Notices
Old 11-05-2009, 05:43 PM   #1
alpentalic
Member Sales Rating: (1)
Member#: 146280
2004 39'WRX - SOLD
2005 Duramax Silverado
Default Prosport Oil Pressure Sender Problems
Just wondering if anyone else has had problems? FYI - my experience is specific to the performance series.
My story:
Purchased a set of prosport gauges about 6 months ago, oil pressure and oil temp. Install the gauges and the oil temp works great right out of the box. Oil pressure starts out normal, reading maxed out, but once warm sparatically cuts in and out and reads 0psi most of the time. So, I check and recheck grounds and sender wires and determine out of box failure on the sender. Contact prosport and ordered a new sender. Customer service rep offered to credit me back if I mailed in the broken sender, assuming the sender proved to be bad in a bench test. New sender arrived and solved the problem. Never mailed in the deffective one as the part was only $20 and didn't seem like it was worth the hassel.
Everything works great for the last 6 months and recently the gauge reading drops to 20ish psi while driving and I notice when I stopped that I'm leaking oil. WTF. Get under the car and locate the source of the leak at the oil pressure sender. I assume that the leak is related to the tefflon tape that I used to seal the threads and remove the sender and reseal with a liquid based non-drying thread sealer. Did not fix the problem. Upon further inspection realize that the oil is leaking from the sender it self. The sender unit is a two piece construction with one part as the treaded end of the sender and the other piece being the cup like housing that holds the sender. It seems as if the seal at this junction between the two pieces has failed and is allowing oil to escape.
I'm wondering if this is just an extreame fluke that I have had two failures in a period of 6 months, because I have heard nothing but good things about these gauges on a bang for your buck level. Has anyone else out there had a similar experience with the performance series sender?
List of NASIOC users who have experienced failures:
alpentalic - 2 failures
watercooled - 2 failures
FleaDog - 2 failures
SCOOBYdudematt - 2 failures
alpentalic is offline   Reply With Quote
Old 11-10-2009, 10:01 AM   #2
watercooled
Member Sales Rating: (18)
Member#: 109051
04 WRX
Default Re: Prosport Oil Pressure Sender Problems
im on my second oil pressure sender for this gauge, and its currently broken. I never had any leaks, the darn thing just stopped working after about 6 months both times.
mayb third times a charm?
watercooled is offline   Reply With Quote
Old 11-10-2009, 10:28 AM   #3
spinningcain
Member Sales Rating: (77)
Member#: 176490
2005 STI
mine has been fine for a year
spinningcain is offline   Reply With Quote
Old 11-10-2009, 04:22 PM   #4
HeyChris
Member Sales Rating: (7)
Member#: 2234
2013 F-XT
Obsidian Black Pearl
Prosport gauges = Glowshift.com gauges. Just relabled with higher price.
I have the latter for over a year, no issues other than reads a little higher than I think it should be...
C.
HeyChris is offline   Reply With Quote
Old 11-11-2009, 04:15 PM   #5
alpentalic
Member#: 146280
2004 39'WRX - SOLD
So I have found at least one other owner who has gone through not one, but two senders. I have no complaints about the gauges, they work fine and read what I believe to be accurately. I'm just at the point where I don't want to spend $20 on another sender that is just going to fail again.
Old 11-17-2009, 09:33 AM   #6
sourcandy
Member Sales Rating: (2)
Member#: 212410
If your using tape on the threads, make sure it's rated safe for oil usage. While I have not seen the threads on the sender, I'm guessing it is NPT cut. In my understanding you don't need sealer with NPT as they are designed to seal? Could be wrong, just offering help.
sourcandy is offline   Reply With Quote
Old 11-21-2009, 07:17 AM   #7
FleaDog
Member Sales Rating: (4)
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
Had to replace 2 before the latest which has been running strong (knock on wood).
FleaDog is offline   Reply With Quote
Old 11-23-2009, 02:24 PM   #8
alpentalic
Member#: 146280
2004 39'WRX - SOLD
So now were up to three people that have gone through more than two senders. I'm going to start making a list in the original post.
Old 11-23-2009, 05:47 PM   #9
SCOOBYdudematt
Member#: 134380
'05 CGM STi
GT35R'd with 315mm tires!
this is my second sender and it looks like it has gone bad after about 3 months of use.... :fail:
SCOOBYdudematt is offline   Reply With Quote
Old 11-23-2009, 10:22 PM   #10
watercooled
Member#: 109051
04 WRX
where are you mounting these senders?
I wonder if maybe they are getting wet or too hot.
Mine is near the shock tower connected to a remote line going to the factory oil plug.
I dont think its getting too hot way over there, but who knows.
I ordered a 3rd one, but this time I think I will wrap the oil line from the block
that passes by the turbo with aluminum shielding and see if that helps it survive.
Old 11-24-2009, 12:22 PM   #11
alpentalic
Member#: 146280
2004 39'WRX - SOLD
added to the list of failures
Mine was direct into the sandwich plate that prosport sells. I kept the under tray on my car at all times, so it shouldn't have gotten overly wet and regardless should be enginieered to withstand a reasonable level of moisture and heat and nothing should have caused mine to start leaking.
Old 11-24-2009, 02:02 PM   #12
mastershakewrx
Member#: 80120
2002 Wrx sedan
MBP
my gauge stoped reading a signal 3 days after i installed it im waiting to see if prosport will warranty it
mastershakewrx is offline   Reply With Quote
Old 11-24-2009, 02:36 PM   #13
stucknde
Member#: 217703
I was running my oil pressure sender on the sandwich adaptor for about 3 months, then the wire came loose, and i then used lock nuts...bad idea, i ended up spinning the threaded posts and i believe breaking the wires inside the sender...
So long story short...thread lock
stucknde is offline   Reply With Quote
Old 11-24-2009, 03:27 PM   #14
alpentalic
Member#: 146280
2004 39'WRX - SOLD
I assume you have checked your connections and have confirmed that this is some sort of failure. Have you determined if it was the gauge or the sender that failed?
Old 11-24-2009, 08:57 PM   #15
watercooled
Member#: 109051
04 WRX
I want to add that I have never had a problem with the gauges themselves,
and I have alot of them. Oil pressure, coolant temp, EGT, mechanical boost, oil temp,
and not 1 single problem ever in 2 years.
Old 11-25-2009, 11:28 AM   #16
stucknde
Member#: 217703
yeah i pretty much broke my sender, my only advice is for people to use thread lock so the nuts dont vibrate off...which i will be doing on my next one.
Old 07-20-2010, 06:47 AM   #17
FCmaniac
Member Sales Rating: (69)
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
Isn't there a better sender from a different company that we can buy? I'm talking about for use with the Prosport electric oil pressure gauges.
FCmaniac is offline   Reply With Quote
Old 09-17-2010, 09:19 PM   #18
thechoochman28
Member#: 42900
Add me to the list, oil pressure sender lasted 3.7 years...fuel pressure sender is still working though.
I thought I was going crazy and had serious engine issues, because the leak was so slow I couldn't find it until the oil started to leak more and then burn off and smoke on top of my engine block.
It appears the leak was coming from between the housing of the sender...if this one goes i'll know to throw some high temp epoxy on the next one.
thechoochman28 is offline   Reply With Quote
Old 10-25-2010, 08:36 PM   #19
ScooByBooSt007
Member Sales Rating: (6)
Member#: 149382
2004 Sti
FP HTA68+Meth 368hp 25psi
Wow what a coincidence, my oil pressure gauge took a **** out on me too about a week ago and I'm now mysteriously leaking a minuscule amount of oil somewhere but I can't seem to locate where it's coming from cuz it's not actually leaking but it's being burned off somewhere below my passenger side cylinder head so I never actually get to see where it's coming from. I'm hoping that it's coming from the sender and nothing else but I dint think it is becaue I'm taping my oil pressure sender off one of those sandwich adapter platea that go between the oil filter and the oil cooler and if I'm correct the adapter plate sits lower than any of the exhaust piping correct??. Haven't gotten a chance to look at everything yet but I wouldn't be surprised if it was from this sending unit!!!
ScooByBooSt007 is offline   Reply With Quote
Old 10-26-2010, 09:23 AM   #20
Blackcot
Member#: 186985
i got mine 7 month ago and boost and oil press stop working....
i send an email to prosport and they said to send back the gauge for testing......
or that they can sell me a new sender for 36$....
next time i will stick to autometer for ''cheap'' gauge
Blackcot is offline   Reply With Quote
Old 01-12-2011, 09:18 PM   #21
watercooled
Member#: 109051
04 WRX
I wanted to add in addition to the 3 oil pressure senders I have had, I finally got around to tapping the EGT sender into the #4 manifold and the dang thing does not even work. Very frustrating
Old 05-11-2011, 12:05 PM   #22
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
I've also had two oil pressure sender failures.... I'm sick of changing these damn things out...
crash is offline   Reply With Quote
Old 05-11-2011, 12:43 PM   #23
FCmaniac
Member#: 142029
2013 Forester
still wondering if anyone is aware of other sender options
Old 05-11-2011, 01:06 PM   #24
HeyChris
Member#: 2234
2013 F-XT
Unfortunately both the Passport n glowshift gauges have been calibrated to the ridiculous
Specs of 3-160 Ohms. Most other brands out there do not start until 10 Ohms....
I looked at other Sending Units before replacing mine. I was unsuccessful and ended buying a GS unit, with a 10% coupon you can easily find online.
The last one lasted me three years. Other than this one working, the main difference is a JPN logo on the unit, where the original did not. Taking the marking as being accurate with the manufacture origin with a grain of salt.
C.
Old 05-25-2011, 10:10 AM   #25
JRizzy24
Member#: 215468
2013 STi
Crystal Black Silica
I replaced both my Oil Pressure and Boost/Vac senders (and replaced the boost hose), traced each wire and ground but the gauges were FUBAR'd. Ordered replacement gauges (now I have an extra sender for each when they fail) for ease of use but they changed the gauges and connectors so I had to do a little rewiring...however, the gauges are now working again.
If they fail again I'm going with another brand
JRizzy24 is offline   Reply With Quote
FS : Parting my car out W0R7Xsubi Tri-State Area Private Classifieds 251 06-17-2014 01:31 PM
To all who own a Prosport Oil Pressure Sender Spike700 Electrical & Lighting 11 06-18-2010 10:03 PM
FS prosport oil pressure sender and Tamiya RC car W0R7Xsubi Tri-State Area Private Classifieds 21 04-06-2010 10:49 PM
Prosport Oil Pressure Sender Question crazycanasian Electrical & Lighting 8 09-19-2008 01:38 PM
Prosport Oil Pressure Sender Question crazycanasian General Community 2 08-19-2008 06:52 AM
