Old 11-06-2009, 03:51 AM   #1
dlh1999
Member#: 105629
2006 300c SRT8
Default Leak causing knock?
I've had a couple CEL's lately that have all been MAF related. I know that the MAF is fine, but after pressurizing the inlet to find leaks, I've found one on one of the elbows coming off the inlet. Also, some of the IC couplers seem to be a bit worn, and might be leaking as well.
Would a leak in the intake system cause a lean condition, which would in turn cause knocking and/or lower IAM's? Recently I've done some logging, and definitely have some knock...I'm just hoping that maybe a leak somewhere might cause this...at least it'd be a relatively easy fix. Any ideas?
dlh1999 is offline   Reply With Quote
Old 11-16-2009, 06:15 PM   #2
awd4ever
Member#: 31573
I found the
meaning of life!
I am curious about OP question that as well.
Also, how did you search for leaks? In the rx7 days I used to spray wd40 on joints and listen for idle to go up. It doesnt seem very precise, but it would find some larger leaks.
Thanks,
awd4ever is offline   Reply With Quote
Old 11-16-2009, 07:20 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
any leak after the MAF can cause problems, however with a turbo when under boost, leaks will result in less than the MAF measured amount of air reaching the cylinders (rich condition) and while under vacuum the opposite typically occurs.
A WB is highly recommended and really required to tune beyond CL maf scaling and OL/CL delay zero-ing
Can a boost leak cause a knock? Deserted1 Engine Management & Tuning 2 04-18-2009 01:02 PM
Major Pre-turbo exhaust leak - cause car to knock? BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-27-2007 03:18 PM
Bad plugs causing knock/misfire? CreeeV15 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-08-2007 11:25 PM
can this code cause knock sr55stiguy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-11-2006 10:09 AM
Could a 3 cent screw and an idiot be causing knock? srf Engine Management & Tuning 8 07-31-2005 10:39 PM
