Old 11-04-2009, 10:45 PM   #1
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Default Built 2.5 Rallispec block, AMR T60R, STi Mikey tuned... NOW WITH MORE 35R!!
Event:[/color] Dyno Pull
Ambient Temp: 60?
Elevation: sea level
Car: 2007 STi
Tuner: JR
Dyno Info: Dyno Dynamcis @ 1.2CF
Peak HP at RPM: 381 @ 6800
Peak Torque at RPM: 330 @ 4400
Baseline hp/tq for a stock on same dyno: 240WHP
Target Boost: 18.5PSI
Target AFR: 11.0
Fuel: 93 unleaded
Driveline Modifications: Clutch Master Stage 3 + flywheel
Engine/Power Modifications:
Rallispec built 2.5 block
-Weisco pistons (99.5mm)
-Manley rods
-Cosworth bearings
-2010 black crank
-2010 oil pick up, oil pan, oil pump, water pump
-Heads decked ~ .008- .010''
-ARP headstuds
AMR-T60R Turbocharger (60lb/min, ported hotside, ported & polished cold side, coated snail)
Maddad headers
Maddad 3 bolt upipe
Tial 38mm EWG & dump tube
APS 3'' TBE
APS hard 3'' inlet, SPT intake / Perrin Big Maf
D-werks 850's
Turbo XS FMIC
Ecutek / Openecu Junior tune
Other: Tein coilovers, AEM boost and wideband, 7'' screen........
I left my office anticipating a nice break in tune. Needless to say, other things happened
I got there with the SPT on the car. Junior literally had the car down on the first pull. 300 whp pulling to 7500, no knock. Second pull, 350. Third, 380whp and out of MAF.
We decided to continue, and for that I owe Jimmy and Junior many of Peepee touches, as my big maf was 40min away and it was already 7PM.
I was so excited, the car sounded and pulled great. I got back to the shop and put the maf intake on.
AND THEN: My tactrix cable failed
And the car resides, on the dyno, with a dead ECU. Junior just looked at me and shook his head, BUILTSTI was the one pulling the car and couldnt believe it either (and couldnt believe he had to drive me 40 minutes home
Anyways, I am very thankful in the fact that the car was blowing no oil, and that the pulls were healthy. As far as the tune, well, the only thing I will say about the timing is there barley is any, haha!
As a reference, 367whp tapering to 350@ redline yielded me a best ET of 12.01 and best MPH of 114.xx
BUILT will have the graphs up tonight
STi Mikey is offline   Reply With Quote
Old 11-04-2009, 10:51 PM   #2
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
mike does anything go smoothly the first time for you? cheese and rice man dont waste any money on lotto tickets. are you going to run at New England Speedway this summer? let me know if you do. i hope things work out for you man.
~woody
woodys77 is offline   Reply With Quote
Old 11-04-2009, 11:00 PM   #3
GeneralTJI
Member#: 152680
Sounds like good power at low boost with a conservative 93 tune!! right on! I made that kind of power at 21-22 psi RSL, with agressive timing and aggressive AFR's That thing you have breathes!
GeneralTJI is offline   Reply With Quote
Old 11-04-2009, 11:06 PM   #4
WRBear
Member#: 207171
2009 WRX
Glad everything worked out for you man.
Hope those nice numbers will yield you sub-12 times at the track soon.
WRBear is offline   Reply With Quote
Old 11-05-2009, 12:20 AM   #5
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Hey Mike, thanks for telling me about all the fuk'ing road work......
Took me 45min to drive you home, and 1 hr to get back.
BUILTSTI is offline   Reply With Quote
Old 11-05-2009, 12:24 AM   #6
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
Weird, my ecu died as well once there too. Power seems good, GL with the car!
j255c is offline   Reply With Quote
Old 11-05-2009, 12:25 AM   #7
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
so now what? when you going for the 500's? anyway thats awesome the motor held. congrats!!!
06-wrx-tr is offline   Reply With Quote
Old 11-05-2009, 12:26 AM   #8
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Was I there?
I seem to fry stock computers for some reason.
WRBEAR's WRX stopped flashing the second I walked up to the car tonight !
Old 11-05-2009, 12:31 AM   #9
WRBear
Member#: 207171
2009 WRX
Originally Posted by BUILTSTI View Post
Was I there?
Wha-wha-what?
Old 11-05-2009, 01:00 AM   #10
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
Was I there?
Dont know i had a black lgt made 420whp ish, then stopped reading and eventually bricked itself out.
Old 11-05-2009, 01:07 AM   #11
downsti
Member#: 63179
2006 Stock Turbo STi
[email protected] VF39
Congrats on the new found power.
good stuff man
downsti is offline   Reply With Quote
Old 11-05-2009, 01:13 AM   #12
ryanviola
Member#: 148445
06 wrx
FP Green 450whps at 22lbs
Ambient Temp: 60?
Car: 2007 STi
Tuner: JR
Target AFR: 11.0
Fuel: 93 unleaded
-Manley rods
-Cosworth bearings
-2010 black crank
-ARP headstuds
Maddad headers
Maddad 3 bolt upipe
APS 3'' TBE
D-werks 850's
Turbo XS FMIC
NOT AGAIN
ryanviola is offline   Reply With Quote
Old 11-05-2009, 01:14 AM   #13
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
Congrats man!
What's the plan for the ECU?
jordanretro1223 is offline   Reply With Quote
Old 11-05-2009, 01:19 AM   #14
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
loooooooooool
Old 11-05-2009, 01:32 AM   #15
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by ryanviola View Post
NOT AGAIN
GL Mikey, I hate the scaling of the graphs .
Old 11-05-2009, 02:14 AM   #16
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Are you going to hit the quarter at this psi?
I am very tempted to take mine and I am only at 15 psi. My tuner wont be back for another week or two.
godforbid67 is offline   Reply With Quote
Old 11-05-2009, 03:38 AM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
315 whp, nice
sure hope the motor wouldnt blow on 315.....
how do you guys blow ecu's?
i've reflashed my wrx and sti about 1000 times EACH
builtsti is gonna make ~30-40 whp more than you.....that 7cm housing is gonna kill you.
Old 11-05-2009, 06:18 AM   #18
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Originally Posted by Phatron View Post
315 whp, nice
If 315 whp can get you 117-118 traps, then my car right now has 315whp....oh wait, right now my car has zero whp, on every dyno
John made 458 on pump. I'll make 430-440. There is no timing in it yet dont forget.
7cm is a little weak, but this one held power out past 7k. With John's set up he should make 20-30 more on pump, he has crzy heads and 5 lb/min more on the turbo.
It still should be fun. 440= 121 traps and = 375 @1.0.
Old 11-05-2009, 06:36 AM   #19
SharpByCoop
Member#: 199906
2008 Infiniti G37S
World's quickest: 11.13"
It's all a test, isn't it Mikey? I know how you feel.
Your carrot is dangling right in front of you. ....juuuuust out of reach.
You're going to rock this week, I'm certain. (Me too!)
Good stuff.
Coop
SharpByCoop is offline   Reply With Quote
Old 11-05-2009, 07:54 AM   #20
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Wow Mikey that was quick turn around from a crapped out stock motor to badass build with a 60lb/min turbo set-up
Congrats!! Can't wait to see what times you can get out of this beast.
Can I ask what landed you on this particular turbo?
Steve.804 is offline   Reply With Quote
Old 11-05-2009, 08:04 AM   #21
SharpByCoop
Member#: 199906
2008 Infiniti G37S
It's a quality piece that made over 500whp on my car. We made a decision to go to an HTA35R on mine, and this was made available to my buds.... He's gonna love it.
Coop
Old 11-05-2009, 08:28 AM   #22
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
It's going to be a rape !
If all goes well, we can put these cars to the test this weekend
Old 11-05-2009, 08:30 AM   #23
ELJonesy
Member#: 175586
track day?
ELJonesy is offline   Reply With Quote
Old 11-05-2009, 09:14 AM   #24
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Congrats on the preliminary results and that the motor is tight. Sucks about the ECU, but just another step in the process.
Originally Posted by ELJonesy View Post
track day?
Weather looks really good, Island on Sunday?
OppositeLock is offline   Reply With Quote
Old 11-05-2009, 09:17 AM   #25
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
No point really. That was with the stock maf, the big maf is on the car now.
There are two options as of now for the ECU. Either Junior can restore by refreshing my current ecutek license, or Jimmy can lend me one while mine is sent out to tactrix. The car is in their hands so its not my call, but all aside the car should resume pulling on friday.
Ill get it to the track on pump gas before the end of the season, then race gas next spring if all goes well.
F/S Fully Built 2.5 short block (pics) STI 02 SCIC Private Classifieds 7 10-07-2010 12:21 PM
02 WRX Built 2.5 long block, GT35R crippies42 Private Vehicle 'For Sale' Classifieds 29 10-21-2009 06:41 PM
you guys perfer built 2.5 block or 2.0 block?? sexycat Built Motor Discussion 9 05-30-2008 01:34 PM
WTB(fl) built 2.5 short block scottD Private 'Wanted' Classifieds 1 01-31-2008 03:42 PM
JDM sti v7 heads + built 2.5 block... rev limit? InfamousDX Built Motor Discussion 11 06-20-2006 11:07 AM
