Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 11-04-2009, 12:06 AM   #1
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
Default Dyno Tune: 2.0L + VF39 = 289.5HP ('04 WRX)
Event: dyno pull
Ambient Temp: ~75? september in socal
Elevation: 33ft
Weather: sunny
Tires: bfgoodrich g-force sport 225/45/R17
Car: 2004 WRX
Tuner: jon @ hbspeed
Dyno Info: dynomite
Peak HP at RPM: 289.5 @ 6500 RPM
Peak Torque at RPM: 273.4 ft-lbs @ 4500 RPM
Baseline hp/tq for a stock on same dyno: ~200/200 on 2.0L WRX
Target Boost: 19.5 psi
Target AFR:
Fuel: 91 unleaded
Engine/Power Modifications:
stock block (short block has ~7k miles, the rest is at 78k)
VF39
JDM V7 STI TMIC
STI Pinks
Walbro 255 FP
Gruppe-S V1 Header
Helix UP
Invidia V4 DWG Catted DP
HKS Carbon-Ti CBE
Accessport V1
Prodrive BCS
Driveline Modifications: none
Suspension Modifications: prodrive springs, 17" rotas
Other Modifications:
overall very happy with the tune. i wish i had that extra 0.5L to get the much better torque '06-'07 owners get, but i'm not complaining. difference between using the Cobb OTS VF39 map and this one is night and day
dLo R6 is offline   Reply With Quote
Old 11-04-2009, 12:28 AM   #2
preacher#1
Top Scoob 022
Member#: 129894
FSTI '04 4EAT Sierra
Gold Metallic 20G-XT, EWG
Lookin good!! yes you should have picked up a .5 ltr prior to tune. You running 19.5 on a stock bcs?
I will be seeing HB this sat for a re-tune...w00t!!
preacher#1 is offline   Reply With Quote
Old 11-04-2009, 12:47 AM   #3
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
oops forgot that - prodrive BCS
Old 11-04-2009, 08:35 AM   #4
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Fuel: 91 unleaded
Wildly optimistic dyno.
Still, an uncorrected 24Xwhp on 91 octane is nothing to sneeze at from a 2.0l. Good job!
Spenk is offline   Reply With Quote
Old 11-04-2009, 09:44 AM   #5
xsnapshot
Member#: 170973
2004 WRX 4EAT
I would've said a very conservative dyno. Baseline for a stock 2.0L WRX was 200/200. So he got a ~90 whp gain with all that. Stage 2 2.0L can get a 70whp just from a protuned stage 2.
How is that optimistic?
xsnapshot is offline   Reply With Quote
Old 11-04-2009, 10:22 AM   #6
bikerwriter
Member#: 113125
2005 Saabaru Stage 3
How is that optimistic? Let's see... The stock car was rated at 227 from the factory. The dyno shows 200 at the wheels. That translates to a 12% drivetrain loss. For an awd car. Sure. Very reasonable.
But the dyno is a useful tool for comparison purposes, and if he saw a 90 hp gain on the same dyno, then he has achieved a good increase even if his measuring stick reads high.
What he and you need to keep in mind is that with his 12% drivetrain loss factored in, his 289 whp car is only making 328 hp at the crank. His 289 whp doesn't mean he has 30-40 hp more than everyone else with a 2.0 VF39.
End transmission.
bikerwriter is offline   Reply With Quote
Old 11-04-2009, 11:56 AM   #7
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
if you guys want another comparison, my friend's stage 2 (2.0L '05) with UP DP and CBE made 240/231 on the same dyno. the 200/200 number i pulled off another car's chart who i don't know (same dyno tho).
Old 11-04-2009, 12:06 PM   #8
gogetr
Member#: 178631
02 shatdan
very nice.
i just put my car on the dyno on saturday. same type of dyno but i made a bit less than you. 266hp @ 6800 /255tq @ 4400
the only difference between our cars(besides year) is i have a v7 block, stock header(ported), stock up-pipe(gutted), catless dp, stock boost controller, 93 instead of 91 and a little less boost, no ap. and RA gears. so with that in mind, if everything else was damn close to the same, a header and up pipe = good gain.
gogetr is offline   Reply With Quote
Old 11-04-2009, 12:14 PM   #9
BlobeyeSTi
Member#: 187877
04 WRX STi
Nice Numbers!
Im looking to do pretty much the same thing this winter but on 93 oct and no cat on my dp so I'm hoping for over 300whp and over 280wtq.
BlobeyeSTi is online now   Reply With Quote
Old 11-04-2009, 01:10 PM   #10
DSM Nexus
Member#: 196985
2004 EVO VIII
Nice numbers, ill be taking my HTA 68 setup there as soon as I get my turbo inlet in the mail and on the car. (its still a 2.0 btw)
DSM Nexus is offline   Reply With Quote
Old 11-04-2009, 02:54 PM   #11
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
93 oct? Let us know what psi you run and the numbers you put down of course. A dyno graph will help also.
Subian is offline   Reply With Quote
Old 11-04-2009, 02:59 PM   #12
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Holy late spool Batman! That thing should be fully spooled a good 700 RPMs sooner. Good power no doubt, but the powerband is shifted to the right more than seems necessary.
The peak numbers seem to be right where they should be, a solid setup!
Audiosavvy is offline   Reply With Quote
Old 11-04-2009, 03:47 PM   #13
hammyt
Member#: 92585
2005 Saab 9-2x Aero
13.6@100 EJ205 VF48 93Oct
Unless I'm reading his mod list wrong he is running the stock intake, which maybe the cause of some of that lag.
hammyt is offline   Reply With Quote
Old 11-04-2009, 06:16 PM   #14
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
could that really be a big restriction? from everything i read, i didn't think it would be too much of a gain so i forewent getting a CAI or short-ram and just stuck with stock airbox (no resonator/snorkel).
Old 11-04-2009, 06:44 PM   #15
Audiosavvy
Member#: 150794
Qcab dakota 4x4
At your power level, it could definitely help, though it's hard to say just how much it would. I still wouldn't see it gaining you 700 RPMs of spool though.
As I said you're making good power, but not even making close to 10psi by 3500 is not quite right... The right half of the graph looks good, the left half not as much
Old 11-04-2009, 07:31 PM   #16
xsnapshot
Member#: 170973
2004 WRX 4EAT
It looks like they didnt start the pull until around 3,000 RPM. Which would make sense why it takes 1000 RPM to spool up. Start that pull at 22-2300 RPM and I bet full boost comes on a good deal quicker.
Your right though....I would've expected that torque peak at 4000. not 4500.
Old 11-04-2009, 09:09 PM   #17
CatfaceType-R
Member#: 81102
awesome numbers and setup, who needs a ej257??
CatfaceType-R is online now   Reply With Quote
Old 11-04-2009, 09:12 PM   #18
CatfaceType-R
Member#: 81102
I didn't see him post a boost graph? how do you know what his boost is at and when? no offense...
tuners get to decide what his graph will look like by how he achieves his torque
it looks completely normal and like a nice strong tune to me on a ej205
Old 11-04-2009, 09:21 PM   #19
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
the boost is the dotted line (look at the right side scale)
Dyno Tune: 2.5L Shortblock + VF39 = 270hp/310tq w/ 91 oct (05 WRX) Kenji815 Proven Power Bragging 28 06-19-2010 07:21 PM
Dyno Tune: 2.0L + VF43 makes 285 whp dsolis Proven Power Bragging 54 04-05-2010 06:34 AM
Dyno Tune: 2.0L + Blouch Evo lll 16G makes 302 WHP burtonrider3889 Proven Power Bragging 33 03-26-2010 12:00 AM
Dyno Tune: 2.0L + TD04 makes 242whp 263WTQ (Epic Motorsports) fl4tsc Proven Power Bragging 17 02-05-2010 03:31 AM
Dyno Tune: 2.5L hybrid + VF39 makes 352whp on 92 octane *03wRx* Proven Power Bragging 8 11-08-2009 11:18 PM
