Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 11-05-2009, 11:00 PM   #1
Dnhieu
Member#: 225969
Default FS: 1991 Eagle Talon tsi awd
so the time has come to sell my car. its got 178k on it currently and less than 5k on the built motor. every ball joint, wheel bearing, tie rod end, rotor and brake pads have been replaced all in the last year.
Mods
Engine:
Ross 8:5:1 .020 over pistons
Eagle Rods
micro polished crank
acl race bearings (main and rods)
cometic headgasket
arp rod bolts and headstuds
balance shaft eliminator kit
ported 1g head
BC 280 cams
FP 4" intake
holset hx40 with complete bulls eye kit
evo III exhaust manifold
punishment racing o2 housing
tial 38mm wastegate
custom 3" turbo back exhaust with fake cat
ebay boost controller
devils own meth injection kit
punishment racing FMIC kit
greddy type RS BOV
rebuilt 1g throttle body
fidanza adjustable cam gears
koyo racing radiator
1 stock fan 1 slim fan
hks turbo timer
fuel pump rewire
2g maf
egr block off
removed emissions
ported oil filter housing
jmf heat shield
msd plug wires
ngk bpr7es plugs
dejon tool front bumper support
shifter bushings
shifter linkage bushings
optima battery (relocated to the rear with circuit breaker)
k&n air filter
electronics
prosport boost, oil pressure, and water temp gauges
DSMLINK v2
plx m300 wideband
fuel
pte 880cc injectors
aermotive fuel pressure regulator
water filled fuel pressure gauge
walbro 255hp
drivetrain
Koni yellow struts
ebiach sportline springs (2" drop)
act 2600 clutch
act 6 puck sprung disk
fidanza flywheel
fidanza short shifter
front strut tower brace
rear camber kit
enkei shogun rims
manual rack out of a 1.8l
2g big brake upgrade
the car runs strong at 24lbs and has a tune that i put on it. only issues with the car is that the windows need help up, one of the head lights is lazy at times, and it could use a new set of tires. the car has run 8.0 at the track but was breaking up and never got a full clean pass.
asking 6k firm
contact info
[email protected]
850-276-8227
Dnhieu is offline   Reply With Quote
Old 11-06-2009, 08:44 AM   #2
Dnhieu
Member#: 225969
bump!
Old 11-06-2009, 10:21 AM   #3
Skyline25
Member#: 162360
Sweet ride I would love to have another one. These cars are a blast to drive.
Skyline25 is offline   Reply With Quote
Old 11-06-2009, 10:48 AM   #4
Dnhieu
Member#: 225969
thanks man. its a bit laggy with the 280 cams and the holset but once it reaches full boost its a blast to drive! im gonna miss her but i really want to step up the displacement and get in touch with torque of a subie
Old 11-06-2009, 06:13 PM   #5
Dnhieu
Member#: 225969
bump for a clean GOOD RUNNING 1g dsm!
Old 11-06-2009, 07:34 PM   #6
subaruwrx300hp
Member Sales Rating: (4)
Member#: 137892
I've always been a subie guy so help me out a little here.
where is the car located?
can you estimate the 1/4 time?
what is the whp and tq? or hp and tq?
any issues with the transmission? can it handle the power its making?
subaruwrx300hp is offline   Reply With Quote
Old 11-07-2009, 12:06 AM   #7
Dnhieu
Member#: 225969
the car is located in panama city florida. i cant tell you what it runs in the 1/4 but it ran consistent 8.0's in the 1/8th breaking up. that issue has been fixed and the car is running stronger then ever. i would estimate around 400-450hp range on 24-26 psi range. i have no issues with the transmission. it shifts through every gear fine. everyone says these transmissions are garbage but i have never had a issue. its all in the driving .
Old 11-07-2009, 01:01 PM   #8
Dnhieu
Member#: 225969
bump!
FS: CT : 1991 Eagle Talon TSI AWD 5spd, 40k original miles wrx4x4 Private Vehicle 'For Sale' Classifieds 5 03-24-2008 06:44 PM
1991 Eagle Talon Tsi AWD Douginss SWIC Private Classifieds 0 07-26-2007 12:35 PM
FS: 1991 Eagle Talon TSi AWD WRXTacy419 Private Vehicle 'For Sale' Classifieds 0 08-24-2006 09:47 PM
FS: 1990 eagle talon tsi awd 5spd 50k orig miles pimpinwrx MAIC Private Classifieds 3 03-30-2006 12:37 AM
FS: 1991 Eagle Talon TSI AWD turbo2 Private Vehicle 'For Sale' Classifieds 0 12-08-2004 12:37 AM
