Old 05-14-2002, 11:21 PM   #1
Marcin
Member#: 2874
2005 CGM WRX WGN
Jorge Tunned BattleWagon
Question Anyone with Burllen 3", especially Ludespeed Kit
Does anyone know if a 3" Burllen Catback fits stock cats. Does it bolt in to stock 100%.
Also does anyone know if Burllen bolts into Ludespeed downpipe.
I'm thinking of getting the Burllen Exhaust System but I'll be driving with it N/A for a while. I have a ludespeed kit to install, and I want to know If I can use the exhaust with and without the kit installed.
Thanks
Marcin is offline   Reply With Quote
Old 05-15-2002, 11:52 AM   #2
Impreza25RS
Member#: 4850
1998 EJ22.5RS-T
more mods coming soon!!
Sorry man but the 3" Brullen is way to big for the stock cats without modification. Im not sure about the Ludespeed kits but my 2.5"downpipe from FAT still too small for the 3" Im sure it is very easily adaptable though.
Kyle
98RS Owners UNITE!
Impreza25RS is offline   Reply With Quote
Old 05-15-2002, 01:23 PM   #3
Aphex
Member#: 146
'16 WRX Limited
all depends on the flange that's on the brullen, if it's got a 2.5" flange with the two bolt holes on it then it should bolt right up to both the stock cats, and to the downpipe when you get it, if it's got the 3" flange with 3 bolt holes then it will not fit onto the stock cats, but if you don't have the turbo kit yet, you could let tom know and either order a 3" downpipe with 3" flange or get the 2.5" downpipe and a 3" flange on the end of it.
eli
Aphex is offline   Reply With Quote
Old 05-15-2002, 02:03 PM   #4
preza
Member#: 1454
2000 2.5 RS-T
it will not bolt up to the stock cat, the flange is too big.
BTW it is a 2 bolt flange, i cut the flange off and clamped it to shiv's downpipe with no cats
preza is offline   Reply With Quote
Old 05-16-2002, 08:25 PM   #5
Marcin
Member#: 2874
2005 CGM WRX WGN
Thank you all for the replies.
I'll see if it's possible to get a 3" midpipe with 2.5" flange from Burlen, that would be great. I'll ask them.
I'm not sure if Tom can make a 3" downpipe, I haven't seen it mentioned on the Ludespeed website. I think Nick (8Complex) got a 3" DP but it has 3 bolts flange, not 2 bolt. I'm going to ask Tom too.
Preza: I understand that you have a Burllen, if so, what do you think about it
Would having a 3" downpipe made be benifical enough to invest and get the DP made, against just making the 3" exhaust fit the 2.5" downpipe?
Paging anyone with a Kingpin GT35R Turbo kit IDOXLR8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-02-2005 08:09 AM
Anyone with field experience of AVO kits? G.Subramaniam Normally Aspirated with bolt-on Forced Induction Powertrain 4 08-22-2004 04:45 PM
Turbo Kit Owners, READ. Especially Ludespeed kit owners. ImprezaRSX Normally Aspirated with bolt-on Forced Induction Powertrain 20 02-05-2004 02:45 PM
Anyone with a LudeSPEED stage III kit... WRX 555 STi Normally Aspirated with bolt-on Forced Induction Powertrain 5 11-26-2002 05:00 PM
Anyone with a working IC Sprayer kit? Obscure411 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 09-10-2001 04:05 PM
