Old 11-07-2009, 03:57 PM   #1
cleans13
Member#: 172919
2002 wrx hybrid
psm
Default rear rotor won't come off? 02 wrx
changing my rotors and pads and i can't get the rotor off. yes my ebrake was off when pulling at it. and i went and loosend the cable at the brake handle itself as well. for some reason the drums are frozen to the rotor. i used a sterring wheel puller to try and pull them off, but the drum is stuck. now after all the pulling and hammering and turning the hub i think i have fed up my ebrake setup. i was told there's a rubber plug in the knuckle to access a fine tunning of the ebrake, but i can't see inside nor get a screwdriver in there. any ideas?
cleans13 is offline   Reply With Quote
Old 11-07-2009, 04:23 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
have you tried using a bolt to push the rotor off the hub? or a deadblow to the rotor?
Old 11-07-2009, 04:57 PM   #3
cleans13
Member#: 172919
2002 wrx hybrid
psm
yeah guy i used a steering wheel puller and hammered the crap out of it. the puller did do it's job, but the ebrake assembly or shoes were coming w/ the rotor.
Old 11-07-2009, 08:39 PM   #4
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Try the 8mm (i think) bolts threaded in the holes to push it off.
mmiller2002 is offline   Reply With Quote
Old 11-07-2009, 08:47 PM   #5
Subiracer06
Member#: 182487
04 STI
JBP
when i changed mine out i used a ton of that rust off spray. you have to let it soak for a while and then it did the trick. make sure you spray everything down with cleaner after
Subiracer06 is offline   Reply With Quote
Old 11-08-2009, 05:21 PM   #6
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
stick a bolt in the hole!
lil'redwagon is offline   Reply With Quote
Old 11-08-2009, 11:21 PM   #7
cleans13
Member#: 172919
2002 wrx hybrid
psm
really guy? did you read my first post?
hammered it......not off
sterring wheel puller......not off
the ebrake shoes are stuck on the rotor itself. the rotors loose from the hub, but like i said the ebrake assembly is stuck on it.
Old 11-09-2009, 05:53 PM   #8
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
where does it say your rotor's free form the hub? ...guy?
Old 11-09-2009, 07:57 PM   #9
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Your PB shoes have likely grooved into the tophat. Use a flat screwdriver and turn the adjuster through the hole in the back of the hub. It'll retract the shoes enough to remove the rotor.
IDK on Subies, but on my bug one was RH threads and one was LH threads, IIRC. Or maybe they were just on opposite sides of the car. Anyway, it ought to solve your problem.
ETA: The illustration I have says pry the cog wheel down. ie. The handle of the screwdriver will be moving up. YMMV, of course.
bushflyr is offline   Reply With Quote
Old 11-10-2009, 08:47 AM   #10
rkramer
Member#: 118209
2015 WRX Limitec
yes there an adjuster on the back of the brakes, it is the ones you are supposed to use to adjust the e-brake. Sometimes there is a rubber plug, sometimes it is long gone. I doubt it will help you much in this situation though, there really isn't any access to anything except the star wheel adjuster from that hole.
Need some quick help, rear rotor wont' come off lh0628 Brakes, Steering & Suspension 5 05-30-2010 10:58 PM
Caliper won't come off of rotor HELP!! isk8drugfree Newbies & FAQs 9 10-13-2006 08:15 PM
FS: JDM STi rear glass w/ wiper off 02 WRX sedan (also for sale) boneriffic MAIC Private Classifieds 17 07-08-2006 08:13 PM
H6 DBA rear rotors won't fit WRX? WRXThis Brakes, Steering & Suspension 24 07-14-2002 05:00 PM
Cap bolt just won't come off!! Need help! scooby5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-08-2001 12:25 AM
