Old 11-04-2009, 06:48 PM   #1
Scott_2.5TS
Member#: 163806
Default Quick Omori boost gauge install question
This seems a bit harder than i thought it was going to be, more wiring came in the package than i anticipated
instructions:
http://www.j-spectuning.com/installs...lumn_Podv2.pdf
The thing that confuses me the most is, i was almost 100% the majority of boost gauges are tapped off the line at the top of the BPV? The instructions mention tapping a line that goes to the check valve? near the intake manifold/FPR
Also it makes no mention of the black pouch in the pic (which contains a circuit board and some wires coming out of it), also the clear plastic thing with the sponge inside?
My head hurts
Scott_2.5TS is offline   Reply With Quote
Old 11-04-2009, 10:07 PM   #2
sharkmonkey
Member#: 118566
2005 WRX
I believe the black pouch is a dimmer accessory, meaning the boost in stock trim doesn't dim with the rest of the car's interior lights. That is meant to fix that, but I don't know how to hook it up. I have a stack of Omori gauges sitting on my desk and no instructions to install them either :/
sharkmonkey is offline   Reply With Quote
Old 11-04-2009, 10:13 PM   #3
RedefinedTR
Member#: 149848
2011 Honda CRZ
Performance White Pearl
I have one on my car, did not use the dimmer box. Actually don't think I got one with mine. But I tapped off the fuel pressure regulator line, seems to be more accurate, don't get spikey numbers. I recommend using zip ties to make sure the lines don't pop off tho.
RedefinedTR is offline   Reply With Quote
Old 11-05-2009, 04:17 AM   #4
Scott_2.5TS
Member#: 163806
coool... where do you guys put the sender? engine bay or under the dash?
probably doesn't matter anyway
Old 11-05-2009, 08:47 AM   #5
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Put the sender in the engine bay.
If you're going to run a hose under the dash, you should have just bought a mechanical boost gauge.
Old 11-05-2009, 05:33 PM   #6
Scott_2.5TS
Member#: 163806
I don't understand this... on page 9
There are 4 wires
red: connect to ignition wire
green: connect to ignition wire
white:connect to switch lighting or small accessory wire
black: ground
wheretf are these wires they speak of?
then it goes on to say
red: yellow/green
green: yellow/green
white: pink/blue wire (if gauge comes on with headlights
black: black
Are they trying to say that there's 2 different ways to wire this thing?
Old 11-07-2009, 09:57 AM   #7
MTL_Flat4
Member#: 63352
2006 WRX wagon
I have a printed copy of the install. Mine says the following:
RED: Ignition switch
Green: battery +
White: 12V dash lighting
black: vehicule ground
So for me, it will be pretty strait forward. White and black will go behind the radio. There is a connector behind the radio for the oem boost gauge option. This connector is tied with the car's dash dimmer.
For the Red and green, I will play with my multimeter.
MTL_Flat4 is offline   Reply With Quote
Old 11-07-2009, 04:29 PM   #8
Scott_2.5TS
Member#: 163806
i got it wired up. It came with a resistor/dimmer thing (see it sitting ont he dash int he pic)
I didn't install it, can i just solder it where everything is connected? or willt hat affect the clock? i guess it has to be soldered along the power line going to the gauge?
Old 11-07-2009, 04:40 PM   #9
20wrx09
Member#: 207417
2009 WRX
td06sl2-20gtx 413/423
this is to be put in the line going to the sender unit so that dirt and moisture doesnt get into the sender
20wrx09 is offline   Reply With Quote
Old 02-20-2011, 04:11 PM   #10
slimez04
Member#: 260286
2013 WRX Wagon
I didn't hook up the filter thingy. Has anyone had a problem with not using it? I guess oil junk will eventually work its way into the sender.
slimez04 is offline   Reply With Quote
A few questions about Omori boost gauge install- dimming and extra parts.. Civ2Sub311 Newbies & FAQs 23 02-20-2011 07:16 PM
A few questions about Omori boost gauge install- dimming and extra parts.. Civ2Sub311 Electrical & Lighting 1 09-16-2009 10:30 AM
Quick 2p connector for boost gauge install question BlackoutWRX Newbies & FAQs 4 01-16-2006 01:23 AM
Omori Boost Gauge Install Pic BrysImpreza Forester Forum 13 09-11-2003 09:59 PM
Omori Boost Gauge Install volley Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-22-2002 10:36 AM
