Old 11-06-2009, 02:36 PM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default does anyone know if the 05+ legacy GT spindle will work on the 93-07 impreza's?
the legacy GT spindle looks pretty different from the impreza spindles, it looks similar to the 05+ sti but they are still 5x100 hubs.
the back of the knuckle has the 4bolts that hold the bearing in like the 05+ sti.
I don't have ABS so I don't really care which style knuckle I have as long as it will work
my car is a 94 impreza L
scobaru is offline   Reply With Quote
Old 11-06-2009, 02:41 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
It's different. I have heard rumor that you can swap over the knuckle, but I have not confirmed.
Old 11-06-2009, 05:52 PM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
If the wheel bearing does unbolt with the hub then I think you might be able to bolt up the 5x114 wheel bearing and hub. I'm curious to know if the part where you bolt the strut up is the same as the 05 sti which would mean that I couldn't use the knuckle
Old 11-06-2009, 07:02 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
That one I know is a no.
Old 11-06-2009, 10:08 PM   #5
jamal
Member#: 71875
98 Legacy GT
my wheels fit
the upright should fit fine. strut mounting and the ball joint and the tie rod etc are all the same.
the bearing isn't specifically any better as far as I know. Having them bolt in would be convenient.
jamal is offline   Reply With Quote
Does anyone know if an '03 WRX oilpan will work on a 2.5??? singincanary Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-13-2014 07:57 PM
Will a 05+ Legacy GT turbo crossmember bolt into a 93-07 impreza??? JRach Subaru Conversions 3 09-12-2009 09:39 PM
Does anyone know if a walbro pump gss 341 will fit 2002 wrx kakarotoni General Community 0 05-06-2008 05:36 PM
Does anyone know if the UR cold air intake would work on the Perrin kit 03clipsegts Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-15-2007 02:59 PM
Does anyone know if STI ver.6 wagon springs will work ok with FHI ver.5 struts? Robmat Brakes, Steering & Suspension 5 05-17-2001 02:13 PM
