Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-15-2002, 02:35 AM   #1
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Default Tapping the turbo outlet?
I havethe Ludespeed stage III kit, and am messing around with boost controllers. Right now my wsategate is getting it's signal from the intake manifold. I think it would be a better set up if I was to tap the turbo outlet and get a pressure signal from there, like on most other turboed motors.
Has anyone tried this before?
I think it might be easier to tap the elbow pipepiece between the IC and the turbo. That was if I screw up I only mess up a peice of steal piping!!
LVSUBARU is offline   Reply With Quote
Old 05-15-2002, 10:33 AM   #2
Jewbaru
Member#: 1994
2013 Impreza WRX
first off, external wastegates should be connected after the TB.
Second, what boost controller? MBC, or EBC?
Third, don't go punching holes in the turbo, there is a little square screw sticking out from the side of the turbo outlet. Remove that, go to autozone, and get a hose fitting for it. That screw is blocking an outlet that is designed for an internal wastegate's signal source.
Jewbaru is offline   Reply With Quote
Old 05-15-2002, 08:44 PM   #3
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
1.That's what I thoght, but sombody told me otherwise.
2.I haven't decided yet. Any suggestions?
3.I don't have a square screw sticking out of my turbo. It's a T3/T4 from the Ludespeed kit.
Old 05-16-2002, 10:26 AM   #4
Jewbaru
Member#: 1994
2013 Impreza WRX
1) External wastegates use 2 sources, and the pressure feed should come from after the TB. Internal wastegates go before the TB.
2) Not sure, use an EBC. I had a profec A, didn't work, so I wouldn't recommend that.
3) Really? That's bizzar, I haven't heard of a single turbo without that port.
what size is the turbo intake side outlet Rexxyou Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-22-2008 09:42 PM
WTB: Sti turbo outlet hose(elbow), turbo oil line. Mecanic07 Private 'Wanted' Classifieds 0 12-13-2006 09:31 PM
Turbo outlet wastegate fitting. Aphex Normally Aspirated with bolt-on Forced Induction Powertrain 3 07-25-2002 12:05 PM
Where is turbo outlet duct link please? ssspoon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-30-2001 01:40 AM
Normal EGT's at turbo outlet? PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-26-2001 09:25 AM
