Old 11-03-2009, 12:13 PM   #1
bankguns
Member#: 113799
2002 Wrx
Aspen white
Default Help sti swap in wrx
Hi guys,
i just recently swapped my 2.0 for a 2.5 but my UTEC died on me, but i am wondering if i can still drive the car on the regular ecu with the boost pushed down. If not if any one knows about a tunner in orlando fl, who does open ecu... please some one help...
bankguns is offline   Reply With Quote
Old 11-03-2009, 10:26 PM   #2
Bug_i_Sti
Member#: 224598
if you did just a 2.5 long block (or shortblock) and still have the 2.0 ecu... i wouldnt try to drive it. You need to compensate for the injector difference and the .5 L
Bug_i_Sti is offline   Reply With Quote
Old 11-09-2009, 12:51 AM   #3
preza95
Member#: 229407
1995 Impreza ???
red
if you try to run the 2.5 on a stock 2.0 ECU, it will be sluggish and struggle in area it normally wouldn't, an you may be faced with engine problem if driven like that over any extended period of time,such as premature wear on the cams,valves,bearings and timing set. The stock 2.0 ECU won't allow the 2.5 sufficient air and fuel which can stress those parts over time. You may be able to buy a custom chip to make up the difference.
preza95 is offline   Reply With Quote
2.0 to 2.5 swap in WRX, need some help. Samurai_jim Built Motor Discussion 3 11-22-2008 10:37 PM
help... engine swap in my 2002 wrx jmodica Subaru Conversions 2 08-26-2008 11:36 PM
Help!!!! Jdm Swap In My 02 Wrx cowsbitepeople Subaru Conversions 1 12-08-2006 04:20 PM
STi swap in a 00 RS....HELP!!! jcarv20 Subaru Conversions 2 02-16-2006 10:52 PM
97 JDM sti swap in 97 impreza CEL flashes, won't hit full boost HELP WRXlerate Subaru Conversions 13 05-31-2005 12:30 PM
