Alaskan Impreza Club
Old 05-14-2002, 06:18 PM   #1
WRXnFX
Alaskan Mafia
Member#: 10398
Default Understeer/Oversteer and handling
Lets talk about how ALK, endlinks, sway/strut bars, stiffer bushings, camber correction and suspension will affect your car in the handling and NVH department.
Let me start this off by asking is there a big difference in running PBMs and the solid mounts? I've heard that the solid versions cause more NVH but handle better. Is this true?
Winslow
WRXnFX is offline   Reply With Quote
Old 05-14-2002, 09:28 PM   #2
AutoXr
Member#: 2047
'04 Audi S4
Red
We're talking about bushings, right?
The solid versions handle better because there is less deflection in the suspension allowing it to work more efficiently. When a flexible bushing material is used, it stretches, or deflects under a load (cornering or hard acceleration) whereas a solid material keeps it's shape. This causes a couple of things:
1) Handling is more predictable since there are fewer moving parts and you are tuning the suspension, not dealing with the deflection in the bushings.
2) NVH is transmitted through the car significantly more since there is nothing to absorb it as there would be with a flexible bushing. Some people like this saying that they "feel" the car more while others can't stand it, commenting on the feel as "buzzy" or "jolting"
Most serious race cars have solid bushings since all out performance is what they are after.
Most licensed road cars have flexible bushings since living with solid bushings on a daily basis is not a tradeoff most people are willing to live with. Almost all cars directly off the showrom floor have rubber bushings which deflect significantly more than other materials such as poly or delrin.
Comments?
Next question please
AutoXr is offline   Reply With Quote
Old 05-14-2002, 10:33 PM   #3
WRXnFX
Alaskan Mafia
Member#: 10398
PBMs - Pillow Ball Mounts
Stock has PBMs and other companies like Cusco offer adjustable camber solid mounts.
So some bushings come solid (semi-metallic) rather than stiffer polyurethane?
I guess all stiffer suspension will cause more NVH but some are worse than others.
Has anyone had experience with motor mounts or transmission mounts such as the group N versions?
Give me a run down on the ALK and handling.
Winslow
Old 05-16-2002, 02:04 AM   #4
AutoXr
Member#: 2047
'04 Audi S4
Red
PBMs material should have the same effect on NVH as any other bushings. The solid bushings that I'm thinking about right now are spherical bearings that are used on sway bar end links.
ALKs increase caster by changing the suspension geometry up front. By getting more caster, you get a better bite when turning, especially when you get on the gas, hence, the designation "anti-lift kit". I haven't driven a car with one installed in it, but have heard rave reviews from several people. Some even say that it improves handling as much as adding an adjustable rear bar.
Other than caster, I can't see that it does much, but as I stated, I haven't even seen a car with them on it yet.
Mike Shields at SPD Tuning swears by the motor and transmission mounts along with the full bushing kit that he sells. Here's what he says about the Group N STI bushing kit on a road car suspension:
Stage 3. Rubber bits
Once the springs and shocks are in place the addition of the STI bushing set will give the car a very precise feel. This set included new motor and trans mounts, which improve the shifting and throttle response. Taking up the slack in the production bushings is perhaps a fine point for the $700 the set will cost, but it makes it possible to place the car very precisely on the cones when running an autocross route. The area it benefits the most is braking. An Impreza with WRX brakes, Prodrive suspension, P-Zero tires and the STI bushing set was tested at 105 feet from 60 mph. The lack of compliance in the bushings keeps the tires griping.
Old 05-16-2002, 08:54 PM   #5
RawCode
Member#: 3115
2002 Impreza 2.5RS
If you check around for engine and tranny nounts here on the board. You will learn that almost everyone raves about them.
Once I get new Tires I plan to get myself some new sway bars front and rear.
And I don't think stock has PBM. I mean have you seen the Cusco PBM;s? They are rather hard. The only thing stiffer than stock without going to metal plates is the STI Top mounts.
Check out http://home.att.net/~teaguesauto/suspensi.htm
to see the differences.
RawCode
RawCode is offline   Reply With Quote
Anyone going to TS Understeer/Oversteer this Sat/Sun? junk240sx North West Impreza Club Forum -- NWIC 13 06-13-2007 01:35 PM
Oversteer and understeer in daily driving? Rymep General Community 37 07-17-2005 05:09 PM
Car behind me sees me oversteer and decides to try and race me. Snoopy Off-Topic 98 05-20-2005 04:22 PM
roadholding capability effect by changing understeer/oversteer? gypsymoth Brakes, Steering & Suspension 2 07-01-2003 06:12 PM
Cold Snow tires understeer, oversteer, overcorrection lift throttle oversteer thump. munkis Tri-State Area Forum 11 12-31-2001 07:16 PM
