Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 11-04-2009, 11:13 AM   #1
jessetm
Member#: 228956
'15 ISM STi
07 WRX on e85-sold
Default I need a clear answer on how to disconnect my DRL's on my 07 WRX
I'm a newbie, so I hope I'm doin this right, I looked around for info on this. I couldn't find a clear answer. Is there a DRL relay I can unplug for my 07 WRX? Is it behind my glovebox? I put a HID kit on, everything works fine I just don't want the DRL's on anymore...
jessetm is offline   Reply With Quote
Old 11-04-2009, 11:24 AM   #2
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 12.8@105mph
boostdog is offline   Reply With Quote
Old 11-04-2009, 12:10 PM   #3
jessetm
Member#: 228956
'15 ISM STi
07 WRX on e85-sold
Thanks Boostdog, I did see these forums that you posted earlier today. I just couldn't seem to get a clear answer as to specific 2007 details. It sounded like 06's were different. I will pull the glovebox and see if it is located there...
Old 11-04-2009, 01:17 PM   #4
boostdog
Member#: 149752
07 wrx tr
anytime mang
Old 11-04-2009, 01:35 PM   #5
jbark1018
Member#: 224935
2015 WRX
Crystal Black Silica
i had issues before but when you click search do advanced and then in TITLES ONLY. its in the drop down below the search box. this should help out a lot...
jbark1018 is online now   Reply With Quote
Old 11-04-2009, 02:27 PM   #6
f1speeder
Member#: 138854
I did it to my 06 WRX.
Move the passenger side seat all the way back.
Look under the dash towards the side where the fender would be.
You will see a white wire clip.
With small hands you can disconnect it without removing the glove box.
EASY AS PIE
f1speeder is offline   Reply With Quote
really need help with how to disconnect fuel pump relay on 05 RS MrSaabaru Normally Aspirated Powertrain 2 08-06-2005 10:13 PM
Confused on how to disconnect throttle cable.. jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-28-2005 05:12 PM
I am putting too much thought into this question, any ideas on how to answer it? linux>windows Off-Topic 15 09-17-2004 08:34 AM
Directions on how to put AN fittings on SS braided line? rhdude Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-08-2003 07:05 PM
Need instructions on how to install on my clutch BLUETURBOWRX Transmission (AT/MT) & Driveline 15 10-10-2002 05:39 PM
