Old 11-07-2009, 12:26 AM   #1
Speedster329
Member#: 214652
2004 STI !
JBP !
Default stock end links with new sways??
whats up guys i just bought some STI sway bars for front and rear.....can i just take the old sways off and put these new 1s on using my STOCK ENDLINKS?? please let me know because if not i will have to look for some new ones and i want to put this on asap...any info is great....Thanks guys
i got the STI pink 21mm SWAYS for the 02/03 wrx
Speedster329 is offline   Reply With Quote
Old 11-07-2009, 12:31 AM   #2
fastwrx25
Member#: 126441
03 bugeye
the sti bars are longer than the wrx ones.
they are not going to fit perfectly...you might have to install them differently.
maybe someone who has done this will chime in...or go search the suspension forum I've read about this but forgot how to make it work.
did you get stock sti bars?
fastwrx25 is offline   Reply With Quote
Old 11-07-2009, 12:52 AM   #3
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
Stock 02 WRX and STi sway bars are the same diamater 20mm F&R. What's the point? I know that rear end links are different between a WRX and STi.
Edit: Did you by chance get the STi "pink" 21mm sways for WRX?
rexman2002 is offline   Reply With Quote
Old 11-07-2009, 01:02 AM   #4
Speedster329
Member#: 214652
2004 STI !
JBP !
yes i got the PINK 21mm sways for the 02/03 wrx
Old 11-07-2009, 01:27 AM   #5
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
I think you can use oem endlinks, but it's always recommended to go aftermarket endlinks to take full advantage of the sways. You should also consider the 04/05 rear sway mounts as mentioned above, as they are more reinforced than the wimpy 02 ones (that's what I did, 04/05 rear mounts, cusco21mmF/22mmR/kartboy endlinks). But stock endlinks should work fine no problem, I don't see why they wouldn't work.
Old 11-07-2009, 01:31 AM   #6
Speedster329
Member#: 214652
2004 STI !
JBP !
alright sounds good but for the 04/05 sway mounts is it direct bolt on or do i need to customize a few things because if there better i might as well change them while this stuff is off you know...please let me know rexman2002
Old 11-07-2009, 01:40 AM   #7
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
yes, the mounts are a direct bolt one for the 02/03 models, they are from 04+ models, which got a beefier set. Here's where I got mine, not a bad price. For aftermarket heavy duty mounts you're looking at 100$+, but these will work fine with those sways.
https://www.chaplinssubarugenuinepar...oducts_id=1230
Old 11-07-2009, 03:44 AM   #8
fastwrx25
Member#: 126441
03 bugeye
you know your stock bars are 20f/20r right? you only went up 1mm
but yeah everything will bolt up, you can always upgrade the rear sway bar mounts later on.
Hochkis End Links with what sway bars? AutoXRex Brakes, Steering & Suspension 8 03-21-2007 03:14 PM
FS: Perrin, 22mm Sway Bar, Lightened Crank Pully, Lights, Stock End Links Ackit NWIC Private Classifieds 0 01-01-2007 04:36 PM
Recommended End Links With Cobb Sway Bars? Dasani Brakes, Steering & Suspension 5 08-21-2004 05:26 PM
End-Links with Spherical Bearings, All in Stock PolTec Inc Suspension/Brakes/Handling 160 06-18-2004 02:56 PM
('93-'01) Cusco rear sway with stock end links? [gearhead] Impreza Forum 3 02-24-2004 05:00 PM
