioned, when you were running 50/50 meth/water you might have actually been pumping in too much. If there was too much water, that was displacing air-fuel as well as lowering cylinder temps too much. Now that you are basically on straight meth, all your injection volume is combustible. Add in some colder denser air and you have a recipe for more power.
I usually run 50/50 meth/water cars around 11.8-12:1 AFR. The 100% meth cars I like around 11.5:1. Water has such a high latent heat of evaporation that you have to run it a bit leaner to avoid pulling too much heat out of the combustion chambers with the injection.
socalLGT is offline   Reply With Quote
Old 11-03-2009, 02:29 AM   #5
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Well, 7* is a big change, and if you were far past MBT, you'd be throwing off the VE, and thus airflow and load. Still, I'd bet there was something else going on, the meth, IAT's, not sure. Did you check all compensations?
Were those plots done with the same smoothing factor? I've found that just 1 point can make the same plot look like either of those two graphs.
Merp is offline   Reply With Quote
Old 11-03-2009, 02:32 AM   #6
socalLGT
Member#: 89752
08 STI
Oh and BTW, I believe the baseline numbers in Airboy are from an 06-07 WRX, not an STI.
Old 11-03-2009, 02:59 AM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
somethings wacky.....now i dont trust anything i did today.
I guess i'll just go out tomorrow and do back to back pulls and jack the timing back up on the 2nd one.
My meth still isnt 100% meth now. I have the 12L tank and it was about 1/4 full still with a mixture of VP meth, meth i got from a friend, denatured alcohol, and water. The 3/4 i just added was 100% meth.
Maybe i just found a good mix
I only had 3 beers tonight....maybe that was my problem.
Paul, are customers allowed to rent the dyno at yimi? If so how much is it an hour?
Old 11-03-2009, 03:25 AM   #8
socalLGT
Member#: 89752
08 STI
That's the problem right there Ron... don't you usually have at least a 6 pack in you when you are out tuning and logging?
The dyno is available for hourly rentals. PM me or give me a call for rates. I'll even drive the car for you and give you really bad advice
Old 11-03-2009, 03:30 AM   #9
socalLGT
Member#: 89752
08 STI
I just looked at your timing graph a bit more closely. There is no way you were past MTBT on your old tune. Aside from the wacky peak at 4750 then dip after that timing is roughly right. The "new" tune is way low on midrange timing for a meth tune running the boost and fueling target that you have. The timing values on the logs from tonight look more like straight pump gas numbers.
Old 11-03-2009, 11:11 AM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ that peak and dip is why all this started.
That is 1.4 FLKC in there. I havent tuned in so long i forgot that the FLKC doesnt zero out when you flash, it only does it when you reset the ecu.
So i kept lowering the timing.....still knocking.....lowered again.....still knocking....i finally looked at the 4 logs and noticed it was FLKC and that it was the exact same on all 4 runs. So i reset the ecu and did the last pull.
And I was thinking exactly that while i was lowering the timing. I was wondering if my meth was spraying.....but i can smell it in the cab.
Well, at least this makes me hopefull that i should pick up some more power adding that 4-7* back in the midrange.
Old 11-03-2009, 11:17 AM   #11
Bullwinkle1983
Member#: 172332
2006 WRX
What is the difference between intake temps between the two days tuning sessions?
Bullwinkle1983 is offline   Reply With Quote
Old 11-03-2009, 11:39 AM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
i can look at the logs when i get home, but iirc about 2*
old tune - 10-31-2009 between 10pm and midnight
new - 11-2-2009 between 9pm and midnight
it was in the mid 50's both times
Old 11-03-2009, 04:54 PM   #13
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Hrmm...
I think you need to WOT log on both maps again..
BUILTSTI is offline   Reply With Quote
Old 11-03-2009, 10:48 PM   #14
Phatron
Member#: 36033
CEO PhatBottiTuning
Just did the logs literally 5 minutes apart.
Old 11-03-2009, 10:53 PM   #15
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
which is which?
Old 11-03-2009, 10:58 PM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
sorry.... the higher midrange tq/hp on all 3 is the higher timing.
only difference between the two runs is the timing.
Old 11-03-2009, 11:07 PM   #17
2000max
Member#: 115558
2005 WRX
Was this all done on the same exact flat stretch of road?
2000max is offline   Reply With Quote
Old 11-03-2009, 11:08 PM   #18
Phatron
Member#: 36033
CEO PhatBottiTuning
yes. i use the same road everytime. have for about 2 years.
Old 11-03-2009, 11:08 PM   #19
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
I hate timing... . .
Junior2JZ is offline   Reply With Quote
Old 11-03-2009, 11:13 PM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ im probably gonna take it out. car doesnt really feel different w/o it.
still need to put in my wg spring and put on my greddy bov.
i want boost!!!! need atp35.
anyone got 1 fo sale?
Old 11-03-2009, 11:15 PM   #21
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
I rather make 20 less ftlbs and 20 less whp and know that it will always be consistent vs good for 1 or 2 pulls and then pulling timing.
Old 11-03-2009, 11:22 PM   #22
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
FP RED FTW!
Old 11-04-2009, 07:36 AM   #23
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Very happy to see you coming out to play again Ron. Did you take your car add offline yet?
STi Mikey is offline   Reply With Quote
Old 11-04-2009, 09:17 AM   #24
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Nice Ron, bet she rips
Kastley85891 is offline   Reply With Quote
Old 11-04-2009, 11:30 AM   #25
Phatron
Member#: 36033
CEO PhatBottiTuning
no. only one guy has even asked me about it.
i told him that i didnt even know if i'd take $28k (blue book +$3k) and i never heard back from him.
i have over $3k in stereo equipment alone. too much money to just give away. i'd venture about $20k total into the car.
im gonna search the classifieds for a Red, dom4 or atp35 for a couple months. then i'll be done. or start doin some suspension here and there
Dyno Tune: 2.5L, GT35R, E85-Tuned STI Makes 540whp! Cobb Tuning Proven Power Bragging 45 04-25-2013 04:42 AM
Break-in tune: 2.5L 9:1 CR EJ257 + GT35R = 430whp @ 15-16psi jays05 Proven Power Bragging 96 03-05-2010 08:36 AM
Road Tune: 2.5L + Dom4-XTR Makes 470whp on 91+meth Phatron Proven Power Bragging 77 02-25-2010 10:13 PM
Dyno Tune: 2.5L hybrid + VF39 makes 352whp on 92 octane *03wRx* Proven Power Bragging 8 11-08-2009 11:18 PM
Dyno Tune: 2.5L + ATP35 makes 360whp 2gnt2wrx Proven Power Bragging 12 10-31-2009 08:32 AM
