Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 11-06-2009, 06:32 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default HKS CAMP System_Apexi AFC Neo $350_Turbo Timers $89
Apexi AFC Neo
The AFC-neo is a multifunctional sub-computer that allows the tuner to fine-tune air-fuel ratios, calculate MAF/MAP transfer functions, control VTEC or other solenoids, address stall issues associated with open-air blow off valves, and monitor key ECU data.
Changes in air-fuel ratio are achieved by correcting the airflow sensor signal or pressure sensor signal at 16 different RPM points, and at high and low throttle positions, all of which can be moved according to the customers needs. By changing this input signal, the tuner can alter the injector pulse width as calculated by the ECU.
The AFC NEO is unique in the sense that it has a built in MAF/MAP transfer function, which is necessary when the tuner swaps MAF/MAP sensors from one vehicle application to another. By setting the sensor IN and OUT to the appropriate sensor numbers, the AFC NEO can act as a translator/emulator unit, eliminating the need for costly sensor or ECU reprogramming.
The unit also has a VTEC solenoid control function that allows the tuner to change the VTEC engagement/disengagement point on Honda VTEC systems (not compatible with iVTEC systems). The VTEC solenoid control and also be used to control other types of solenoids as used in nitrous-oxide and water/methanol injection systems.
On MAF applications with open-air blowoff valves, there is a deceleration air correction feature that allows the tuner to compensate for the over-rich condition that occurs at throttle-off. By adjusting the MAF signal at throttle-off condition, the tuner can reduce the amount of fuel injected and prevent stalling.
In monitor mode, the driver can monitor digital engine RPM, throttle position, battery voltage, airflow sensor capacity usage, pressure sensor data, Karman frequency, MAF/MAP/Karman correction factor, and solenoid on/off status.
The AFC NEO is a universal unit that can be used on a wide range of cars and trucks that have an air metering system that uses a VAF, MAF or MAP sensors operating within the 0-5 volt range, as well as applications using Karman sensors
$350 Shipped
Apexi AVCR
Digital Boost Controller
The AVC-R is a digital boost controller that allows the user to modify the boost pressure level on turbocharged vehicles. While there are many boost controllers on the market, none of the other includes as many features as the AVC-R, period. Despite all of the complex features included the unit, the AVC-R is flexible enough to be used by beginners. Entry level users need only to input a desired boost level and the AVC-R's trademark self learning CPU processor does the rest.The AVC-R also uses a highly durable, fast action solenoid valve to physically control the boost . The valve movement (Boost Duty Cycle) can also be modified. Raising the duty cycle increases boost response, while lowering the duty cycle will slow boost response. This feature allows boost response adjustment for varying turbo sizes. Since larger turbos take longer to spool up ( bad low end response) the duty cycle should be raised under lower RPM's for better response. The opposite should be done for smaller turbo's
$485 Shipped
Cobb AccessPort
Lowest Price on NASIOC
Are you to busy to worry about tuning your own car? Would you like piece of mind knowing your vehicle's computer (ECU) is protected against accidental damage. Are you ready to spend less time fumbling with a laptop and more time driving?
We offer you the ultimate personal tuning solution for your STi. Save time and money with the ability to conveniently reprogram your vehicle's computer (ECU) by selecting one of the pre-installed performance "maps" that automatically optimize settings such as the air/fuel ratio, ignition timing, boost and more for performance results you can instantly feel.
However, the AccessPORT is so much MORE than just a REFLASH DEVICE. It allows you to monitor fuel economy (average and real time), perform performance tests in order to estimate your 0-60mph and 1/4 mile time, read and decipher ECU trouble codes (CELs), and monitor live data via the OEM vehicle sensors which eliminates the need for costly aftermarket gauges.
Lowest Price On NASIOC
Please Call 949-457-1234 for Price
HKS CAMP 2 System
The long-awaited return of HKS' CAMP system is now a reality with the release of CAMP2. CAMP2 is an all-in-one engine multi-meter system that is incorporated with a vehicle's on-board factory or aftermarket monitor.
The launch of the CAMP2 comes just as HKS celebrates its 35th Anniversary. The first generation CAMP was released by HKS in 1996. At that time, it was the first monitoring system of its kind allowing users to view vehicle engine information. During the time of CAMP's initial release, on-board factory monitors were still rarities in cars available in North America and aftermarket units were not as commonly seen as they are today. CAMP2 is now available for purchase through your authorized HKS dealer.
TECHNICAL INFORMATION:
Users can view up to 6 simultaneous readings while monitoring up to 24 data signals from the vehicles OBD2 port and optional HKS Sensors.
Installation is simple and connects to the vehicle's self-diagnostic OBD2 port enabling the CAMP2 to function on a variety of vehicles and applications.
CAMP2s menu features are user switchable to Metric or SAE readings according to user region.
ECO Drive Programmable calculations for fuel costs, average fuel consumption, and Fuel efficiency lets the user monitor real time data readings. (Vehicle applications vary, ECO option is only available to vehicles with the abillity to read Injector and Speed data)
An included remote control allows the user to switch between functions and modes. The remote control receiver is separate from the base unit allowing convenient,user friendly placement.
CAMP2 allows map editing for the F-CON S/SZ/iS.
Display Unit Not Included
PM For Price
DEFI BF-R Series
Perfect Match for STi Gauge Cluster
Defi BF-R Package 60mm(Black/Red)
- ATI Triple Gauge Pod
- Defi V2 Control Unit
- Boost
- EGT
- Water Temp or Oil Temp
$999 Shipped
DEFI Racer Gauges
Defi Racer Package 52mm(Blue/Red and White)
- Boost
- EGT
$749 Shipped
AEM Triple Gauge Package
52mm Gauge Package
- Boost Gauge
- Oil Pressure
- UEGO A/F Controller
$699 Shipped
Apexi Triple Gauge Package
60mm Gauge Package
- Boost Gauge
- Oil Pressure
- EGT
- Gauge Controller
$775 Shipped
Apexi Timers
Silver & Black
$89 Shipped
HKS Turbo Timers
Type 1 Limited Black
$89 Shipped
Type 1 Silver
$89 Shipped
__________________
Thanks,
Gruppe-S
[COLOR=black][B]Please Note:[/B]
[I]- All Competitors Prices Beat
- All Items Are Shipped Via FEDEX
- All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit
- Any Order Cancellation Will Result In A 25% Processing Fee
- Local Pick-Ups Available[/I][/COLOR][I]
- [B][COLOR=Red]No Cancellation on JDM Or Special Orders. No Exceptions![/COLOR][/B][/I]
Gruppe-S is offline
Old 11-10-2009, 10:16 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Car Bump of the Day!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 11-16-2009, 08:31 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Car Bump of the Day
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 11-30-2009, 09:48 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Car Bump!!!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 12-11-2009, 09:56 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 12-22-2009, 04:05 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 12-29-2009, 06:24 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-08-2010, 06:04 PM   #8
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 02-04-2010, 08:11 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 02-12-2010, 10:22 PM   #10
jeffk182
Member Sales Rating: (14)
Member#: 150649
2014 STI
Hey, can I get a price for 2 gauges?
Defi BF-Link EGT (F*) and Oil pressure (PSI) in amber red please!
I am local to your shop and would be picking it up. Thanks!
-Jeff
jeffk182 is offline
Old 02-19-2010, 07:16 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 02-19-2010, 10:22 PM   #12
moratti
Member Sales Rating: (1)
Member#: 238496
2006 STI
Crystal grey metalic
price on an accessport please
moratti is offline
Old 03-22-2010, 10:49 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 04-13-2010, 07:58 PM   #14
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-12-2010, 07:35 PM   #15
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump bump bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-24-2010, 07:09 PM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 06-08-2010, 10:00 PM   #17
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 06-15-2010, 08:52 PM   #18
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 06-18-2010, 04:44 PM   #19
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 06-21-2010, 06:44 PM   #20
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 06-23-2010, 08:24 PM   #21
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 06-29-2010, 08:36 PM   #22
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 07-01-2010, 04:06 PM   #23
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 07-02-2010, 07:59 PM   #24
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 07-13-2010, 08:23 PM   #25
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Closed Thread
HKS CAMP System_Apexi AFC Neo $350_Turbo Timers $89 Gruppe-S Gauges & Electronics 48 10-02-2009 12:02 AM
apex afc neo hector Other Engine Management 5 10-11-2007 10:15 PM
Apexi AFC neo 2.5rsDOHC Engine Management & Tuning 1 08-09-2007 08:33 AM
afc neo 98jdmwrx Pre-2002 Factory Turbo Powertrain 0 08-02-2007 06:03 PM
Apex-i AFC NEO Rallly2000 Electrical & Lighting 1 10-15-2006 01:34 AM
